ScumSoft
EggVenture
EggVenture
Thanks to ZPH for getting me back here.
The game is now back in active development.
For now here is the OLDER V2 build of the game.
Instructions: There are none! it's an unforgiving adventure game of trial and error.
Hint: Be sure to return the sword to the castle after slaying the spider.
Left Difficulty switch to (B) puts the game in EASY..er mode. Take your time and have fun completing the game. But your still going to die, a lot.
Left Difficulty switch to (A) puts the game in PRO mode. Basically your going to die, and lose...a lot!
Press fire to flap, touch anything and die.
Press down to dookie on things, Arrows...heads...
Left/Right controls Cluck.
Go save your EGGs! and good luck. If you rescue all 8 eggs you will be treated to an ending sequence.
EggVenture 2600 (V3) is being fixed up, lot's of bugs were introduced in the remake.
Attached version is dated 7/12/2011
Known game breaker bug: If you die after receiving the sword but before collecting it, you cannot complete the game and will need to restart, be sure to not die at this time!
EggVenture_NTSC_V2.bin
Edited by ScumSoft
I'm Back!
  • Like 8
rem -hit the pad to hard and you bounce off wasting fuel trying to land
I think that should be "hit the pad too hard".
I like the title screen, but I haven't tried the game.
They better be nice, they are modified based on your LEMs physics code. Which of course I will credit once a credit page it done for it :)
Very modified!
I really like the way your character moves!
My L.E.M. for Atari 8-bit computers has physics, VCS version hasn't physics!
But I am happy if my program in some way has inspired you!
Yep, I've learned a bit from your code. Didn't know bB supported floats till I saw your source and then looked it up on Random Terrains site. It's a learning experience for sure. Game design isn't my forte but I've always wanted to do this, so I'm working diligently on completing this game before the month ends.
It can be done! I think :) been pulling all nighters lately. Seeing the sun rise was a rare thing for me you know.
Really solid start ScumSoft!
To throw a few ideas out there, maybe you could have the playfield be always destructive, with your goal being to rescue a chick that's walking back and forth on part of the level.
The chick would only grab hold if he's nearby and you're hovering near his level. Once he's onboard, you need to take-off again.
There might even be multiple chicks, ala Flicky, which would make navigating the ascent even harder, though they might flicker a bit.
The other players might be used as roving enemies or dynamic parts of the playfield.
Neat idea, I might be able to do level based mini-games ala Wario Ware style instead of focusing on landing pad repetition.
I'll see what I can come up with. But for now my coding day has ended and it is time for some sleep. I'll cya in a couple hours or so.
Latest build posted, all game mechanics are in place and playable albeit buggy in some situations.
Still doesn't work on the harmony for whatever reason. Anyone have ideas what might be causing this?
I gave it a run-through. Some observations...
  • I like the "bacock" graphic. Nice touch!
  • The titlescreen shading is nice.
  • The score seems to get messed up at certain values.
  • On the level with upper and lower paths to the landing pad, the chicken seems to float up on it's own when you start.
I'll take a look at the DPC bouncing tonight. I tried the first bB DPC beta and it ran smooth in harmony, but I haven't tried the second beta on real hardware... it's possible your scanline bounce is an issue with the beta itself.
I reversed the gravity on that level for a different touch, it may or may not appeal to many though.
It's odd, since none of the binaries I've posted worked on my harmony. I've tried many different DFxFRACDATA values for the playfield and different playfield heights, but they all bounced. I'm sure it's most likely some oversight of mine.
Thanks for helping me test.
It's not a bad idea, but there should be some sign that something is different... an upside down chicken or inverted colors or glowing purple walls or whatever.
Another spitball idea - you could have stuff that effects sideways velocity too, like the electric fans in Bubble Ghost.
Not at all - I reproduced it with very simple code, and the first beta definitely wasn't doing that.
I submitted the bug report, so for now just stick to Stella.
Ok found a workaround for the bug, you just update the DFxFRACINC pointers every frame and it won't bounce.
[edit] Batari fixed this in his latest release.
Edited by ScumSoft
I played for a while, and I'll be playing it again. This is very interesting! :thumbsup:
Some of the screens, like the castle, have a very thin bit of playfield at the bottom - to the beginner it's not entirely obvious if those are barriers or not until they kill you.
Phil, from ScumSoft's description it sounds like a DPC+ issue, so I'm not going to be able to be a great help. I'd raise it with batari... the fact that Stella differs from Harmony makes it sound like either a bug or some undocumented behavior.
The issue:
Player sprites start to get erased or misaligned.
Score color changes to a random color, mostly purple.
Background changes to same shade as score color.
My pointers are set as such:
DF0FRACINC = 32
DF1FRACINC = 32
DF2FRACINC = 32
DF3FRACINC = 32
DF4FRACINC = 64
DF6FRACINC = 64
Playfield size = 23 lines, 22 causes graphic artifacts in the score region, 23 seems to fit okay though, but there is that slim playfield line right above the score region.
Also at the top right of the screen.
PlayfieldColor and bkcolors tables are set to 23 bytes.
I make any changes to the pointers and things go wonky, this looks the most stable. I might just have everything set incorrectly. Close but no cigar. Stella seems to handle the pointers differently.
Scorecolor is missing for current release (waiting for fix from batari in next release), so I set the bkcolors all to $00 except byte 23 which falls in the score region, and reflects the difficulty setting.
Green = easy, Blue = hard
Edited by ScumSoft
the concept is very good!!! yet a bit difficult for me. I only regret to crash even I'm flying at very low speed. I've tested it on my 7800 pal and all color are blue but its still playable. :)
I'll do the conversion now before final release, so I can launch both versions at the same time once done.
Is there a PAL limitation in batariBasic? Setting the kernel to PAL doesn't position the score at the bottom of the screen and it still only produces 262 scanlines.
DPC+ support only for NTSC right now?
@abaudrand
This is something I've debated at length about, and I've decided due to the bugs collision against the playfield would cause that it's best if colliding simply kills the player instead of bouncing off the walls at low velocities. You can though safely bounce in your Home Tree.
Mostly because the player at max velocity is moving 2 pixels at a time, the player embeds themselves into the playfield far enough that my collision code would cause the player position to float through the playfield, thus causing issues on screen wrapping. Also allowing the player to gather the final egg before your supposed to be able to.
[edit]
Okay I posted a PAL version, but it is stuck to 262 scanlines right now.
Edited by ScumSoft
Yes, I believe the bB DPC+ kernel is NTSC/PAL60 only at the moment.
I think PAL60 is good enough for most people with PAL sets. If you decide to go regular PAL your titlescreen will look more flickery and you'll need to adjust the internal speeds all around. (or let the game play at 83% of the NTSC speed)
In my second session I finished the game, though my score was pretty low - damned bat!
