AtariGeezer #1 Posted May 1, 2011 Today I was testing an 835 modem with the SIO2SD connected and 835 made a weird noise. Afterward the LCD display on the SIO2SD came up with a row of blocks on the top line, and only the green LCD lights up... Can I reflash the atmel chip from the six pin connections on board? If so, How do I wire it up to an LPT Port? Or how can I get a new programmed Atmel for it? Thanks, Jay Quote Share this post Link to post Share on other sites
sloopy #2 Posted May 1, 2011 stk-200 cable, third schematic down... http://my.opera.com/CrazyTerabyte/blog/2007/10/26/first-contact-with-atmega8-microcontroller-part-2 sloopy. Quote Share this post Link to post Share on other sites
AtariGeezer #3 Posted May 1, 2011 stk-200 cable, third schematic down... http://my.opera.com/CrazyTerabyte/blog/2007/10/26/first-contact-with-atmega8-microcontroller-part-2 sloopy. Thank you I'll run down to the parts store tomorrow and get the 6-pin header and make a cable... Quote Share this post Link to post Share on other sites
AtariGeezer #4 Posted May 2, 2011 Next Question: What program is used in that configuration? AVRprgWin's docs says to use different pins on the LPT port for SCK snd Reset... Quote Share this post Link to post Share on other sites
AtariGeezer #5 Posted May 2, 2011 (edited) or should I use this one from This Thread instesd for AVRprgWin? Thanks again, Jay Edited May 2, 2011 by AtariGeezer Quote Share this post Link to post Share on other sites
flashjazzcat #6 Posted May 2, 2011 I'd say if you use the diagram I posted in Post #2 and the software I also posted, you'll have no problems. The crystal and +5v supply are unnecessary, since the power and timing will come from the SIO2SD itself when you're flashing it. Quote Share this post Link to post Share on other sites
Rybags #7 Posted May 2, 2011 What's the exact model PIC used in SIO2SD (I don't feel like pulling my LCD off again) ? It's almost looking like worth being buying a spare then programming it and having it stored away in case anything goes wrong. Quote Share this post Link to post Share on other sites
flashjazzcat #8 Posted May 2, 2011 ATMEGA32 16PU 0934D ...is what it say on the chip I have here. Quote Share this post Link to post Share on other sites
AtariGeezer #9 Posted May 2, 2011 I'd say if you use the diagram I posted in Post #2 and the software I also posted, you'll have no problems. The crystal and +5v supply are unnecessary, since the power and timing will come from the SIO2SD itself when you're flashing it. Thank you for the clarification FJC Quote Share this post Link to post Share on other sites
AtariGeezer #10 Posted May 2, 2011 Woo Hoo!!! Got my SIO2SD back up and running with v3.0rc5, also set the Fusebits to (H: 0xC3, L: 0x3F)... Thanks again for the help... Quote Share this post Link to post Share on other sites
c0nsumer #11 Posted August 4, 2011 For what it's worth, I really, really, really like the Atmel AVR Dragon as a do-all programmer. It's now supported by avrdude so I can use it from OS X without issue. I've got a bit about mine and the DIP40 ZIF socket that I fitted it with here. (This is the device that I used for flashing the SDrive NUXX AVRs via HVPP mode.) Quote Share this post Link to post Share on other sites
