Miss 2600 #1 Posted February 27, 2011 I finally got a genuine Heavy Sixer! It came with heavy sixer style joysticks (never had these before), paddles (with the Atari logo), and grey power supply. I have a couple questions: The console plays fine, but the connector to the switch box looks corroded. It has black spots on it. Should I clean it and, if so, what should I use? The paddles work great! No jiggling at all! One of the joysticks doesn't work well, the other one works fine but squeaks (they both squeak). The rubber material on both joysticks has popped out. Is there a way to fix that? I see the openings the rubber pieces go into, but can't put them back together. The power adapter worked for a second and then the console lost power. I used my black power supply from my Sear Light Sixer and it worked fine. I actually bought another grey power adapter off eBay before buying this Heavy Sixer. I was regretting that since another one came with the Heavy Sixer, but I'm glad to have it now. 2 Quote Share this post Link to post Share on other sites
tz101 #2 Posted February 27, 2011 The console plays fine, but the connector to the switch box looks corroded. It has black spots on it. Should I clean it and, if so, what should I use? The rubber material on both joysticks has popped out. Is there a way to fix that? The power adapter worked for a second and then the console lost power. I used my black power supply from my Sear Light Sixer and it worked fine. The RF cable end can be shined up with steel wool if one so desires, but the black oxidized look should not really impede operation of the console. Best fix for the rubber stick boots is to take the joystick cases apart from the bottom by removing the screws. Then, just pop the rubber stick boots into the top casing from the bottom side. Afterward, just screw it all back together. The gray power adapter sounds like it has bit the dust. I had one like that and there is not much you can do. 1 Quote Share this post Link to post Share on other sites
fiddlepaddle #3 Posted February 27, 2011 I probably wouldn't bother since it works fine, but if you want to clean off the black spot, you can use a mild abrasive, like a pencil eraser or very fine grit sandpaper, and/or use "Caig De-Oxit" to make it conduct better and keep it from getting any worse. I've never messed with the original joysticks. Might take one apart and see if you can put it back together right. I don't think they are complicated...just a couple of screws. 1 Quote Share this post Link to post Share on other sites
Miss 2600 #4 Posted February 27, 2011 Best fix for the rubber stick boots is to take the joystick cases apart from the bottom by removing the screws. Then, just pop the rubber stick boots into the top casing from the bottom side. Afterward, just screw it all back together. The gray power adapter sounds like it has bit the dust. I had one like that and there is not much you can do. I never thought of taking it apart. Good idea. I'll probably try fixing the one that doesn't work well first and see how it goes. I'll probably keep using my "Top" style joysticks for regular playing. It is just nice to finally have a couple older style joysticks in my collection. 2 Quote Share this post Link to post Share on other sites
Miss 2600 #5 Posted February 28, 2011 Strange. I fiddled with the grey power supply (jiggling it, taking the plug out and putting it back in a few times--no bad jokes, please ) and now it is working. Maybe it needed to be woken up like an Activision cartridge. Anyway, this Heavy Sixer might become my main playing console as the power supply plug fits better. It is a tad loose on my Tele-games console and, once in a while, I'd be playing a game and the power will suddenly go out. Quote Share this post Link to post Share on other sites
accousticguitar #6 Posted February 28, 2011 I decided my heavy sixer gives the best picture of all my consoles. I still want to put a ferrite bead on it though. I asked a clerk at WalMart where the ferrite beads were and she directed me to the arts and crafts section. Quote Share this post Link to post Share on other sites
Miss 2600 #7 Posted February 28, 2011 How is "ferrite" pronounced? The way I'm pronouncing it, I'd probably take you to the pet care section Quote Share this post Link to post Share on other sites
accousticguitar #8 Posted February 28, 2011 fer ite. I just looked it up; I have been pronouncing it wrong. The pet care section it is! Quote Share this post Link to post Share on other sites
fiddlepaddle #9 Posted February 28, 2011 So ferrite beads are like mouse droppings? Quote Share this post Link to post Share on other sites
ScumSoft #10 Posted February 28, 2011 So ferrite beads are like mouse droppings? No, those taste like bonbons, these do not. Quote Share this post Link to post Share on other sites
Schizophretard #11 Posted February 28, 2011 (edited) You also always have the option to replace the cable. It unplugs from the inside. What serial number is it? Edit: I found the answer in the other thread. 69986H Edited February 28, 2011 by Schizophretard Quote Share this post Link to post Share on other sites
Benzman66 #12 Posted February 28, 2011 (edited) Let me know if you have any luck finding the ferrite beads at a big box retailer. I haven't been able to find them anywhere locally except the one mom and pop electronics store, that just closed up last month. I've been having to order them online; Ferrite Beads Edited February 28, 2011 by Benzman66 Quote Share this post Link to post Share on other sites
accousticguitar #13 Posted February 28, 2011 I haven't found any yet. The first place I looked was Radio Shack. Silly me. Quote Share this post Link to post Share on other sites
A.J. Franzman #14 Posted March 6, 2011 (edited) The power adapter worked for a second and then the console lost power.The gray power adapter sounds like it has bit the dust. I had one like that and there is not much you can do.That's not true. Other than a smashed case, wire break near the console plug or totally ruined cable, most DC adapter failures can be fixed. For a heavy sixer adapter, if necessary you could even replace the entire cable with one from a "standard" 2600 adapter, though it wouldn't look the same. I have repaired internal cable breaks near the wall block many times; and even replaced capacitors, diodes and a transformer or two inside the cubes. How is "ferrite" pronounced?I've never looked it up but I've laways pronounced it to rhyme with "airtight". Edited March 6, 2011 by A.J. Franzman 1 Quote Share this post Link to post Share on other sites
JacobZu7zu7 #15 Posted March 7, 2011 Anyway, this Heavy Sixer might become my main playing console as the power supply plug fits better. It is a tad loose on my Tele-games console and, once in a while, I'd be playing a game and the power will suddenly go out. Cool those heavy sixers have a DEEP cart slot don't they? It's like looking down a well. (bein' real I is, not dirty) I have the same problem with my light 6'er woodgrain. The power supply in the back of the system, cuts out. I have to turn it slightly and "push" to make sure enough power is going in. This is the original supply it came with too. Or could it be our consoles circuit board being iffy? Quote Share this post Link to post Share on other sites
eeun #16 Posted March 7, 2011 I have the same problem with my light 6'er woodgrain. The power supply in the back of the system, cuts out. I have to turn it slightly and "push" to make sure enough power is going in. This is the original supply it came with too. Or could it be our consoles circuit board being iffy? Just got myself a light sixer that was doing the same thing. Had the console apart anyway to clean off 30 years of dust, dirt and what I really hope was chocolate , and discovered the AC adapter connector solder points were all loose. 2 Quote Share this post Link to post Share on other sites
