omgaz
CV garbled start screen a couple of questions
I have a CV that I have been meaning to fix for a long time -- and its finally time. It has always had the garbled screen on boot. If I put a cart in, it does appear to play the game(audio and movement on screen), however I cannot make anything out. The power supply has the correct voltages. I disassembled the power switch, cleaned and greased it and no change. I suspect the video ram is on its way out. I was probing around with a multimeter and when I check for resistance on pin 11 of the bottom right memory chip, the missing letters in colecovision appear and almost everything else goes out on the screen. Because of this I think I am going to replace them all with the 4161 chips and sockets.
Are these the correct chips?
eBay Auction -- Item Number: 1806130816231?ff3=2&pub=5574883395&toolid=10001&campid=5336500554&customid=&item=180613081623&mpt=[CACHEBUSTER]
Does it sound like i'm on the right path to getting this fixed?
pic of boot screen
pic of boot screen
You said 4161, it's 4164...however your link is right and I have purchased from that Ebay seller and she is top notch. Now the bad news. I doubt you have bad DRAM(S), so replacing them will likely not solve your problem. Also you can't check a resistor "in circuit" accurately with a multimeter, you need to desolder one side to check it. I also highly doubt that you have a bad resistor. If I where going to blindly guess on an IC swap, I would say the VDP. Unless you are extremely skilled in soldering, attempting to replace a VDP without damaging the PCB is highly unlikely. There are however other things that can cause video problems and diagnosing via a forum is pretty much an act in futility. Aside from refurbishing the power switch, repairing a ColecoVision is a lot more involved than a Google search and a soldering iron.
Hmmm well thats not what i was hoping to hear. Is there any way to narrow it down further as to what the problem is? I am not that skilled at soldering, however I have replaced 40 pin ICs before with success and this one looks no different. Is there a way to test the VDP?
I bought a logic probe and it appears the memory is OK. Is there a way to test the 9928 chip with a logic probe? Because I a can't seem to find any help/documentation on the internets i am going to replace the 9928 chip. If that doesnt work i guess it'll go in the closet for another 10 years.
