Sign in to follow this
RSS Bot
jwierer's Blog - VisualbB Changes to support bB 1.1 Beta
Batari has started to release early versions of the bB1.1 compiler that includes support for the new DPC+ kernel. While this is likely to go through a number of language iterations, I started to add initial support for folks that want to start creating new sprites. You can read more about 1.1 from batari's blog.
Here are some of the changes in visualbB:
  • The most important change is that player data is stored right-side-up in the DPC+ kernel, so the sprite editor was modified. When you copy the color and sprite data will be right side up (upside down if run in the standard kernel).
  • Also the height in the editor will be viewed as half the height of the normal sprites.
  • New keywords are available in the intellisense editor.
http://www.atariage.com/forums/blog/302/entry-7888-visualbb-changes-to-support-bb-11-beta/
