Sign in to follow this
w1k
Copying diskette to sio2sd problem
Hello, i have new problem :)
I have new xf551 and i want copy diskettes to sio2sd.. but sio2sd is connect to sio into atari
I set SIO2SD as D1 and XF551 as D2.. can i use D3 as another sio2sd file? i trying it in DOS 2.5, DOS XE, BIBO DOS 7, but doesnt work.. i copy only one program, but when i want copy all of diskette, i have errors, etc.
i try different copy programs, but that same result.. maybe if i can use D3 as SIO2SD, but how?
Can i setup XF551 as D1 and sio2sd as D2? i trying it, but doesnt work..
I have done a similar thing with drive and 1050
Set 1050 to drive 2
Load copy utility into slot 1 on the sdrive
Load a blank or sacrificial .atr image into slot 2 on the sdrive
Reset Atari and load copy utility
Alter settings for source/ destination drive
Swap the blank atr image into slot one of the sdrive
Copy
which program for this copying (diskdrive to sio2sd or sio2pc) is good?
ok, i use mycopier.. first i load mycopier in D1:, D2 is XF551.. then i load BLANK atr to D1..
i set source to D2 and destination to D1
doesnt work :(
Edited by w1k
when i now check DIRECTORY of D2 on q-meg or dos2.5, then xf551 something reading and sio2sd to something reading..
xf551 is left down, right up (d2)
Edited by w1k
wait, its working.. thank you :)
Edited by w1k
:thumbsup:
Your budgies seem to like the SIO sounds.
yes, in each video :/
So am i right in thinking that you can use original atari disks with this sio to usb thing (or at least make them into atr/emulator compat. files)
yes, i can, but on that diskettes is nothing interesting.. that software is on internet yet, nothing new or interesing.. but i want download newest soft and copy it on diskettes :)
