GeneralMurdock
Atari Jaguar Box Template
I believe everybody knows that there are templates for atari 2600 (so it will work for 5200 and 7800) but I can't find a template for atari jaguar.
I want to replace some of my boxes and I got the art from this site and thecoverproject site.
All I need now is a template with the right measures.
I tried it with a n64 box, because the difference is just the side the upper and lower part come from. In atari jaguar it comes from the front and in n64 it comes from the back.
The size is just the same.
So is there any atari jaguar box template around ?
Yes there is [url="http://www.u-235.co.uk/downloads/files/Jaguar_Artwork/"]Jaguar Artwork[/url] in the Cartridge Box directory.
Hope that's what you are after.
[quote name='Jag_Slave' timestamp='1304871853' post='2275797']
U-235? Are they new, or an old group that hasnt done anything in awhile? Just curious...
[/quote]
I founded it in 2003, alas never really started anything much. Not the case currently tho :)
[quote name='GeneralMurdock' timestamp='1305234885' post='2278746']
It's almost like that.
I was hopping for something to print in two A4 paper to replace my damaged boxes.
[/quote]
Perhaps the best bet would be to open out one of your boxes and scan it on an A4 scanner, and build your own template from that. Maybe useful for others out there that want to do similar. The only template I have is that one, the official Atari one, sorry.
Good luck
Well, atari jaguar boxes has the same size the N64. The only difference is the side the upper and botton flaps comes out.
In the N64 it comes from the back and in the jaguar it comes from the front.
I've tried to modify my 64 template but the size mismatched don't know why:(
I measured the old boxes by hand. They fit perfectly fine on (11inchx17inch) paper. Unless that template is the wrong size, or you're scaling it somehow, the template has plenty of room on 11x17.
Hope that helps! I have a template that works if you cant get yours working :D
And on that note, Im confusing what box you are referring to.
The cart boxes will fit on 11x17 paper...
As far as making a box for the whole Jaguar system, you will have to get that custom printed at a shop because it's a large format print.
Usually what I do is have them print on vinyl, and then have them glue the vinyl to card stock. Its the same as the stickers they use to put on vans, trucks, etc...
But I suggest you do what they recommend to you.
For one box, I would be willing to guess if its only a small order (1-5 box templates), you are looking at 30-40 bucks per print depending on where you go.
Keep in mind Im used to getting my student discount, for doing graphic design. So prices will vary ALOT.
Hope this helps.
I almost started a new thread, but it seems more appropriate here.
Songbird asked me to make a 6MB badge in the style of other labels, such as "1-2 players". Below is the 300 DPI graphic for any who may find it useful:
Yes there is Jaguar Artwork in the Cartridge Box directory.
Thanks for access to the template! A great resource.
Two takeaways here... the logo looks awesome, and...
"Songbird asked me to make a 6mb logo..."
... this also means good things to come! :)
