Marius #301 Posted January 30, 2013 I did not test the new version on MyIDE ][ ... Are there plans to make it work on MyIDE ][ or is it for MyIDE I only. For me it does not matter; I'm just curious. This new loader (fat16 compatible woohoo) is running great on MyIDE I. Except for that RTC timebar, but that is not so important. Quote Share this post Link to post Share on other sites
candle #302 Posted January 30, 2013 I'm sure they will patch it if they feel like it - they did that once before, so why this should be any diffrent? beyond this - i don't care about myide ii at all 3 Quote Share this post Link to post Share on other sites
mr-atari #303 Posted February 5, 2013 Ok, just dropping the question. Can you compile a version for MyIDE without the time-bar? Size is a issue too, as small as possible, best is below 8k. Like the SIDE-rom version you released long time ago. If not, not, if yes, thanks! Quote Share this post Link to post Share on other sites
Frankie #304 Posted February 5, 2013 I was wondering if you could make a change to the loader so it would skip these directories - System Volume Information $RECYCLE.BIN I have an IDE CF drive and I can't get Windows 7 to stop creating those. Quote Share this post Link to post Share on other sites
candle #305 Posted February 7, 2013 Sijmen: date and time - will do, but bit low on my priority list size - this is an issue, i suggest you use some banking mechanism or compression what takes most of the space are status messages, and i won't get rid of them just like that logo can't and won't go, as this identifies this program Frankie: it would be a matter of not displaying entries that have status of system and hidden set, if anyone else would like that, then sure, why not i preffer to see all the data there are, and i find amusing that windows will block you from browsing these directories, while you can navigate them under altirra using fat loader i was working on adding CIO D: handler, that would allow multifile programs to load, and here it is if program wants to use CIO handler, it must not load below - say - $1000 (currently $BF8, but directory reading and directory change is not implemented yet), and if it doesn't want to load any data, it can safely load as low as $9A6 because of me keeping memlo as low as possible, transfer are a bit slow, but hey - it works it will be more usefully with directory read, but i don't know how this suppose to work and need to read something first fat32-incognito.xex fat32-side.xex fat32-myide.xex fat32-intmyide.xex 2 Quote Share this post Link to post Share on other sites
+Roydea6 #306 Posted February 7, 2013 NO PBI FOUND.. Quote Share this post Link to post Share on other sites
candle #307 Posted February 7, 2013 might be so this will be displayed if you try to boot atr without side hardware enabled inside incognito or u1mb Quote Share this post Link to post Share on other sites
+Roydea6 #308 Posted February 7, 2013 NOPE I tried both 800xl and 130xe with ulmb with first run SIDE cartridge. Also Booted Atari800 with incognito flashed with the latest ROM file that I have available to me. Jon's pbi rom I downloaded from the PM list.. I used The RomBuilder latest version in the ABOUT dialogue box. Use epom burner to flash the ROM chip so believe that I have the latest PBI rom. And I have the xilinix flashed with the latest jed files also. Is ther a new latest PBI... The Fat32 incognito xex loader just before this one works great on loading atr's even multiples Quote Share this post Link to post Share on other sites
candle #309 Posted February 7, 2013 latest pbi driver... loader is not up to the latest pbi driver - we changed a lot when it comes to mounting ATR files and handling over FAT partitions, so it won't work with the latest, it will with what was officially released eons ago Quote Share this post Link to post Share on other sites
+Roydea6 #310 Posted February 7, 2013 latest pbi driver... loader is not up to the latest pbi driver - we changed a lot when it comes to mounting ATR files and handling over FAT partitions, so it won't work with the latest, it will with what was officially released eons ago OK I will continure to use the previous fat32xex loader.. Quote Share this post Link to post Share on other sites
candle #311 Posted February 7, 2013 it won't change a thing, it is pbi driver you need to downgrade right now Quote Share this post Link to post Share on other sites
flashjazzcat #312 Posted February 8, 2013 New PBI with changes you mention isn't public yet Sebastian, so not sure what the problem is here. Quote Share this post Link to post Share on other sites
candle #313 Posted February 8, 2013 i've assumed you've posted it on incognito betatesters list my bad will check this soon Quote Share this post Link to post Share on other sites
candle #314 Posted February 10, 2013 fixed bug in cluster chain handling (that didn't manifest outside cio driver), and added CIO directory listings now things like quick assembler works, pretty useless without save, but maybe one day... good thing: you could put RMT files with RMT player in one directory and it would list the files and load them flawlessly right from fat16/32 partition currently fat16 root directory cannot be accessed from cio driver, so if someone wants to have this kind of functionality over fat16 partition please put files inside subdirectory cio driver will see all the files from directory that the xex file was loaded fat32-incognito.xex fat32-side.xex fat32-myide.xex fat32-intmyide.xex 2 Quote Share this post Link to post Share on other sites
flashjazzcat #315 Posted February 11, 2013 Great work - I really like the way this project is heading. Quote Share this post Link to post Share on other sites
+Roydea6 #316 Posted February 22, 2013 Great Fat32 loader I put RMTPLAYER and all the files I have into a folder and listened to Rmtplayer for several hours. I also put The Last word and related file into a folder and was able to print to P: but not save. Now I am looking for a slide show viewer for pictures but the only one I have is a basic program. PS the Last word editor didn't find any ram so I could only have one buffer. Quote Share this post Link to post Share on other sites
candle #317 Posted February 22, 2013 thanks Roy write support is planned, but not yet there Quote Share this post Link to post Share on other sites
flashjazzcat #318 Posted February 22, 2013 PS the Last word editor didn't find any ram so I could only have one buffer. XEX loader won't affect the RAM visible to TLW, so something else must be to blame. Check hardware RAM configuration, any RAMdisks present, and consult manual regarding TLW extended RAM set-up. Quote Share this post Link to post Share on other sites
+Roydea6 #319 Posted February 22, 2013 YEA You are correct I had to re-burn the CF card to change the LW.SYS. Quote Share this post Link to post Share on other sites
TheMontezuma #320 Posted February 22, 2013 I have a SIDE interface (from Zaxon). I wondered how can I replace the original loader in the SIDE cart with "fat32-side.xex" files posted by Candle? (the "side-update.xex" files worked fine for me) Is flashing of SDX independent of flashing the loader? Quote Share this post Link to post Share on other sites
candle #321 Posted February 22, 2013 at some point, flashing utility will be provided now i'm just trying to get as much feedback as i can Quote Share this post Link to post Share on other sites
Frankie #322 Posted February 23, 2013 Ok, what's the reason the day-of-the week displayed in the loader is off? Mine is always a day behind. The actual date and time is correct. If I flip the switch on my side and go in SDX, type TD ON, it shows the correct day of the week. Frank Quote Share this post Link to post Share on other sites
candle #323 Posted February 23, 2013 the same story as in u1mb or incognito bios screen we didn't agree on how we count days i'm using linux numbering, trub is using ISO Quote Share this post Link to post Share on other sites
+phoenixdownita #324 Posted October 6, 2013 Hi, new here. Just bought a MyIDE2 and like it. I mostly use it with FAT32Loader as it is way easier to use, just drag and drop . I'd like to ask if it is possible to support KBOOT ATR files? FAT32Loader complains that those ATRs are not correct, which is right as they are truncated, but would it be possible to force the loading anyway considering all the missing blocks as zero? If this is not the right forum please feel free to point me in the right direction. Thanks and keep up the good work. Quote Share this post Link to post Share on other sites
+Roydea6 #325 Posted October 6, 2013 (edited) Hi, new here. Just bought a MyIDE2 and like it. I mostly use it with FAT32Loader as it is way easier to use, just drag and drop . I'd like to ask if it is possible to support KBOOT ATR files? FAT32Loader complains that those ATRs are not correct, which is right as they are truncated, but would it be possible to force the loading anyway considering all the missing blocks as zero? If this is not the right forum please feel free to point me in the right direction. Thanks and keep up the good work. There is another small tool called "ATR Image Size Corrector" from Christian Wyk. The program is german-only, but that doesn't matter, you can figure it out how it works... PC windows program. There are only 4 options 1. "Einzelne Datei korrigieren" means "correct one single file", 2. "Verzeichnis korrigieren" means "correct folder", 3. "XFD>ATR konvertieren" means "convert XFD>ATR" and 4. "Sortieren" means "sort". Ah yes, and the buttons: "Datei wählen" -> "choose file", "Verzeichnis wählen" -> "choose folder", "schliessen" -> "end", "Quelle..." -> "source...", "Ziel..." -> "target..." ATRImageCorrector.zip Edited October 6, 2013 by rdea6 Quote Share this post Link to post Share on other sites
