phaeron Posted April 30, 2011 Share Posted April 30, 2011 v0.4 works much better. Not only does Ilusia load fine now, but this also fixes a problem I just hit where v0.3 was giving 255 System Errors in a 128K configuration. Thanks! By the way, the ARC command apparently doesn't handle general SDX device paths and won't extract from PCL:. It thinks it's A: instead. Quote Link to comment Share on other sites More sharing options...
atarimac Posted April 30, 2011 Share Posted April 30, 2011 Yeah, I guess we know about the carts but the OP was specifically asking about emulators. Flashjazzcat was right BTW Atari800MacX does support pass through carts amongst its many other great features. The Atari800 emulator's latest release should have the dual cartridge feature also. I checked my Atari800MacX dual cart code in there about a year or so ago, and I think the team just did an updated release. Speaking of releases, this week was my last week of school for this semester, so if work allows, I should get around to releasing a Atari800MacX bug fix/maintenance release in the next week or two. Mark Quote Link to comment Share on other sites More sharing options...
drac030 Posted May 1, 2011 Author Share Posted May 1, 2011 By the way, the ARC command apparently doesn't handle general SDX device paths and won't extract from PCL:. It thinks it's A: instead. Exactly. It is one of the things on the todo list. Quote Link to comment Share on other sites More sharing options...
atx4us Posted May 2, 2011 Share Posted May 2, 2011 (edited) Yeah, I guess we know about the carts but the OP was specifically asking about emulators. Flashjazzcat was right BTW Atari800MacX does support pass through carts amongst its many other great features. The Atari800 emulator's latest release should have the dual cartridge feature also. I checked my Atari800MacX dual cart code in there about a year or so ago, and I think the team just did an updated release. Speaking of releases, this week was my last week of school for this semester, so if work allows, I should get around to releasing a Atari800MacX bug fix/maintenance release in the next week or two. Mark Mark, Thanks for letting us know about the dual cartridge support for Atari800 2.2.1. First, attach the "SDX443_intsdx128.car" cartridge image. Then, the "Insert SDX Piggyack Cartridge" will appear in the "Cartridge Management" menu. Choose this option to insert your piggy back cartridge. Nice! Hayden Edited May 2, 2011 by atx4us Quote Link to comment Share on other sites More sharing options...
HiassofT Posted May 5, 2011 Share Posted May 5, 2011 Hi! I just ran into an issue with the SDX formatter (format.com): If I send a percom block with a "floppy configuration" (i.e. one which has tracks/heads/sectors set, not a "hdd config" with just a single track), the format configuration (tracks/density) won't update to the percom block. If a "hdd config" is received, the number of sectors and density is displayed correctly and I can build a directory (formatting is unavailable then, of course). No big issue for standard "floppies" with <= 1440 sectors, I can just manually set these values. But it doesn't work for larger "floppies", for example 2880 QD sectors (80 tracks, 2 sides, 18 sectors of 512 bytes) or 5760 DD sectors (80 tracks, 2 sides, 36 sectors) as format.com won't let me choose more than 1440 sectors. If I build a directory it will create a VTOC with max. 1440 sectors - the remaining space is unavailable. Could you maybe change this so that format.com respects the values in the percom block and allows building a directory with tracks*sides*sectors total sectors? Even better: also allow formatting these drives (including drives with a "hdd config"), I support this in AtariSIO and it will blank-out the whole image (sometimes nice for testing stuff). so long, Hias Quote Link to comment Share on other sites More sharing options...
drac030 Posted May 7, 2011 Author Share Posted May 7, 2011 (edited) But it doesn't work for larger "floppies", for example 2880 QD sectors (80 tracks, 2 sides, 18 sectors of 512 bytes) or 5760 DD sectors (80 tracks, 2 sides, 36 sectors) as format.com won't let me choose more than 1440 sectors. If I build a directory it will create a VTOC with max. 1440 sectors - the remaining space is unavailable. Yes, the formatter has such a limitation. That's the way ICD wrote it. Could you maybe change this so that format.com respects the values in the percom block and allows building a directory with tracks*sides*sectors total sectors? Yes, I am planning to make the formatter do that and other things as well, so that it would become more flexible. This just requires time. Even better: also allow formatting these drives (including drives with a "hdd config"), I support this in AtariSIO and it will blank-out the whole image (sometimes nice for testing stuff). I don't think it is a good idea to even support the format command for such images, I even had to block this in SIO2BSD, as I once ended up with accidentally wiped out ATR image, when an "!" command intended for a real floppy drive was by my mistake also received by SIO2BSD. For real hard drives, physical formatting has no point either, and if you want to wipe the disk's content, a dedicated program is a much safer solution. Edited May 7, 2011 by drac030 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted May 8, 2011 Share Posted May 8, 2011 The ARCLOCK.SYS driver in 4.43 isn't working properly for me. I had no troubles with an older driver (which I've now mislaid but hopefully will be able to find again), but every time the machine cold-starts, the driver resets the clock. I had to add the /F switch in CONFIG.SYS, otherwise I just kept getting "No ARC Clock". It's easy to miss the "clock reset" message, too, and one tends not to notice that the clock isn't set until one has inadvertently created a lot of files will nonsense dates. It's rather frustrating, since Trub went to great lengths to get this driver to work properly. I even tested the betas, and I don't recall having any problems, although I do believe he made some change before the final version. Quote Link to comment Share on other sites More sharing options...
HiassofT Posted May 9, 2011 Share Posted May 9, 2011 Could you maybe change this so that format.com respects the values in the percom block and allows building a directory with tracks*sides*sectors total sectors? Yes, I am planning to make the formatter do that and other things as well, so that it would become more flexible. This just requires time. Thanks a lot! Even better: also allow formatting these drives (including drives with a "hdd config"), I support this in AtariSIO and it will blank-out the whole image (sometimes nice for testing stuff). I don't think it is a good idea to even support the format command for such images, I even had to block this in SIO2BSD, as I once ended up with accidentally wiped out ATR image, when an "!" command intended for a real floppy drive was by my mistake also received by SIO2BSD. For real hard drives, physical formatting has no point either, and if you want to wipe the disk's content, a dedicated program is a much safer solution. I never had the problem of a "mistakingly" received command frame with AtariSIO. As for real hard drives, well, wiping out 16MB would take quite some time and might not be too practicable with a maximum timeout of ~255 seconds. As for AtariSIO: everything's stored in RAM, so it's just a "delete[]" followed by a "new". Even if you accidentally wiped a drive you can still choose to not write back the data to your harddrive. And you have the big benefit that you can work with the drives just like real floppy drive - use DOS/Percom Block to configure it to 90k/130k/180k/16MB whatever, issue a format command and you have freshly allocated drive of your desired size so long, Hias Quote Link to comment Share on other sites More sharing options...
kurtm Posted May 9, 2011 Share Posted May 9, 2011 I never had the problem of a "mistakingly" received command frame with AtariSIO. As for real hard drives, well, wiping out 16MB would take quite some time and might not be too practicable with a maximum timeout of ~255 seconds. As for AtariSIO: everything's stored in RAM, so it's just a "delete[]" followed by a "new". Even if you accidentally wiped a drive you can still choose to not write back the data to your harddrive. And you have the big benefit that you can work with the drives just like real floppy drive - use DOS/Percom Block to configure it to 90k/130k/180k/16MB whatever, issue a format command and you have freshly allocated drive of your desired size so long, Hias This may be what Hias is saying, but here goes: What if the emulation devices did take a percom block and when you format, it just creates a new image of the spec? It would probably have to pick a new name itself (or we could have an exotic SIO command that sets the name). But that way, they won't blow away an image by mistake, but you also have a way to create new images from the atari itself. Thoughts? --Kurt Quote Link to comment Share on other sites More sharing options...
drac030 Posted May 9, 2011 Author Share Posted May 9, 2011 I never had the problem of a "mistakingly" received command frame with AtariSIO. Never so far, that is As for AtariSIO: everything's stored in RAM, so it's just a "delete[]" followed by a "new". Even if you accidentally wiped a drive you can still choose to not write back the data to your harddrive. For SIO emulators I still think that it is much safer to do that with some manual control, i.e. choosing options on the SIO emulator user panel/screen whatever. If you can block flushing the image contents to the disk, then you must be also able to wipe the image you select similar way. And you have the big benefit that you can work with the drives just like real floppy drive - use DOS/Percom Block to configure it to 90k/130k/180k/16MB whatever, issue a format command and you have freshly allocated drive of your desired size Not exactly. The SDX disk formatter allows to configure floppies (either real or emulated) and format them to a variety of formats. I agree that the variety is, maybe, not varied enough and the flexibility of the formatter's menu is to be enhanced (and it will be enhanced in some future), but at the other hand it allows you to format disks to 90/130/180/250/360/500/720/1000/1440k, which is a set of formats sufficient for most needs, isn't it. There is however one exception, the disks which identify itself as "hard disks" (trk == 1) cannot be formatted. And I think it is reasonable, because: 1) real floppies do not return such PERCOM blocks 2) real hard drives do not need such formatting (partition wiping and resizing is done by dedicated software) So the only real purpose of this change would be emulator support, and that's what we don't do. Despite that I think that it is actually good thing, if the device is able to tell the DOS in advance (i.e. before a format command is sent over the bus) that it does not wish to be formatted. Quote Link to comment Share on other sites More sharing options...
HiassofT Posted May 9, 2011 Share Posted May 9, 2011 Hi! And you have the big benefit that you can work with the drives just like real floppy drive - use DOS/Percom Block to configure it to 90k/130k/180k/16MB whatever, issue a format command and you have freshly allocated drive of your desired size Not exactly. The SDX disk formatter allows to configure floppies (either real or emulated) and format them to a variety of formats. I agree that the variety is, maybe, not varied enough and the flexibility of the formatter's menu is to be enhanced (and it will be enhanced in some future), but at the other hand it allows you to format disks to 90/130/180/250/360/500/720/1000/1440k, which is a set of formats sufficient for most needs, isn't it. There is however one exception, the disks which identify itself as "hard disks" (trk == 1) cannot be formatted. And I think it is reasonable, because: 1) real floppies do not return such PERCOM blocks 2) real hard drives do not need such formatting (partition wiping and resizing is done by dedicated software) So the only real purpose of this change would be emulator support, and that's what we don't do. Despite that I think that it is actually good thing, if the device is able to tell the DOS in advance (i.e. before a format command is sent over the bus) that it does not wish to be formatted. I have no problem with it, just wanted to suggest something which MyDos supports for ages and what I think to be a really nice feature. so long, Hias Quote Link to comment Share on other sites More sharing options...
drac030 Posted May 9, 2011 Author Share Posted May 9, 2011 I have no problem with it, just wanted to suggest something which MyDos supports for ages and what I think to be a really nice feature. I know that MyDOS' behaviour (sending PERCOM block to "high-capacity" drives, apparently in order to resize them) and I consider it useless. So we don't agree in this point. Quote Link to comment Share on other sites More sharing options...
HiassofT Posted May 9, 2011 Share Posted May 9, 2011 I know that MyDOS' behaviour (sending PERCOM block to "high-capacity" drives, apparently in order to resize them) and I consider it useless. So we don't agree in this point. OK, I'm fine with that! so long, Hias Quote Link to comment Share on other sites More sharing options...
Keatah Posted May 24, 2011 Share Posted May 24, 2011 (edited) With the original website for SpartaDOS X 4.43, where can I get this nowadays? I'm looking to use it with Altirra 1.9. All searches seem to return outdated links, which is what frakking google seems best at nowadays. Either that, or non-relevant links. Edited May 24, 2011 by Keatah Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted May 24, 2011 Share Posted May 24, 2011 Try post #1 of this Thread... Quote Link to comment Share on other sites More sharing options...
Keatah Posted May 24, 2011 Share Posted May 24, 2011 (edited) Try post #1 of this Thread... Tried that, -- http://sdx.atari8.info/ -- 1st thing I did. Seems to be down or not accessible by my IP, never ever had that issue though. Is that page working for you? Because if so, then it is an ip provider problem and I can mess with a proxy then. --update-- seems a proxy says it's dead too. Edited May 24, 2011 by Keatah Quote Link to comment Share on other sites More sharing options...
spookt Posted May 24, 2011 Share Posted May 24, 2011 There's another thread floating around about this but I threw the zip file of 443 images which I grabbed at the weekend up to my web space: http://www.sixtimesnine.net/paul/SDX443_images.zip I can put the manual up there too if anyone needs it. Not sure if I have the latest extentions disk but I can look. Hopefully the official site will be back soon. Quote Link to comment Share on other sites More sharing options...
