José Pereira
ANTIC4 or Gr.7?
Why not just use 16 shades of blue/green/gray etc for backgrounds and colour PMs separately?
It would result in something like this:
Not bad , in my opinion. Some multiplexed PM (Main ship, weapons , ground turrets, shots ) over that background makes a great looking game out of this. Some parallax on the tiles should be possible aswell.
Emkay it's not like that.
What you have there is a 2:1 Resol. with 16 luminances.
The Playing Area have 13Ground Tiles, each one it's 2bytes wide.
The Playing Area it's indeed 26chars/bytes wides (without any Lines, just Playing Area).
Like this each tile of 2bytes would be 4pixels of GTIA Modes.
But the screen would look very bad looking.
If you convert 2bytesd/1Tile to 3bytes/1Tile and screen would be 39bytes and our screen must be 40bytes wide.
But this would also turn the Gfxs. a little bit widest, and you'll also have to put them a little bit taller.
This is something how it could really look:
(with the space at the Bottom to get a new Status Area)
The hor. pixel are based on 75 pixel . To have the aspect ratio a bit eye friendly, you have to adjust many objects to 2 or even 4 scanlines.
It's a mockup , thus not really as it looks after someone would create it on the A8.
But someone may save us from games in your proposed aspect ratio ;)
You and your 'always ;) '
Can you say something more, even just a little bit more.
My time to ' ;) '
Emkay you picture has 170pixels wide and it's based on 85pixels 2:1ratio:
That will go for that in 4:1ratio 340pixels wide (or A8 reality in old T.Vs. 336pixels)
I was on the jump to work, and i was bored of your strechted image . So a typo happened.
What do you want to prove with the strechted image?
Check this out ;)
320 x 238 (80 x 238)
But it will show less, because 32or40 scanlines would be needed for the Status Area.
Like that the Playing Area will be more or less what I show ;)
Edited by José Pereira
Check this out ;)
Status Areas are for computers that cannot handle the game fullscreen ;)
Check this out ;)
Yes, but for computers that have many sprites to also use at Status Area and place over gfxs.
You need some scanlines just for the Status Area ;) .
But, by the way I discouver this:
A new 'sort of' Super Mario Bros.
Doesn't have nothing new from 1st of April but if someone interested I may contact the guy...
And it doesn't need to be exactly the same, just use that Rocks/Undergound idea but we can build new Game Map and Enemys/Objects/...
I taked one screen and use some original SMB 'bad guys' and have some ideas in my Head :ponder:
(Because of Rocks 'type/colour like' I call this SMB Attack of the Rock Creatures)
It can use that 'MWP'(8way scrolling) routine with a Soft Sprite routine.
The coins would be done the same as an idea I had when me and CreatureXL were talking about the 'Interlude CREATURES2' screen(s).
Could look a real good 'NES like' on A8.
(was talking some weeks ago with a friend and show him some examples and prove him why A8 (7800 also) was the only computer back in time that could simulate NES and those console colour Pallete looking games because of back in time was the only with 128/256 colours/luminances ).
The bigger the status area the smaller the computer's powers, compared to needs of the game ;)
Very often , the AMIGA version of a game got a huge status area, because it was an adaption from the ST.
The Big Status Area in LN has it's cause by the usage of the C64's memory (for example) , to keep the screendata low.
The good thing with the A8, we could always use fullscreen and change the resolution inside, to adjust the gamespeed.
Probably will save 'P1' and instead of Coins may betther go for just 'Chars' and Diamonds in a 'Gianna sisters type':
Those games really don't touch my needs ;)
But I'm still curious for a game looking like that (taken from the same site ) :
.... and using the same techniques as in Space Harrier (which means a fluent movement is going on.
No needs for special colour DLI or PM multiplexing. Just handling the linear framebuffer....
Or, the VSCROL could be used for a double scanline mode.
In theory a game with the Atari robot could be built on this.
Edited by emkay
Best example:
http://www.youtube.com/watch?v=owHCjEWjAvs
The low resolution sometimes doesn't matter, because the movement let's the eyes calculate a resulting image . So just give all moving objects a slight animation/movement, to enhance the visual "resolution" is the key. And sheddy's engine seems fast enough for this. And the best thing: we have all pms available for some "HUD" .... aka status Area ;)
Edited by emkay
The real 'key' would of course then be a cartridge with a 16GB storage feature.
Hehe. Not really.
We'd need not as much different objects as in Space Harrier. When moving, a fixed amount of shapes would be necessary. Some cycled animation would be necessary, if no movement happens.
Edited by emkay
Though you could always add a DLI and put the game into APAC mode. Seems to work well enough in that Wolfenstein demo someone did on here ...
