Sign in to follow this
Larry
ATR Header?
Here is info from Nick Kennedy's SIO2PC docs about the ATR header:
"WORD = special code* indicating this is an Atari disk file
WORD = size of this disk image, in paragraphs (size/16)
WORD = sector size. (128 or 256) bytes/sector
WORD = high part of size, in paragraphs (added by REV 3.00)"
I am not familiar with "paragraphs". If I try to use the typical (low byte + high byte x 256) /16 then I end up with 718.5. (?)
Does anyone know how to correctly decipher these "size" numbers (including the "extra" word added by "REV 3.00") ?
Thanks,
Larry
The size is counted in "16 byte increments", aka paragraphs. For example, 256 bytes = 16 paragraphs. 1024 paragraphs = 16x1024 = 16384 bytes.
Edited by drac030
Thanks for the paragraph information, Konrad.
I think that I've also determined why the "size" doesn't come up to 720 (with my calculation) -- it would be off by exactly the 3 "single density" boot sectors.
If I nail this down, I'll re-post. Google referenced several related posts in the past, but I saw none that really answered my query.
Edit:
Yes, that's it! A SD disk/image should contain 720 * 128 = 92160 bytes.
a 90K ATR header shows a "word" value of 128, 22
That would be 22*256 + 128 = 5760 "paragraphs"
5760 * 16 = 92160 bytes.
Thanks, again!
-Larry
Hello Larry,
do you still use version 3.00 of SIO2PC ?? Remember, this version has a bug, it produces enhanced density ATR`s with a length of 140kbytes (143,xxx Bytes), so better use a newer version like 4.1x or 4.2x. If you try to copy/download such a 140k ATR with a Sectorcopy program, most of the time the copy program will recognize it as SD/90k, so you have problem there... (which I solved with MyCopier 1.c and setting the "E"nhanced density switch to "on")...
-Andreas Koch.
Edited by CharlieChaplin
Hi Andreas-
Thanks, but I don't use SIO2PC -- just Win APE. However Nick's SIO2PC docs explain the header slightly better than Steve Tucker's Disk Image FAQ's, so I quoted from Nick (verbatim). I don't think that I'd ever heard of the "paragraph" term before.
-Larry
Hello Larry,
-Andreas Koch.
A 180K double-density disk is off by three sectors of 128 bytes because the first three sectors are ALWAYS 128 bytes, even in double-density. This is because the disk boot process loads three sectors assumed to be 128 bytes each. Double-density disks store the data as 256 bytes sectors, but the control board only returns half the sector data for the first three sectors.
