Rybags #26 Posted October 12, 2018 There is a LOMEM command from Edit mode. You use it before commencing source programming or loading. The intention is so you can raise the MEMLO pointer so your object code can go between where DOS finishes (or $700 if no Dos) and the source code starts. It should be the first command entered before programming commences (ref ERROR 18 later in the article). Quote Share this post Link to post Share on other sites
