+Lee Stewart Posted September 20, 2012 Share Posted September 20, 2012 (edited) OK I have a few more questions: Since most programs will span more than one screen, how does one load all the screens at once? Yes. Use the word --> at the point on the screen/block where you want to load the next screen/block. This would normally be the last item on the page; but, there are reasons for ignoring the remainder of a screen/block. You can also explicitly load a particular screen/block with 67 LOAD if screen/block 67 is the next block you wish loaded. For obvious reasons, --> is usually better. Also, when I edit a particular screen, I have to reload it and as expected I then get a string of redefined warnings. Is there another way to do this? If you FORGET the first definition on the screen in question, you will erase all the definitions from the one you FORGET to the latest one defined and, thus, avoid the problem. By first definition, I mean to include constants, variables and anything else that is compiled into the dictionary. Finally, I'm not completely clear on SMLIST and SPRMOV: 0 -2 0 SMLIST should set up a movement vector straight up for sprite 0 0 1 SPRMOV should move ONLY sprite 0 according the its previously defined SMLIST vector Am I correct so far? Now if I change SMLIST, do I need to issue another SPRMOV or does the sprite simply change direction and/or velocity? It seems that you expect SPRMOV to set sprites into automotion. It won't. It only moves them according to vectors set up by SMLIST. Consequently, setting up different vectors will not take effect until you issue another SPRMOV for the range of sprites you wish to move. I am pretty sure @Willsy has not implemented sprite automotion. It wasn't obvious to me from a cursory look at TI Forth what would be needed to implement automotion in TF. To simulate automotion, you will need to set up SPRMOV in a loop. As I recall, most gamers prefer that to automotion anyway. As you might have guessed, I'm having problems getting sprites to move and I wanted to double check that I understood the above words correctly... ...lee Edited September 22, 2012 by Lee Stewart Quote Link to comment Share on other sites More sharing options...
Willsy Posted September 20, 2012 Share Posted September 20, 2012 Hi, Yes Lee, you're right. TF doesn't have sprite automotion. That will come as a surprise to anyone coming from the XB world, as it is a crutch upon one must rely if one is to use sprites in XB. Anyone used to assembly (I know you are, Vorticon!) will be quite happy moving sprites around under their own control, and enjoy the extra flexibility that comes with it. We're all familiar with sprite over-shoot and dodgy collision detection in XB. In TF, the sprites move on their vectors only when SPRMOV is executed. The more often you execute SPRMOV, the more often your sprites will move. If you arrange your sprites cleverly, you can move them in groups, and get the same effect as automotion when calling SPRMOV in a loop. This is possible because SPRMOV takes a starting sprite parameter. So you could move, say, sprites 0 to 3 on continuously in a loop, and every other loop iteration, execute an extra SPRMOV on sprites 4 to 7, for example. OR, you can set say, sprites 0 to 3 to move, say, 4 pixels to the right, and sprites 4 to 7 to move 2 pixels to the right, and call SPRMOV on all 8 sprites, and the first four will move at twice the rate of the second four. It's up to you. You're in control . For an example of SPRMOV in action, see this page (scroll down to the sprite demo - it looks a bit jerky, but that's just YouTube). Regarding dictionary re-definitions, as Lee says, FORGET is your friend here. Say you have block 43, and it has the following definitions in it: : MoveUp .... ; : MoveDown ... ; : MoveLeft ... ; : MoveRight ; --> (Note that the --> in the above causes the next block to be loaded - you 'chain' blocks together in this way) As you have found out, you get re-definition warnings when reloading the block. The way around this is to do: FORGET MoveUp : MoveUp .... ; : MoveDown ... ; : MoveLeft ... ; : MoveRight ; --> When the FORGET MoveUp is executed, MoveUp, *and everything AFTER it* is removed from the dictionary. The fact that your blocks are chained re-loads the stuff that was removed from the dictionary. Note that FORGET (as stated in the language reference on the TF site) cannot be used inside a colon definition. After a while, continually editing and re-loading blocks (and waiting for the subsequent blocks to be re-compiled) will get on your nerves (It's fine if you have a RAM disk). Well, there is an alternative method, which is very very handy when you are just entering colon definitions at the command line and feeding it stack data and trying out/debugging the definition. It means that you don't have to re-load all the stuff *after* the word you are working on. It's a trick, for sure, but it *does* save time while debugging a word. When you have the word working nicely, you edit your block accordingly, use FORGET and re-compile (or, as I do, use COLD to restart the whole shebang and compile afresh). One last note regarding FORGET. Forget removes the FIRST matching occurrence that it finds. All dictionary searches start from the last defined word and work backwards. So: : TEST 1 . ; : TEST 2 . ; : TEST 3 . ; FORGET TEST TEST Can you work out what happens here? Finally, have a look at MARKER. MARKER isn't built in to TF, but is very easily defined. I haven't got around to putting it on the site, but I've attached information for you. MARKER.txt I guess all the above is a lot to digest. Don't worry. Small steps. Rome wasn't built in a day. You're immersing yourself in a programming language that is so very very different to anything else, with bugger all documentation! As I like to say to people, when learning Forth, it's better to leave your previous programming experience 'baggage' behind... It'll just weigh you down Quote Link to comment Share on other sites More sharing options...
Willsy Posted September 20, 2012 Share Posted September 20, 2012 Just had a thought regarding ED: and ;ED. I'm not sure which build of TF V1.2 you're running, but you might find that it doesn't work if you are using the (I think) the last two builds of V1.2. The reason is because BRANCH and 0BRANCH were changed to take an explicit address, rather than an offset (makes it slightly faster). The code published uses an offset. I'll change the code to produce an explicit address (ED: will get simpler, less code!). Mark Quote Link to comment Share on other sites More sharing options...
Willsy Posted September 20, 2012 Share Posted September 20, 2012 Couldn't resist... The new version of ED for V1.2 is (I think): : ED: BL WORD FIND IF 2+ DUP ['] BRANCH SWAP ! \ write BRANCH opcode 2+ HERE SWAP ! \ write branch address ] \ enter compile mode ELSE TRUE ABORT" not found" THEN ; : ;ED $832C , \ compile EXIT opcode [COMPILE] [ \ enter interpret mode ; IMMEDIATE Un-tested as I don't have my laptop with me. I'll update the site tonight. I'm off to the dentist this afternoon so I'll be at home drooling like a baby come 4pm so I'll fire up Dreamweaver and my FTP software! Quote Link to comment Share on other sites More sharing options...
JonnyBritish Posted September 20, 2012 Share Posted September 20, 2012 Can I add to this thread... What are the implications for TF1.2 as regards F18A support. Like a few of us i am lucky to have an F18 installed and now have a loverly rock steady VGA display but with a bad keyboard (another story) Mr Willsy, are you planning to add support for F18 or just additional addons for TF1.2? Quote Link to comment Share on other sites More sharing options...
Willsy Posted September 20, 2012 Share Posted September 20, 2012 There's no room in the Rom for f18 support out of the box, but I am planning some libraries that can be loaded and used. If I ever do a TF 2.0 (a possibility) it will have a 64k Rom and support for the f18 built in :-) Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted September 21, 2012 Share Posted September 21, 2012 Just had a thought regarding ED: and ;ED. I'm not sure which build of TF V1.2 you're running, but you might find that it doesn't work if you are using the (I think) the last two builds of V1.2. The reason is because BRANCH and 0BRANCH were changed to take an explicit address, rather than an offset (makes it slightly faster). The code published uses an offset. I'll change the code to produce an explicit address (ED: will get simpler, less code!). Mark Ahhh, what is ED??? Willsy, I'm still a total nube at this, remember? I'm still using version 1.1 because I'm testing TF on my real console. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted September 21, 2012 Share Posted September 21, 2012 (edited) Ahhh, what is ED??? Willsy, I'm still a total nube at this, remember? I'm still using version 1.1 because I'm testing TF on my real console. I'll give you a preview because Mark is sawing logs at the moment! Then, he can clean up my attempt at an explanation. ED: and ;ED are part of a quick and dirty solution to the one-more-bug syndrome---you know---where you code a word that fails, but you're sure you know what the problem is, so you fix it only to have it fail again. But, you know what's wrong this time and you keep up these stutter steps into the wee hours. One of the problems with re-programming a word is that it might be way back in your definitions, so every time you FORGET the word to rewrite it, you have to reload all the words behind it! ED: and ;ED allow you to rewrite the word on the command line without affecting any other words until you get it right. All you need to do is to treat ED: like : and ;ED like ;. Say, for example, you wrote this: : TESTLOOP 10 0 DO LOOP ; The problem is that you intended to display the loop index, but your bigger problem is that TESTLOOP is ten words back in the dictionary and you'd like to fix it without reloading the other ten words. Enter ED: and ;ED: ED: TESTLOOP 10 0 DO . LOOP ;ED <----Uh-oh! Still wrong! Underflow... ED: TESTLOOP 10 0 DO I . LOOP ;ED <----Ah! Now it should work! You can repeat this procedure pretty much as long as you want. You do have to completely redefine the word. It's not truly an edit. It also chews up dictionary real estate, so you eventually need to actually FORGET the word and make a clean redefinition if you want to keep it; but, it can save you some debug time along the way. ...lee Edited September 21, 2012 by Lee Stewart Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted September 21, 2012 Share Posted September 21, 2012 (edited) Well I did additional sprite testing after reading your comments (thanks ), and the code below just refused to work in TF1.1, and I suspected it was the joystick patch at the root of the problem. So I removed the patch and entered the same program in Classic 99 using TF1.2 and it worked perfectly. : INIT 1 GMODE 12 SCREEN ; : DEFCHR1 DATA 4 $18BD $FFBD $3CBD $FFBD 384 DCHAR ; : DEFCHR2 DATA 4 $EE44 $FEFF $FFFE $44EE 385 DCHAR ; : DEFCHR3 DATA 4 $BDFF $BD3C $BDFF $BD18 386 DCHAR ; : DEFCHR4 DATA 4 $7722 $7FFF $FF7F $2277 387 DCHAR ; : DEFSPR 0 80 125 384 15 SPRITE 0 -2 0 SMLIST ; : READJOY 0 JOYST CASE 16 OF 0 -2 0 SMLIST ENDOF 2 OF 0 0 -2 SMLIST ENDOF 4 OF 0 0 2 SMLIST ENDOF 8 OF 0 2 0 SMLIST ENDOF ENDCASE ; : START INIT DEFCHR1 DEFCHR2 DEFCHR3 DEFCHR4 DEFSPR BEGIN READJOY 0 1 SPRMOV BREAK? AGAIN ; It was blazing fast! Any other major issues I need to know about regarding TF1.1 so I don't try to pull my hair out every night? Edited September 21, 2012 by Vorticon Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted September 21, 2012 Share Posted September 21, 2012 I'll give you a preview because Mark is sawing logs at the moment! Then, he can clean up my attempt at an explanation. ED: and ;ED are part of a quick and dirty solution to the one-more-bug syndrome---you know---where you code a word that fails, but you're sure you know what the problem is, so you fix it only to have it fail again. But, you know what's wrong this time and you keep up these stutter steps into the wee hours. One of the problems with re-programming a word is that it might be way back in your definitions, so every time you FORGET the word to rewrite it, you have to reload all the words behind it! ED: and ;ED allow you to rewrite the word on the command line without affecting any other words until you get it right. All you need to do is to treat ED: like : and ;ED like ;. Say, for example, you wrote this: : TESTLOOP 10 0 DO LOOP ; The problem is that you intended to display the loop index, but your bigger problem is that TESTLOOP is ten words back in the dictionary and you'd like to fix it without reloading the other ten words. Enter ED: and ;ED: ED: TESTLOOP 10 0 DO . LOOP ;ED. You can repeat this procedure pretty much as long as you want. You do have to completely redefine the word. It's not truly an edit. It also chews up dictionary real estate, so you eventually need to actually FORGET the word and make a clean redefinition if you want to keep it; but, it can save you some debug time along the way. ...lee Nice. I definitely could use this little tool. Thanks for the explanation Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted September 21, 2012 Share Posted September 21, 2012 Finally, have a look at MARKER. MARKER isn't built in to TF, but is very easily defined. I haven't got around to putting it on the site, but I've attached information for you. Thanks. Another extremely handy tool! Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted September 21, 2012 Share Posted September 21, 2012 Nice. I definitely could use this little tool. Thanks for the explanation Sorry! I messed up my example above in post #108. I've corrected it (I think). ...lee Quote Link to comment Share on other sites More sharing options...
Willsy Posted September 21, 2012 Share Posted September 21, 2012 Well I did additional sprite testing after reading your comments (thanks ), and the code below just refused to work in TF1.1, and I suspected it was the joystick patch at the root of the problem. So I removed the patch and entered the same program in Classic 99 using TF1.2 and it worked perfectly. : INIT 1 GMODE 12 SCREEN ; : DEFCHR1 DATA 4 $18BD $FFBD $3CBD $FFBD 384 DCHAR ; : DEFCHR2 DATA 4 $EE44 $FEFF $FFFE $44EE 385 DCHAR ; : DEFCHR3 DATA 4 $BDFF $BD3C $BDFF $BD18 386 DCHAR ; : DEFCHR4 DATA 4 $7722 $7FFF $FF7F $2277 387 DCHAR ; : DEFSPR 0 80 125 384 15 SPRITE 0 -2 0 SMLIST ; : READJOY 0 JOYST CASE 16 OF 0 -2 0 SMLIST ENDOF 2 OF 0 0 -2 SMLIST ENDOF 4 OF 0 0 2 SMLIST ENDOF 8 OF 0 2 0 SMLIST ENDOF ENDCASE ; : START INIT DEFCHR1 DEFCHR2 DEFCHR3 DEFCHR4 DEFSPR BEGIN READJOY 0 1 SPRMOV BREAK? AGAIN ; It was blazing fast! Any other major issues I need to know about regarding TF1.1 so I don't try to pull my hair out every night? Ha ha!! Nice one! You're on your way! :thumbsup: Well done! Er, yeah, sorry about that - I think that patch for Joyst is also bugged. Er, I'll have to patch the patch! Regarding your code, I would factor it slightly differently, but that's not important right now. Just for kicks, try it again in V1.2 without the BREAK? in the word START. See how much a keyboard scan slows down the program? Bloody shocking, isn't it?? You could use the joystick fire button to exit, by adding an extra case in READJOY: 1 OF TRUE ABORT" Program exit" ENDOF That would be faster than keyboard scan. Also, it's probably faster (never tried it) to use SPRLOC to mve a single sprite around. In fact that would make a very good excercise for you: Use a variable for X and another for Y and move the sprite around using the variables. Tips: Use the language reference on the website, and look at VARIABLE, @, !, 1+ 1-, etc. Also look at the variables tutorial here for more information. Finally, you may prefer to use VALUES rather than variables (I do). There's a tutorial on VALUES on the website, too! You have 24 hours to deliver your homework! Regarding Lee's comments on ED - much better explanation than me, Lee! Thanks! Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted September 22, 2012 Share Posted September 22, 2012 Willsy, how would you factor this differently? Quote Link to comment Share on other sites More sharing options...
Willsy Posted September 22, 2012 Share Posted September 22, 2012 Willsy, how would you factor this differently? Like this: : UDGs DATA 4 $18BD $FFBD $3CBD $FFBD 384 DCHAR DATA 4 $EE44 $FEFF $FFFE $44EE 385 DCHAR DATA 4 $BDFF $BD3C $BDFF $BD18 386 DCHAR DATA 4 $7722 $7FFF $FF7F $2277 387 DCHAR ; : DEFSPR 0 80 125 384 15 SPRITE 0 -2 0 SMLIST ; : INIT 1 GMODE 12 SCREEN UDGs DEFSPR ; : READJOY 0 JOYST CASE 16 OF 0 -2 0 SMLIST ENDOF 2 OF 0 0 -2 SMLIST ENDOF 4 OF 0 0 2 SMLIST ENDOF 8 OF 0 2 0 SMLIST ENDOF ENDCASE ; : START INIT BEGIN READJOY 0 1 SPRMOV BREAK? AGAIN ; But really, it's no big deal. And factoring is a matter of personal taste and style. It's just that, in the case of this particular program, (in my opinon) the definition of the graphics was 'associated' (in my mind) with initialisation, so I had INIT call the code to define the graphics, rather than have it done in START. Also, I put all the UDGs in one word, saving dictionary space. Also, have a look at DEFSPR and INIT. You may notice that I've seperated logically different parts of the definition with two spaces. This is the equivalent of a paragraph in written English - I.e. in English, when we change the subject, we start a new paragraph. In Forth we do the same, but we leave two or three spaces as a paragraph marker. This makes it much easier to read the code later. For example: 0 80 125 384 15 SPRITE 0 -2 0 SMLIST See the extra spaces after SPRITE? So, when reading it back later, we can clearly see the end of the sprite definition code, and the beginning of the initialisation of the sprite movement list. You'll see this advocated in various Forth books (Brodie et al) and I think it's a good habit to get into as early as possible. It will make your code much more readable. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted September 24, 2012 Share Posted September 24, 2012 Yes, definitely a better way to do it. Thanks for the tips. I'll play with variables and values as well. JohnnyBrittish actually has a little sprite demo with variables implemented. I guess I'll keep plugging along although it's unlikely I'll have much time to play this week Quote Link to comment Share on other sites More sharing options...
Willsy Posted September 25, 2012 Share Posted September 25, 2012 Good stuff. For starters, just try a program to move a single sprite around the screen using variables. Then, when you have done that, do the same using NO variables at all! (It can be done - but it really hurts the non-Forth brain! - It's a very good excercise though). Final tip: I don't know why, but when I'm figuring out difficult code, I always revert to pen/pencil and a notebook. Never the screen and keyboard. Just thought I'd throw that in Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted September 26, 2012 Share Posted September 26, 2012 Willsy, did you ever correct the patch for the JOY function in version 1.1? Until V1.2 is finalized, I'm stuck with the older version on my real TI... Quote Link to comment Share on other sites More sharing options...
Willsy Posted September 26, 2012 Share Posted September 26, 2012 Ah... No I didn't... I'll have a look tonight, shouldn't take long to produce a patch. Quote Link to comment Share on other sites More sharing options...
slinkeey Posted September 29, 2012 Share Posted September 29, 2012 This lin miht have already been shared.. Sorry if i am late to the game.. This tutorial is great! http://turboforth.net/tutorials/tutorials.html Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted September 29, 2012 Share Posted September 29, 2012 Out of curiosity, how does TI Forth compare to TF speed wise? Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted September 29, 2012 Share Posted September 29, 2012 Out of curiosity, how does TI Forth compare to TF speed wise? It varies. TF is generally faster than TIF, but I've written stuff where TIF was actually faster. With code that includes the display in a loop, TIF definitely loses. @Willsy's display routine is much faster than TIF's. ...lee Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted September 29, 2012 Share Posted September 29, 2012 This lin miht have already been shared.. Sorry if i am late to the game.. This tutorial is great! http://turboforth.ne.../tutorials.html Another Forth convert? Quote Link to comment Share on other sites More sharing options...
slinkeey Posted September 29, 2012 Share Posted September 29, 2012 I just wanted to check it out. I doubt I will do any serious developing. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted October 1, 2012 Share Posted October 1, 2012 Lee, it seems there is something funny going on with the -TRACE option in TIF. When I try to load it, I get the following: -TRACE : isn't unique. ok I also get a couple of numbers on the stack, namely 0 and 5. Subsequently, I get no errors when I execute the word TRACE, but again I get a couple of numbers placed on the stack. I came across this while testing the recursion example on page 29 of your TIF manual which incidentally is missing an IF in the colon definition as it should be : FACT DUP 1 > IF DUP 1 - MYSELF * ENDIF ; Tracing the execution of the above using TRON gives me correct stack results except for 2 additional unchanging digits at the bottom of the stack. Am my missing something or is there a problem with TRACE? Walid Quote Link to comment Share on other sites More sharing options...
