rhindlethereddragon #1 Posted February 27, 2011 I have an old copy of MAMED for Dreamcast and it works quite well, but some games are too large to fit the screen. For example, in Donkey Kong, the entire bottom rung is not visible. Is there any way to mitigate this? Quote Share this post Link to post Share on other sites
goldenegg #2 Posted February 27, 2011 It's been a while since I've used Mamed, so I'm not 100% sure this can be resolved. One thing I can recommend to check is that you're using the right version of Mamed for the games you're trying to play. For more info, check the following site: http://www.dcevolution.net/index.php?id=mamed EDIT: I just did some searching and found that Mame4All was ported to the Dreamcast. I'd definitely suggest checking that out, as it should (in theory) run better than Mamed. http://chui.dcemu.co.uk/mame4all.html Quote Share this post Link to post Share on other sites
