w1k #1 Posted March 5, 2011 (edited) with sio2pc and APE? it is possible? or other program? thanks or how i can install R: handler? Edited March 5, 2011 by w1k Quote Share this post Link to post Share on other sites
+bf2k+ #2 Posted March 5, 2011 Yes you can. APE has a built-in Telnet client that you enable in the Ape R: section so you can load ICE-T, go to terminal mode, hit the <RETURN> key and you should see the APE outbound telnet menu. Then use a command like: OPEN bfbbs.no-ip.com to login to an internet bbs. Quote Share this post Link to post Share on other sites
w1k #3 Posted March 5, 2011 Yes you can. APE has a built-in Telnet client that you enable in the Ape R: section so you can load ICE-T, go to terminal mode, hit the <RETURN> key and you should see the APE outbound telnet menu. Then use a command like: OPEN bfbbs.no-ip.com to login to an internet bbs. I run APE, R: is ready, boot ice-t, but ice-t i cant continue, because not R: handler.. hm. i have 320kb ram, sio2pc in COM1 Quote Share this post Link to post Share on other sites
Marius #4 Posted March 5, 2011 Yes you can. APE has a built-in Telnet client that you enable in the Ape R: section so you can load ICE-T, go to terminal mode, hit the <RETURN> key and you should see the APE outbound telnet menu. Then use a command like: OPEN bfbbs.no-ip.com to login to an internet bbs. You need to run a RS232.COM or something like that handler first. The Atari does not have the R: handler by itself. Some Atari terminal programs (like bobterm) do download the R: handler from the sio device (like an 850, or in your case APE). ON the Ice-T disk there is something like boot850.hnd or so? That is probably a loadable binary file. Good luck M. Quote Share this post Link to post Share on other sites
w1k #5 Posted March 5, 2011 then i have some different ICE-T or what where i can find rs232.com? Quote Share this post Link to post Share on other sites
[email protected] #6 Posted March 5, 2011 then i have some different ICE-T or what where i can find rs232.com? Have some versions of ICE-T on my page ... Search for ICE-T and it has several handlers on there http://pokeysoft.no/games/atari/a8util.htm Quote Share this post Link to post Share on other sites
w1k #7 Posted March 5, 2011 (edited) thanks, thats it.. but now i run terminal and i cant typing.. when i run dialing and i want EDIT, then JJJJJJJJJJJJJJJJJJJJJJ.. jesus - on pc ON ATARI: R: device not found.. ok, in dos 2.5 i try load ATARI850.HND - nothing do.. :/ Edited March 5, 2011 by w1k Quote Share this post Link to post Share on other sites
+bf2k+ #8 Posted March 5, 2011 thanks, thats it.. but now i run terminal and i cant typing.. when i run dialing and i want EDIT, then JJJJJJJJJJJJJJJJJJJJJJ.. jesus - on pc ON ATARI: R: device not found.. ok, in dos 2.5 i try load ATARI850.HND - nothing do.. :/ My version is called ICET850.com and it beeps when you run it indicating that the handler is loaded. Quote Share this post Link to post Share on other sites
w1k #9 Posted March 5, 2011 (edited) http://www.youtube.com/watch?v=TudG0Eru9ys i listen then beep, then i push RESET, because system freeze and then: Edited March 5, 2011 by w1k Quote Share this post Link to post Share on other sites
w1k #10 Posted March 5, 2011 (edited) ok, i done it.. but ICE-T have problems with columns? strange.. text is overflowing Edited March 5, 2011 by w1k Quote Share this post Link to post Share on other sites
[email protected] #11 Posted March 6, 2011 (edited) Did you get it to work? I tried the Atari850.hnd and it works fine ... If you rename it to AUTORUN.SYS Edited March 6, 2011 by [email protected] Quote Share this post Link to post Share on other sites
w1k #12 Posted March 6, 2011 Did you get it to work? I tried the Atari850.hnd and it works fine ... If you rename it to AUTORUN.SYS yes, im works fine now Quote Share this post Link to post Share on other sites
w1k #13 Posted March 6, 2011 interesting.. i trying use 850.hnd like autorun.sys on contiki, or fujichat, but on that stuff i cant connect but ice-t is fine.. http://www.youtube.com/watch?v=T8tr6XDdX44 Quote Share this post Link to post Share on other sites
russg #14 Posted March 7, 2011 (edited) then i have some different ICE-T or what where i can find rs232.com? APE for Windows 3.0.6 registered comes with an already configured IceT .ATR. It's in C:\Program files\APE for Windows\Disk Images\ATR. I tried it and it works, no R: handler required. This is with a serial port SIO2PC. I guess do the server mode modem config. with your SIO2USB, I'm using client outbound only. OR... SIO2USB interface may require the R: handler. I don't see how a MIO would effect this, You aren't using the serial port on the MIO. Edited March 7, 2011 by russg Quote Share this post Link to post Share on other sites
+bf2k+ #15 Posted March 7, 2011 I tried it and it works, no R: handler required. This is with a serial port SIO2PC. I guess do the server mode modem config. with your SIO2USB, I'm using client outbound only. OR... SIO2USB interface may require the R: handler. I don't see how a MIO would effect this, You aren't using the serial port on the MIO. It works the same way with the Ape USB interface. But you have to un-assign the R: port in the MIO or it will not work. Quote Share this post Link to post Share on other sites
w1k #16 Posted March 7, 2011 (edited) hm, what about contiki and R: handler? can be work? Edited March 7, 2011 by w1k Quote Share this post Link to post Share on other sites
w1k #17 Posted March 13, 2011 bfbbs.no-ip.com is down? Quote Share this post Link to post Share on other sites
+bf2k+ #18 Posted March 13, 2011 bfbbs.no-ip.com is down? No... hit <Return> slowly to connect. Quote Share this post Link to post Share on other sites
OldAtarian #19 Posted March 14, 2011 hm, what about contiki and R: handler? can be work? Where do you get a version of Contiki that runs on the A8? I can't find it anywhere, or maybe I'm just not looking in the right place. Quote Share this post Link to post Share on other sites
Fox-1 / mnx #20 Posted March 15, 2011 Where do you get a version of Contiki that runs on the A8? I can't find it anywhere, or maybe I'm just not looking in the right place. Checked here? http://www.atari8ethernet.com/Download.html Quote Share this post Link to post Share on other sites
