Robert M #1 Posted January 3, 2003 Sorry if this is general knowledge, but its not listed in the section of the AA website for the Adventure cartridge. The Trick: Grab the magnet so that it is located up and to the left of the player. Then carefully move so that you are standing within the bridge but holding the still holding the magnet up and to the left. This can be tricky because the magnet is attracting the bridge. Once you are in that position you can move downwards passing through any obstacles/walls. The magnet will pull the bridge along with you and create a moving passage of sorts. This trick is best done when all the dragons are dead, and the bat is locked in a castle. Having the bat take the bridge or magnet while you are in a wall can leave your trapped. One interesting part of this trick is you can use it to get behind the barrier in the main hall that leads to the secret room, but unless the "dot" is there the secret room is not present. Enjoy! Rob M Quote Share this post Link to post Share on other sites
Nukey Shay #2 Posted January 3, 2003 Actually, the dot just needs to be moved to a different screen than the one it starts at. The program just checks to see if it's been moved...if not, you will appear on the other barrier screen instead of the EE screen. Quote Share this post Link to post Share on other sites
Robert M #3 Posted January 3, 2003 Actually, the dot just needs to be moved to a different screen than the one it starts at. The program just checks to see if it's been moved...if not, you will appear on the other barrier screen instead of the EE screen. Interesting... I'll have to try that. Thanks! Quote Share this post Link to post Share on other sites
Chris++ #4 Posted January 3, 2003 Robert -- Which moon is that in your avatar? Is that Io? Off-topic but genuinely curious CF Quote Share this post Link to post Share on other sites
Robert M #5 Posted January 3, 2003 Robert -- Which moon is that in your avatar? Is that Io? Off-topic but genuinely curious CF You are correct! That's Io, my favorite moon. If I am ever a billionaire, I will build a spaceship and do a personal flyby. Quote Share this post Link to post Share on other sites
Nukey Shay #6 Posted January 3, 2003 Your favorite moon? You don't get out much, do you? j/k My favorite moon would at the very least need to be female. Quote Share this post Link to post Share on other sites
shep #7 Posted January 4, 2003 A favorite moon? .....what makes it so special? Quote Share this post Link to post Share on other sites
Nukey Shay #8 Posted January 4, 2003 All that pretty sulphur. Plus, it's got the biggest mining potential west o' the solar system. Quote Share this post Link to post Share on other sites
Robert M #9 Posted January 4, 2003 A favorite moon? .....what makes it so special? Its the most volcanic body in the solar system. I like volcanoes, and I like astronomy, ergo Io is my favorite moon. Quote Share this post Link to post Share on other sites
somePUNK #10 Posted January 4, 2003 this is the best conversation ever Quote Share this post Link to post Share on other sites
moycon #11 Posted January 4, 2003 Anybody wanna see my moon??? *chirp,chirp,chirp* Quote Share this post Link to post Share on other sites
Nukey Shay #12 Posted January 4, 2003 Aaaany waaaay... You could use my hack Adventure34 to go anywhere without worrying about walls. [/shameless plug] Quote Share this post Link to post Share on other sites
