jindroush #1 Posted December 20, 2002 Hi, how to make RGB cable for Commodore 1084S monitor? There is DSub9 connector on the back side. I need to know: 1) Can join all video grounds together ? No problem with it? (also for standard scart cable) 2) Should the monitor be in ANALOG or DIGITAL mode (I assume ANALOG) 3) Which sync signal to use and between which pins it should be connected? I have descriptions of all connectors, I just don't know which sync to use... Quote Share this post Link to post Share on other sites
+Mitch #2 Posted December 20, 2002 Hi, how to make RGB cable for Commodore 1084S monitor? There is DSub9 connector on the back side. I need to know: 1) Can join all video grounds together ? No problem with it? (also for standard scart cable) 2) Should the monitor be in ANALOG or DIGITAL mode (I assume ANALOG) 3) Which sync signal to use and between which pins it should be connected? I have descriptions of all connectors, I just don't know which sync to use... 1) Yes 2) Analog 3) I can't remember. I'll look it up tomorrow if someone else hasn't answered it by then. Mitch http://atari7800.atari.org Quote Share this post Link to post Share on other sites
+Mitch #3 Posted December 22, 2002 3) Use composite sync. Mitch http://atari7800.atari.org Quote Share this post Link to post Share on other sites
patters98 #4 Posted January 14, 2003 I made an RGB SCART to 9pin D connector cable for my Philips CM833MkII monitor and it works fine. I did it ages ago for my PlayStation so if you're still having problems I could open it up and check out the pin assignment. Quote Share this post Link to post Share on other sites
