Sign in to follow this
José Pereira
Gr.1 and Gr.2 bytes/cycles
Hi, me again and more of my doubts/questions:
-> Gr.1 and Gr.2 are Char Modes and they are 1byte=8pixels (2:1 ratio) and not like Gr.12/13 where 1byte=4pixels (2:1)
If I have in a 160wide, 20bytes wide the cycle screen lost would be normally like this:
--1st scanline of Charset: 20cycles(nº of byte per Line)+20cycles(20bytes Charset 1st scanline)+1cycle(refresh)+1cycle(DLI Charset initial)
--other scanlines: 20cycles(nº of bytes per Line)+9(refresh)
If logic applies here, because it consider each pixel(2:1/colour clock) as 1bit it would be half cycle lost VS ANTIC4 in Chars/bytes per Lines (but only one colour per Char, I know!...).
Am I thinking right?
José Pereira.
Edited by José Pereira
EDIT
I'm not sure, but AFAIK the 9 refresh cycles will only be cut down to 1 cycle in case of a real so-called "badline". The badline only occurs in Antic 2, 3, 4 and 5 textmodes: i.e. gr. 0, 0+, 12 and 13. During a gr.1 or 2 line, there's enough free cycles inbetween, so the 9 refresh cycles don't need to be cancelled/deactivated.
Edited by analmux
Thanks, but more than if it is 9or1 cycles for the refresh, most important for what I have in mind is to know if it is:
"20bytes(20chars wide) are 20cycles and not 40cycles like in an ANTIC4 charswide?"
José Pereira.
Only 1 Refresh in Gr. 0 badlines in Wide and Std modes. 3 in Narrow.
Another thing - text modes will always fetch the character bitmap data on both scanlines in the 2-pixel high modes (Gr. 2 and 13 )
