tz101 #1 Posted June 21, 2011 I bought a N64 console for $2 at a yard sale. Hooked it up last night and it played great on several game cartridges. Went away for about 1/2 hour and now nothing. The power-on LED does not light at all, and no signal via RFU to my TV. Any ideas? Quote Share this post Link to post Share on other sites
bigbee99 #2 Posted June 22, 2011 I bought a N64 console for $2 at a yard sale. Hooked it up last night and it played great on several game cartridges. Went away for about 1/2 hour and now nothing. The power-on LED does not light at all, and no signal via RFU to my TV. Any ideas? Sounds like a power problem to me. Test your power supply. I would say use a multimeter but the pinouts on the n64 PSU are very small. I cannot get my leads into them. Maybe a friend near you has a working system that you could use for a day to mix up the cords to find the problem. That would beat buying a working PSU for a system that may be faulty. On a side note, I had the same problem with a Sega Genesis I picked up at a thrift store. When I opened the unit I found that the LED was busted. I replaced it (with a Green LED ) and it worked just fine. You need a security bit to open the n64 though. B Quote Share this post Link to post Share on other sites
A_Locomotive #3 Posted June 22, 2011 I would say use a multimeter but the pinouts on the n64 PSU are very small. I cannot get my leads into them. T-pins and alligator clips to hold them. Oh and something to prevent them from touching. Quote Share this post Link to post Share on other sites
tz101 #4 Posted June 22, 2011 There are about 5 different pins on the N64 power adapter. I need to know which one is ground and the expected voltages of the various hot leads before testing. Quote Share this post Link to post Share on other sites
tz101 #5 Posted June 22, 2011 (edited) Does the N64 have an internal fuse that goes out ala the SNES console? If so, then maybe it is as easy as replacing that fuse. I just need someone to post a pic of where the fuse is on the N64 main board. Edited June 22, 2011 by tz101 Quote Share this post Link to post Share on other sites
bigbee99 #6 Posted June 22, 2011 |123| |456| ----- 1,4,5 = ground 6 = 12V DC 0.8A 2,3 = 3.3V DC 2.7A I would go check my PSU but like I said, I cannot get the ends of my leads to get deep enough into it to make connections with the pins. It's a small hole. As far as the fuse, I am not sure. I'd have to open one of mine and have a look. B Quote Share this post Link to post Share on other sites
nathanallan #7 Posted June 22, 2011 |123| |456| ----- 1,4,5 = ground 6 = 12V DC 0.8A 2,3 = 3.3V DC 2.7A I would go check my PSU but like I said, I cannot get the ends of my leads to get deep enough into it to make connections with the pins. It's a small hole. As far as the fuse, I am not sure. I'd have to open one of mine and have a look. B carefully you can use paperclips as suggested to check it. Quote Share this post Link to post Share on other sites
bigbee99 #8 Posted June 22, 2011 AHhhh. Now I get it! Worth a try I guess. B Quote Share this post Link to post Share on other sites
