r3tr0g4m3r #1 Posted July 25, 2011 How do you remove the front faceplate without mangling or damaging it? I need to open up the console for some TLC. I've attempted to open it without removing the faceplate, but I don't want to force it and risk breaking something. How do I re-attach the faceplate to look like it was never removed? Please advise, thanks! Quote Share this post Link to post Share on other sites
+opcode #2 Posted July 25, 2011 How do you remove the front faceplate without mangling or damaging it? I need to open up the console for some TLC. I've attempted to open it without removing the faceplate, but I don't want to force it and risk breaking something. How do I re-attach the faceplate to look like it was never removed? Please advise, thanks! You don't need to remove the faceplace to open the console. Search for the service manual online. I think it shows how to open the CV. Quote Share this post Link to post Share on other sites
r3tr0g4m3r #3 Posted July 26, 2011 Found some good stuff here: http://www.colecovisionzone.com/page/coleco%20industries/internal.html Thanks!!! Quote Share this post Link to post Share on other sites
+evg2000 #4 Posted July 26, 2011 You might want to look here: http://www.theadamresource.com/manuals/#mod search for A Guide to Disassembling the Colecovision Quote Share this post Link to post Share on other sites
r3tr0g4m3r #5 Posted July 26, 2011 You might want to look here: http://www.theadamresource.com/manuals/#mod search for A Guide to Disassembling the Colecovision That's a great resource as well, thanks for sharing! Quote Share this post Link to post Share on other sites
VectorGamer #6 Posted July 26, 2011 It's a pain in the butt...I've read it a hundred times and opened up a dozen or so ColecoVisions and it's still a struggle! Quote Share this post Link to post Share on other sites
r3tr0g4m3r #7 Posted July 26, 2011 I didn't find it that hard to disassemble and reassemble, but perhaps I just got lucky this time? A little WD40 sprayed in the power switch resurrected my CV for now. I just have to test out all the other stuff I got in the box 'o stuff. Then, I'll decide to go further with any mods. Thanks again for everyone's help! Quote Share this post Link to post Share on other sites
NIAD #8 Posted July 26, 2011 I didn't find it that hard to disassemble and reassemble, but perhaps I just got lucky this time? A little WD40 sprayed in the power switch resurrected my CV for now. I just have to test out all the other stuff I got in the box 'o stuff. Then, I'll decide to go further with any mods. Thanks again for everyone's help! WD40 is just a quick fix and actually not a very good lubricant to use on the Power Switch. The best method is to desolder the switch completely from the PCB and clean everything up, re-lubricate the switch with de-electric grease (auto shops in your area should have this) and then resolder back into place. Here's a link to an older thread with a lot of tremendous How-Tos... http://www.atariage.com/forums/topic/163446-diy-modifications-for-colecovision/page__p__2018922#entry2018922 Quote Share this post Link to post Share on other sites
r3tr0g4m3r #9 Posted July 26, 2011 Thank you. I suspected as much, but then again I just acquired this CV and needed to get it up running quickly to check it out. I think I got lucky! This CV seems to be in real good shape. Has anyone done this power switch mod for a more permanent fix? http://callanbrown.com/index.php?option=com_content&view=article&id=61:colecovision-power-switch-upgrade&catid=36:home-console-projects&Itemid=61 I'd prefer a switch that is completely black, though. But is a power switch mod really necessary if the original switch is rebuilt? How long is a rebuilt switch expected to last? Another 30 years? Quote Share this post Link to post Share on other sites
SlowCoder #10 Posted July 28, 2011 Check my signature for disassembly instructions also. Quote Share this post Link to post Share on other sites
Yurkie #11 Posted July 28, 2011 Thank you. I suspected as much, but then again I just acquired this CV and needed to get it up running quickly to check it out. I think I got lucky! This CV seems to be in real good shape. Has anyone done this power switch mod for a more permanent fix? http://callanbrown.com/index.php?option=com_content&view=article&id=61:colecovision-power-switch-upgrade&catid=36:home-console-projects&Itemid=61 I'd prefer a switch that is completely black, though. But is a power switch mod really necessary if the original switch is rebuilt? How long is a rebuilt switch expected to last? Another 30 years? If I rebuild your switch it should work perfect for years. There really is no need to replace the switch. Quote Share this post Link to post Share on other sites
