SlowCoder
Benefit to keeping my 2600 4-switchers?
I got them to stay there. It is AV modded and this just made the picture that much better.
And those lifted pins, one of them is +5V and one is data input/output I think. It's amazing that it works with them out of it!
Good! I'd put a small piece of electrical tape over the resistor before the shield. :ponder:
That is weird in that one deck I have. I've never done that to a system and I've been itching to try putting the pins in correctly.
Maybe I'll try tonight and see.
would this resistor mod be needed if you are doing a composite/s-video mod?
It's not necessary, but helps. Most av mods I've seen are slightly darker picture so it can only benefit you. IMO
Awesome thanks for the tip! I can't wait to do my 3 Mods to my Atari 2600!!! Its gonna look amazing! I'll start a new thred once its finished so everyone can see the awesomeness. :-)
Later on, I was going to do a screenshot from a board without the resistor and one with for comparison.
Update: I did put the pins from the TIA on that Rev12 board back in and no ill effects. I had to try, it was bugging me. ;)
A comparision screenshot would be awesome! Maybe one of it actually in use too...to show the picture quality difference?
I've started a game on each of 4 systems set properly: L6er sunnyvale, 4sw Rev 12 no resistor, 4sw Rev 13 no resistor, 4sw Rev 16 with resistor. Space invaders provides a good example. Note the shading on barriers and borders, also the difference in score color. These were all shot with the same camera on the same TV using same cart, power cord, tv switch, and camera settings.
If you use the 6er as a baseline, the Rev 12 looks washed out, the Rev 13 looks slightly better, and Rev 16 is almost spot on.
Edited by zylon
Now here's 2 of Kaboom on the same L6er unit before and after and AV mod. I switched to Kaboom because it's a good one to show the change from RF to AV and these 2 are old shots from when I did the work. ;)
Notice how the darker colors got darker and the light ones got lighter. Without adding the resistor(if system doesn't already have it), the differences would be even further apart. The AV does add much to the sharpness and clarity which can be seen on the mad bomber.
Edited by zylon
Before even reading your description of the Invaders screens, I was thinking I liked the upper left (H6) and lower right ones the best. :) Great job.
Thanks. :) The woody 4sw have about a 50-50 on having the mod already installed. Rev 14 has it but 12's and 13's usually don't. Vaders have Rev 14 through 18 and always have it. Rev 17+18 don't have socketed chips though. :( Of note: all Sears 4sw seem to have Rev 14 with the mod installed.
You preferred my tester 6er and my vader then. :thumbsup:
Zylon: Excellent job on the pics! :thumbsup:
Also, how do you know which revision the board is?
To sum things up...the only revisions you would need to do this mod to are: 9, 12, & 13?
Thanks!!!
Of course. :thumbsup:
and my vader then
Dang. :roll:
I knew you'd crack ;) :P In the end, it still proves 6ers are somewhat better video-wise. At least for my applications anyway. Don't knock the vaders that much, they're my best sellers. ;)
Thanks!!!
It will show which Rev# the board is just above the cart slot and near left control port.
The best ones to start with for modding are Rev 14 early and late + Rev 16. :)
The later ones are a lot harder and the earlier ones require a bit more work, but still doable. I've modded quite a few 14's and 16's years ago. :)
In general, all lower revisions than 14 need it if doing av mod. :!:
In that case, I know you wish you had my Vader H6.
I'm not really knocking the Vader. I've just found I really prefer the 6's to the 4's, aesthetics-wise. But that's just personal opinion, as I think the quality is about the same any way you look at it.
I prefer the L6ers myself. :) Probably since that's what still have from back in way-back ;) . Otherwise, I prefer the more solid port mounting and all switches on front as 6ers have. I sell lots of 4's and sometimes H6ers because they sell. The 4's usually need far less work so I don't have as much $ into them. :) That said, I keep one of each style for collection and one spare as insurance, and they're great for mod projects ;)
Zylon: Awesome thanks!!!
Also stay tuned cos after I finish my Atari 2600 mods I'll post pics of before, during, and after pics for you all to see!
Additionally, I was thinking couldn't you add a POT across pin 6 and 9 on the TIA and adjust it until the picture comes in the clearest? our could you damage the TIA chip by too low or too high resistance?
IMO too high a resistance shouldn't hurt a thing, too low might. That's a ? for those a bit more technical than me.
If you REALLY want to see the difference between the resistor and one without, try the pac man cart. The blue background is quite awesome.
As far as the pot, I wouldn't do it, but you could always go up or down a little on the resistor number.
Here is my AV modded 4 switch with the resistors on 6 and 9 compared to an unmodified heavy sixer
Bank Heist looks way better on the heavy sixer, and pac-man looks better on it too, it is not as dark and has the proper colors.
You can adjust the color wheel (white/green/or blue depending on the model) near the power regulator a little to get the colors closer matched, but you are never going to get it as perfect as the sixer units.
Edited by Benzman66
Agreed. :thumbsup:
Closest I was able to get for my demo shots was on the vader board. That was a real tight adjustment. The other 2 were hopelessly outmatched.
I got one for ya Benzman, what is the purpose of these 2 pins on TIA left out on this Rev 12 4sw board? I know for a fact that this was factory since this deck was bought new by a friend of mine's parents and they never opened it. I've left it alone since it works, but this is the only one I've ever seen like this. :ponder:
That's highly unusual. Perhaps certain odd or "rare" games won't work correctly. It's also strange a consumer product would be modded that way at the factory.
