Rybags #1 Posted July 5, 2011 (edited) I've started this so we can put our benchmarks and comments relating to real HDDs and "adaptor-ed" devices like CF and SD cards interfaced via IDE Plus or other IDE interfaces. Use the RWTEST.COM program to test your speeds. Note that 512 byte/sec partitions should be quicker than 256 or 128 byte ones. Also, you'll generally get a speedup with the screen turned off. To assist the benchmarking with the screen turned off, making up a quick Batch file can help. I just called mine "RWT.BAT". You can create it using the "ED" command that shouuld be resident within SpartaDos 4.44 POKE 559,0 RWTEST %1 POKE 559,34 Just enter that into the window that ED brings up, remember press RETURN after the second POKE command. Then CTRL-S to Save and call it "RWT.BAT" (or whatever). Then, to run a benchmark of each type: -RWT D2: RWTEST D2: Note the "-" prefix to tell DOS to run the batch file. I've just started on a second SD card, and have another to try after that. Strange results on this one. This is with IDE Plus 2, 0.7 BIOS, SDX 4.44. Currently the only media I have available is SD and Micro SD cards, used with a cheap IDE to SD adaptor. Digitech 2 GB SD Card (generic yumcha thing, just bought for $8 ) Partition 1 (256 B sectors) Screen on DOS write: 13,904.8 DOS Read: 37,995.6 DOS average: 25,950.2 Screen off DOS write: 13,729.5 DOS read: 48,053.3 DOS average: 30,891.4 Partition 2 (512 B sectors) Screen on DOS write: 21,784.2 DOS read: 58,350.4 DOS avg: 40,067.3 Screen off DOS write: 24,204.6 DOS read: 75,991.3 DOS average: 50,098 Comment: I'm sure this is substantially slower than the first SD card I tried. Will get back shortly with it's results. Weird how on the 256 byte partition that it actually wrote slower with screen DMA off... I ran it several times and got much the same results. Edited July 5, 2011 by Rybags Quote Share this post Link to post Share on other sites
Rybags #2 Posted July 5, 2011 Verbatim 2 Gig Micro SD housed in provided full-size SD adaptor Partition 1 (256 B / sect) Screen on DOS write: 35,135.8 DOS read: 41,892.6 DOS avg: 38,514.2 Screen off DOS write: 69,523.9 DOS read: 81,690.6 DOS avg: 75, 607.3 Partition 2 (512 B / sect) Screen on DOS write: 52,703.6 DOS read: 61,653 DOS avg: 57,178.5 Screen off DOS write: 68,075.5 DOS read: 81,690.6 DOS avg: 74, 883.1 Quote Share this post Link to post Share on other sites
GoodByteXL #3 Posted July 5, 2011 (edited) Toshiba HD MK8032GAX SpartaDOS File System 2.1 Partition 1 (256 B sectors) Screen on DOS write: 37995.639 DOS Read: 45383.6799 DOS average: 41689.6594 Screen off DOS write: 51867.0628 DOS read: 61653.301 DOS average: 56760.1819 Partition 2 (512 B sectors) Screen on DOS write: 55383.4738 DOS read: 66686.2236 DOS avg: 61034.8487 Screen off DOS write: 74264.2036 DOS read: 90767.3599 DOS average: 82515.7817 Dramatically slow on MyDOS, of course Besides these practically usable performance data you might get more excited when testing with Draco's SysInfo Edited July 5, 2011 by GoodByteXL Quote Share this post Link to post Share on other sites
Rybags #4 Posted July 5, 2011 Sandisk 2 Gig SD (fullsize) Part. 1 (256 B sec) Screen on write: 34,762 read: 42,995 avg: 38,879 Screen off write: 44,762 read: 57,327 avg: 51,044 Part. 2 (512 B sec) Screen on write: 50,271 read: 62,839 avg: 56,555 Screen off write: 66,686 read: 83,785 avg: 75,236 Quote Share this post Link to post Share on other sites
flashjazzcat #5 Posted July 5, 2011 SIDE cart, SDX 4.44, test driver, Sandisk II Ultra 1GB CF card: Partition 1 (256bps): Screen on DOS write: 40845.312 DOS Read: 55383.4738 DOS average: 48114.3929 Screen off DOS write: 55383.4738 DOS read: 74264.2036 DOS average: 64823.8387 Partition 2 (512bps) Screen on DOS write: 59411.3628 DOS read: 72613.8879 DOS avg: 66012.6253 Screen off DOS write: 79698.1697 DOS read: 96106.6164 DOS average: 87902.393 Quote Share this post Link to post Share on other sites
drac030 #6 Posted July 5, 2011 (edited) That's a great pity I hadn't this idea earlier ... I can make transfers ~10% faster, but unfortunately only breaking the compatibility with IDEa and the current IDE Plus BIOS-es. So it is probably not worth it. Edited July 5, 2011 by drac030 1 Quote Share this post Link to post Share on other sites
+orpheuswaking #7 Posted July 5, 2011 10% isn't worth it, I'll just drink a cup of coffee while I wait Quote Share this post Link to post Share on other sites
flashjazzcat #8 Posted July 5, 2011 (edited) That's a great pity I hadn't this idea earlier ... I can make transfers ~10% faster, but unfortunately only breaking the compatibility with IDEa and the current IDE Plus BIOS-es. So it is probably not worth it. Not worth it. Just accept second-place gracefully. Storing pairs of even/odd bytes from the sector buffer would really save some time, but I haven't done that. Edited July 5, 2011 by flashjazzcat 1 Quote Share this post Link to post Share on other sites
Frankie #9 Posted July 5, 2011 Fujitsu 40 GB 2.5" HDD 512 Bytes/sector DOS writing: 74092 B/sek DOS reading: 91323 B/sek DOS average: 82708 B/sek -- just for fun, Transcend 1 GB 40-pin Flash module using external MyIDE card + SDX 4.44 DOS writing: 72720 B/sek DOS reading: 93498 B/sek DOS average: 83109 B/sek Quote Share this post Link to post Share on other sites
UNIXcoffee928 #10 Posted July 5, 2011 I wouldn't bother messing around with low-end SD cards, if I was looking for sheer performance numbers... Get a Sandisk Extreme SDHC, to ensure that you have the lowest on-device latency, then perform your tests. I have read that your block-size and partitioning scheme can severely effect both your device's performance and your device's reliability. There is an excellent overview here, where electrical engineers are discussing card-based filesystem tuning with other technical users. You will certainly learn all of the tricks, if you read that whole thread. Quote Share this post Link to post Share on other sites
+Stephen #11 Posted July 6, 2011 Transcend 2GB CF card, not sure of the adapter I am using (got it from Mech). With DMA off and 512GB sectors via SDX 4.44, I get 76998.375 Write, 93498.03 Read, 85248.2 Average. DMA on, 53066.45 Write, 65448.62 Read, 59257.53 Average. Quote Share this post Link to post Share on other sites
drac030 #12 Posted July 6, 2011 Not worth it. Just accept second-place gracefully. Well, I took a look at this and there indeed were places where my I/O routines could be improved a bit. So the next IDE Plus BIOS will be faster But in fact I am now focusing my attention on other functionalities. Quote Share this post Link to post Share on other sites
flashjazzcat #13 Posted July 6, 2011 Well, I took a look at this and there indeed were places where my I/O routines could be improved a bit. So the next IDE Plus BIOS will be faster But in fact I am now focusing my attention on other functionalities. Your software is of such high quality and so consistently innovative that I don't think 3-4KB/s in either direction is a subject for concern. Of course it's always nice when we have time to optimize and have a bit of fun trying to score high benchmarks. However, efficiency has to be (certainly in the case of SIDE) balanced against the code footprint. Although I'm still using the 8 in-line reads/writes that the MyIDE driver used, I'm currently using some techniques which are the preserve of a RAM-based driver, such as self-modifying code (although there's no guarantee that this will make the cut for the final driver). In addition, I no longer have to worry about the slave device. And on top of all this, I can run the 256 byte sectors in 16 bit mode with the 8-bit data register, which removes the need for any sector padding. Quote Share this post Link to post Share on other sites
+Stephen #14 Posted July 6, 2011 I want to see who will be the first to break the 100K/sec barrier (DMA off of course) Quote Share this post Link to post Share on other sites
+bf2k+ #15 Posted July 7, 2011 Western Digital WD600VE Hard Disk on IDE + 2.0 60gb 2.5" 0.5 amps Partition 1 - 256b ------------------------- Screen ON Writ: 37399.2106 Read: 45661.8269 Avg: 41530.5187 Screen OFF Writ: 53793.3851 Read: 65448.6186 Avg: 59621.0018 Partition 2 - 512b ------------------------- Screen ON Writ: 53066.4475 Read: 64375.6904 Avg: 58721.0689 Screen OFF Writ: 78538.3424 Read: 93498.0266 Avg: 86018.1845 Quote Share this post Link to post Share on other sites
GoodByteXL #16 Posted July 7, 2011 I want to see who will be the first to break the 100K/sec barrier (DMA off of course) if it's just for the figures - I did -> 112. Use Draco's SysInfo Tool. http://drac030.krap.pl/en-si-info.php Quote Share this post Link to post Share on other sites
GoodByteXL #17 Posted July 7, 2011 Something to compare with ... MSC IDE Controller on PBI with no name SD-to-IDE-Adaptor (master only) 2GB SanDisk SD-Card CHS-mode only SpartaDOS File System 2.1 Partition 1 (256 B sectors) Screen on DOS write: 14785.6332 DOS Read: 28169.1806 DOS average: 21477.4069 Screen off DOS write: 19684.4876 DOS read: 37558.9075 DOS average: 28621.6975 Partition 2 (512 B sectors) no 512BPS mode possible 240 (master & slave with hd or CF card) partitions of 16MB each at max. Quote Share this post Link to post Share on other sites
Rybags #18 Posted July 7, 2011 I was thinking earlier maybe it'd have been an idea to do PC-based tests on the media before using it on the Atari, e.g. HD Tach. I was expecting maybe a little less margin among the SD types and more margin between real HDD and flash. Still waiting for my CF adaptor to arrive, once it lands I'll be able to get the new cheapie CF card out and try it. Quote Share this post Link to post Share on other sites
+bob1200xl #19 Posted July 7, 2011 Most any hardware storage device will probably have a cache in it, so you may not be measuring the native speed of the unit. You want to see a CF card go nuts, format it on an old PC where it writes to every sector. I did that once... never again. Bob I was thinking earlier maybe it'd have been an idea to do PC-based tests on the media before using it on the Atari, e.g. HD Tach. I was expecting maybe a little less margin among the SD types and more margin between real HDD and flash. Still waiting for my CF adaptor to arrive, once it lands I'll be able to get the new cheapie CF card out and try it. Quote Share this post Link to post Share on other sites
GoodByteXL #20 Posted July 7, 2011 Something to compare with ... More to compare with ... MSC IDE Controller on PBI with no name CF-to-IDE-Adaptor (master & slave) CHS-mode only SpartaDOS File System 2.1 4GB Noname CF (256 B sectors) Screen on DOS write: 13447.0162 DOS Read: 29438.0626 DOS average: 21442.5394 Screen off DOS write: 17289.0209 DOS read: 39849.0848 DOS average: 28569.0528 1GB Noname CF (256 B sectors) Screen on DOS write: 14207.065 DOS Read: 29175.2228 DOS average: 21691.1439 Screen off DOS write: 18566.0508 DOS read: 39368.9753 DOS average: 28967.513 no 512BPS mode possible Quote Share this post Link to post Share on other sites
GoodByteXL #21 Posted July 7, 2011 POKE 559,0 RWTEST %1 POKE 559,34 I noticed that a program called from within a batch performs somewhat slower. Any explanations ... Quote Share this post Link to post Share on other sites
