Mr Spatula #1 Posted January 28, 2011 Recently, i got an Atari 1040ST with the box, monitor, 2 different MIDI attachments, and tons of software and games. The first time i powered it on after i got it, it worked just fine. Then it crashed and gave me two bombs. So i restarted the system and got nothing but garbled lines and about eleven bombs. Now it wont do anything else. It doesn't even try to read the disk drive. I'm a complete noob when it comes to Atari systems, so any help is appreciated. Quote Share this post Link to post Share on other sites
svenski #2 Posted January 29, 2011 Recently, i got an Atari 1040ST with the box, monitor, 2 different MIDI attachments, and tons of software and games. The first time i powered it on after i got it, it worked just fine. Then it crashed and gave me two bombs. So i restarted the system and got nothing but garbled lines and about eleven bombs. Now it wont do anything else. It doesn't even try to read the disk drive. I'm a complete noob when it comes to Atari systems, so any help is appreciated. Does this happen when you turn on the ST without a disk in the drive? Quote Share this post Link to post Share on other sites
Mr Spatula #3 Posted January 29, 2011 Recently, i got an Atari 1040ST with the box, monitor, 2 different MIDI attachments, and tons of software and games. The first time i powered it on after i got it, it worked just fine. Then it crashed and gave me two bombs. So i restarted the system and got nothing but garbled lines and about eleven bombs. Now it wont do anything else. It doesn't even try to read the disk drive. I'm a complete noob when it comes to Atari systems, so any help is appreciated. Does this happen when you turn on the ST without a disk in the drive? Yes, but i have found the problem. Some kind of brown rot on the bottom of the mainboard. Quote Share this post Link to post Share on other sites
Mr Spatula #4 Posted January 30, 2011 Well, i cleaned it up, but it still doesn't work. Any Ideas? Quote Share this post Link to post Share on other sites
tjlazer #5 Posted January 30, 2011 Universal 4" atari drop. Or reseat all socketted chips. 1 Quote Share this post Link to post Share on other sites
+save2600 #6 Posted January 30, 2011 Or reseat all socketted chips. Quote Share this post Link to post Share on other sites
+DarkLord #7 Posted January 30, 2011 Universal 4" atari drop. Or reseat all socketted chips. 4"? Hmm, I always dropped mine from low-lying buildings, worked fine. Bonus points if you hit Amiga users on the way down. Quote Share this post Link to post Share on other sites
carmel_andrews #8 Posted January 30, 2011 Universal 4" atari drop. Or reseat all socketted chips. 4"? Hmm, I always dropped mine from low-lying buildings, worked fine. Bonus points if you hit Amiga users on the way down. Try it from Mt Everest or K2 next time Quote Share this post Link to post Share on other sites
Mr Spatula #9 Posted January 30, 2011 All chips have been reseated. Same problem Quote Share this post Link to post Share on other sites
+DarkLord #10 Posted January 30, 2011 All chips have been reseated. Same problem If you've reseated all the chips you can, checked and cleaned all connections, and you're using floppy's that you know are good, the next thing I'd be looking at is the power supply. Any chance you've got a known good unit you could swap out with? Quote Share this post Link to post Share on other sites
Mr Spatula #11 Posted January 30, 2011 All chips have been reseated. Same problem If you've reseated all the chips you can, checked and cleaned all connections, and you're using floppy's that you know are good, the next thing I'd be looking at is the power supply. Any chance you've got a known good unit you could swap out with? Unfortunatly, i don't. What's the voltage output of the power supply? Quote Share this post Link to post Share on other sites
carmel_andrews #12 Posted January 31, 2011 might be a bad ram chip somewhere Quote Share this post Link to post Share on other sites
