Sign in to follow this
tz101
Qix
I refurbed a stock controller and centered the pots using Missile Command. All games work great except Qix. I know you have to push one of the fire button for slow draw, and the other fire button for quick draw. This worked fine when my cursor was on the bottom of the frame, but when I moved up to the top left corner, neither fire button would allow me to draw rectangles.
Has anyone seen this before and know of any suggestions?
getting a good center is step one
then you have to make sure you can hit all the corners in missile command and if you have gorf and star wars
also that you can go down the stairs in popeye and do good circles in gyruss
if you cant hit the corners in missile command you need to adjust the internal dial
when playing qix if you can go left and right and up and down i dont know why it wouldnt be working
try just running along the walls for a while
I understand, Missile Command, Popeye, and Gyruss, but what am I to do with Gorf and Star Wars as it pertains to adjusting the pots?
