Sign in to follow this
w1k
interesting 130xe
hi, today i buy atari 130xe and it have interesting case
what is it? that its not connector there
Channel selector, normally only found on NTSC XL/XE machines, only 400/800 PAL machines had it.
Probably just a case of cases being either mixed up in production or not having any PAL ones available at the time.
If you have a good look, you can see that the connector for the TV is next to it.
The symbol over it shows that they belong together.
It's a switch to set the modulator to channel 2 or 3.
The channel select switch was dropped for PAL versions, that's why it is missing
If I remember correctly, my PAL XE had a small plastic cover in the channel selector hole.
Maybe the small cover fall out over time.
Robert
Edited by rdemming
