Connect 600XL to TV (PAL)
rveldhuizen
Hi all,
New to this forum, so let me first introduce myself: My name is Rik and I am currently collecting the three main computers I used in my youth: the Apple II+, the TI 99 4/A and the Atari 600XL with 64Kb extension (in that order :)
I've got problems connecting my Atari to any TV I own. I've tried the RCA to RF (coax) cable and searching all channels (incl fine tuning) on 3 different TV's.
Given that I never got that working, I bought (through ebay) a atari/commodore 5-pin to 4 RCA and tried that (in my S-video connections on the tv's). No success either... Never got any further than a darkgreenish/red flickering screen at some point.
Am I may be missing something here? Do I need a special converter to hook up my Atari to any relatively (say, 10-15 years old) television?
I've searched various forums, tried many things, but never got it to work. When I bought my Atari on ebay, the seller did say he hooked it up to a monitor and it worked then... well..
Hope you can help, thanks in advance!
R
Hi Rik and welcome.
People with more hardware knowledge than me will answer.
I can only say that you don't need converters to use your 600XL on modern TV using coax cable or videocomposite cable (2 or 3 RCA not 4).
If I am not wrong, PAL 600XL, like 800XLs and unlike 130XE, don't have s-video (luma-chroma) output but only composite (you can add s-video with an internal mod).
Hi Rik and welcome.
thanks for the quick reply, Philsan!
I think I made a mistake in my original post. I meant to say that I connected the monitor output to my composite connection (not s-video) on the TV's (the yellow connector, so to speak), using one of the 4 available RCA connectors on the cable (tried them all of course, but only one gave me the green/brown flickering signal)... It could be that the cable is not correct for my XL?
R
Ok, update...
I've acquired another Atari 600XL and tried to get a display from that... No success either (using 3 TV's (5-15 yrs old), a VCR (about 15 yrs old) and both the RF as well as the composite cables (different RF this time; original Atari one)! :(
So it is not the computer itself...
The only thing they had in common when I hooked them up to the TV was the power unit (since I have a broken one, I used the same one for both).
My question is: can a faulty power unit cause display issues (there is a signal to the TV, the red light on the Atari is on, but there's no clear image at all (or something resembling a close image))...?? That is the only thing I can think of right now... :( Getting desperate here :)
  • 2 weeks later...
FINALLY!
As posted in my last post, I suspected the power unit could be a possible cause for the non-display... Having replaced one of the fuses in the broken one (the one that didn't work before, i.e., and hence wasn't involved in the testing of the 2 atari's) and using this power unit, I finally got the display right!
So relieved, now I can finally dive into using it again :)
R
Edited by rveldhuizen
FINALLY!
R
Excellent!
