DarkLord
Connector search
Hi gang. I need help finding a connector.
Specifically, 2.54mm pitch, single inline sockets, 10 count and
30 count.
I've ordered from 3 different sites so far, Jameco, Global, and
Uni something or the other...
All 3 parts from these places match perfectly as far as the spacing
between pins, the problem is, the pins themselves are just too small
to fit the header. You can push them in, but they are so loose they
fall right back out.
Here is an example of what I ordered:
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&productId=78642&catalogId=10001&freeText=78642&app.products.maxperpage=15&storeId=10001&refine=1&history=lnlzkog0%7CsubCategoryName%7EInterconnects%5Ecategory%7E30%5EcategoryName%7Ecategory_root%5EprodPage%7E15%5Epage%7ESEARCH%252BNAV&ddkey=http:StoreCatalogDrillDownView
It looks like, from the data sheet, if I'm reading it correctly, that the pin
size is 0.48, and that's too small.
What I'm trying to do is raise the internal power supply board on a
STacy up just a bit - so I need 2 of these, one 10 count and one 30
count, to go between the pins from the motherboard, and the socket
on the underside of the internal power supply board. The sockets on
the underside of the internal power supply board are labeled
JAE 10TS and 30TS
If it helps, this is the same setup on a Mega STe.
Thanks.
30 count.
JAE 10TS and 30TS
Thanks.
perhaps something like this:
jameco
jameco
Right, that *looks* like it would work, doesn't it? I'd actually looked at that item from Jameco
before. The question is, how big are the pins themselves? Unfortunately, this item doesn't have
a data sheet.
They certainly are cheap. I could order just to try them out.
Thanks for the reply, Poobah.
jameco
Okay, I ordered a handful of these - just came in today.
The femaled (bottom) end does match up with the pins coming off the headers
on the motherboard itself. Unfortunately, the male end pins are (again) just
too small to fit into the female end header/riser on the bottom of the internal
power supply board itself. They are so loose that you can put them in, turn it
over and they just fall right out.
Anyone know of this same item with male pins about twice the size? Thanks.
jameco
might be time to solder a different header on the power supply itself
I had actually considered that as well - but only as a last resort.
To be honest, I just don't have great soldering skills. Poor eyesight
as I get older doesn't help any either.
I was thinking that I might try to just "glaze" the pins on the Jameco
socket and see if I could make a solid connection with it then. Guess
it wouldn't hurt to try if I can't find anything that exactly matches.
Whatcha think? :)
Whatcha think? :)
I'll have to take a look at my Stacy and see what a good attack route might be. It really does sound like changing the connector on the power supply might be the path of least resistance.
Another update on this part of my STacy update/restoration project. :)
After much experimentation, like many others, I've also come to the conclusion
that I can't put a T25 accelerator in, and keep the internal P/S board where it
is. I've tried every combination of risers, sockets, etc, that I can find and I just
can't get it to work.
Therefore, I'm following the lead of Marc-Antón Kehr, and his Super STacy here:
http://atari.st-katharina-apotheke.de/home.php?lang=en&headline=SuperStacy&texte=S_STacy
Here is my STacy's internal P/S board, flipped over, with the extension cable I made attached:
Now here is the extension cable attached to the motherboard headers:
And here it is, zoomed out a bit so you can see them connected:
Now, we've got to "adjust" the RF shield to make room for where the internal P/S is going.
Here is the original shield:
Here is the part that is coming off, what's left, and how it originally set in the STacy:
(continued in next message)
Now here is the motherboard, with the internal P/S board setting approximately where it
will be when reassembled:
Finally, here it is with the modified RF shielding in place. so you can
get a good idea of how the new layout will be. The internal P/S board
is now sitting under where the original battery compartment was. I've
got to remove that from the upper lid, to make room for the internal
P/S board vertically. Nothing lost there really, the compartment was
never used except in the very first production models, because Atari
realised that only about 15 minutes of operating time was all you could
get. I'll post pictures of that mod. when I get to it. And yes, that is my
left foot in the bottom corner - no extra charge. :)
Okay, here is what the STacy case looks like, before and after battery
compartment removal. I'm also showing the piece I'm planning on flooring
that section with, so that I'll still have a small storage compartment.
<Continued>
Here's a couple more pics - showing my STacy with the battery compartment
re-floored now, and matching gray color. Now I have a functional storage
compartment again. :)
