mark #1 Posted January 2, 2003 if alchol doesn't work use very fine sandpaper (600+grit) on the contacts. works everytime for me. the round spongy things that protect the switches, use spares you got layin around to also cover them on the outside. take the power supply out after you play so it will last longer. if you don't have a dust cover use a plastic sheet to cover your 2600. anyone else have miscellaneous tips you want to share Quote Share this post Link to post Share on other sites
Nukey Shay #2 Posted January 2, 2003 Take the power supply out? For drinks?? j/k And covering the woody with plastic right after play might be harmful (anyone?). Personally, plastic doesn't do anything for me Quote Share this post Link to post Share on other sites
Happy_Dude #3 Posted January 2, 2003 "do not submerge in water" - funny story - I actually dissasembled my 6 switch an took out all the electrical components and washed the case under running water. The only way I'v found that effectively removes that "cacked on" dust from the groves on the 6 and 4 switch modles - Switch tip If you're switches are gummy and don't click, de-solder them and take them apart using a flat screwdrived, then use a hole punch or another screwdriver and "Gently" tap on the back of the contact. then reasemble and you're switches should be like new Quote Share this post Link to post Share on other sites
badbrad #4 Posted January 2, 2003 when I worked for a local arcade vendor, we would put the pcb's in a dishwasher and dried them in an oven on the lowest setting. Never had one get ruined. Quote Share this post Link to post Share on other sites
Brad2600 #5 Posted January 2, 2003 I find it very useful to use tissue to get to the nooks and crannies on 2600s...so it's not so hard to clean the surfaces of them. I'm not prone to taking apart 2600s and I do try and clean carts as well. Quote Share this post Link to post Share on other sites
Witchfynde #6 Posted January 2, 2003 when I worked for a local arcade vendor, we would put the pcb's in a dishwasher and dried them in an oven on the lowest setting.Never had one get ruined. Wow, that's amazing, an arcade vendor that actually CARED! I hate those that let their machines go to hell and have crappy joysticks and all, the slobs. In regards to topic Yeah, make sure your Atari doesn't feel warm anymore before putting the plastic over it when you're done playing so it doesn't overheat. And a tip for any Vectrex owners: you can use a spare pillowcase as a dust cover. I'll tell ya one funny thing, a buddy of mine had been over a lot during the summer we graduated from high school, playing video games, and then FINALLY one day he said "what IS that underneath that cover?" I told him it was a Vectrex. He didn't even know what one was. Look dude, more games to play! Quote Share this post Link to post Share on other sites
