centaur2 #1 Posted February 4, 2011 Hello everyone, last summer I bought a SCART 7800 including the Peritel cable from France. The console does not deliver the kind of picture quality I am used to from other RGB enabled consoles like the Mega Drive etc. I have a lot of ghosting, both in 7800 and 2600 mode. Is the 7800 not capable of crystal clear picture quality or s there any way to improve the picture quality? I have already added some 220nF capacitors to the RGB pins and a 75 Ohm resistor to Sync, but this didn't change much. Thanks a lot Sebasian Quote Share this post Link to post Share on other sites
centaur2 #2 Posted February 5, 2011 Hi again, I made some pictures. Maybe ghosting is the wrong word, looks more like color bleeding. Thanks Sebastian Quote Share this post Link to post Share on other sites
Phredreeke #3 Posted February 5, 2011 I think it's because the 7800 generates Y/C internally, and converts it to RGB in a separate chip. Quote Share this post Link to post Share on other sites
centaur2 #4 Posted February 5, 2011 (edited) Thanks for your reply! Is there any way to improve the Y/C signal before it is converted to RGB? Are there any mods out there that provide a better picture than the one I already have? Cheers Sebastian Edited February 5, 2011 by centaur2 Quote Share this post Link to post Share on other sites
centaur2 #6 Posted February 5, 2011 Why should I use an emulator when I have the real thing at home? I am just looking to get the maximum picture quality I can get out of this machine. Quote Share this post Link to post Share on other sites
mimo #7 Posted February 9, 2011 sorry for my silly reply. I get that blue ghosting too, although a lot of it can be reduced by altering the settings on the TV. There are also 3 trim pots inside the 7800 that can be adjusted. I think the lower one on the piggy back board will reduce the blue. Be careful though, the trim pots are fairly fragile and most have been hot glued. Quote Share this post Link to post Share on other sites
Atari_Falcon #8 Posted February 9, 2011 I have the same effect with my scart machine, too... maybe will change to a video mod... Quote Share this post Link to post Share on other sites
centaur2 #9 Posted February 10, 2011 Thanks for the replies. I will try the trim pots. Good to know that this is not only a problem of my machine. I will give feedback after adjusting the trim pots. Quote Share this post Link to post Share on other sites
mimo #10 Posted February 10, 2011 Thanks for the replies. I will try the trim pots. Good to know that this is not only a problem of my machine. I will give feedback after adjusting the trim pots. Make sure you mark the original position of the pots. and just to add, a small movement can make a big difference Quote Share this post Link to post Share on other sites
centaur2 #11 Posted February 10, 2011 Too bad, I just tried adjustig the 2 trim pots, but they don't have any effect on the colours. Quote Share this post Link to post Share on other sites
mimo #12 Posted February 10, 2011 Too bad, I just tried adjustig the 2 trim pots, but they don't have any effect on the colours. there are 3, did you try the one on the piggy back board? Quote Share this post Link to post Share on other sites
centaur2 #13 Posted February 14, 2011 Too bad, I just tried adjustig the 2 trim pots, but they don't have any effect on the colours. there are 3, did you try the one on the piggy back board? Sadly, the 3rd trim didn't make any difference. It was not on the piggy back board, but above it on the mainboard. Quote Share this post Link to post Share on other sites
