Only really possible on 16bit ST/Amiga given 320x200 rez and huge palette haha
Only 8bit possible is Commodore 65 with 320x200 256/4096 colours anywhere on screen :P
Apple IIgs might do it.
C= Plus/4 might do it.
8-bit with VBXE might do it. And there's probably many more of them in existance than C= 65.
SNES could do it - that's barely 16-bit :)
actually thinking about it the Sega Mastersystem probably could too and that really is 8-bit
Edited by sack-c0s
SNES = 8/16BIT CPU aligned to 16bit custom chips. Also IIRC SNES <320x256 rez
Master System has insufficient palette and colour resolution issues
COCO 3 =16BIT
CPC+ = 160X200 rez
C= 16/+4 = 160x200 and insufficient total onscreen colours.
IIGS = 16bit machine.
etc
Possible candidate = MGT SAM Coupe (ZX Spectrum compatible) and possibly Konix multisystem But that had 8088 + 16bit custom chips.
Maybe MSX 2 TURBO but not sure.
Closest match is 8086 PC and 8bit ISA BUS video card....if you can get such a card working AND if there were PCs with ONLY 8bit ISA slots. Even then such cards are after 1985 ST/Amiga so.....
I could do it in deluxe paint within hours mind using an off the shelf solution ;)
I'd align the 65816 more with 8 than 16 bit architecture. In the same vein, you can say the 6809 is also an 8-bit CPU.
Plus4, don't go by what the user manual tells you. There's hardware tricks and exploits just like C64 and A8 can do. You can essentially do APAC-like graphics on the Plus4 but in true 160 resolution, and not necessarily need to rely on PAL mixing tricks.
COCO 3 =16BIT
CPC+ = 160X200 rez
etc
I'm pretty sure almost everyone considers the CoCo 3 an 8-bit machine.
MSX 2 screen 8 256 colors or MSX2+ screen 12 65536 colors, but that gives artifacts.
But anyway, too much moving objects to process, so MSX turbo-r in screen 8 indeed.
I would say, maybe Turbo grafx because of its sprite capabilities.
Edited by roland p
why is the SNES an 8/16, but the IIgs is 16bit CPU, when they virtually have the same CPU?
sloopy.
sloopy.
Why is the Lynx considered 16-bit when it has a 6502? Why is the Jag 64-bit when it has two 32-bit processors :D
sloopy.
The Jag has two 64-bit processors, two 32-bit processors, and a 16-bit processor.
It's 64-bit because that's where Atari wanted to put the emphasis. It's unfortunate that most developers only took advantage of the 16-bit processor fully.
End of the day I would only do the Anim on a stock A1000 and a copy of Dpaint 3. Whatever the hardware tricks Dpaint 3 is still the only software worth a crap for pixel art animation even today in the age of i7 PCs :)
YMMV :)
Hardware wise there was also a (French?) computer from 83/84 with identical palette/colour resolution to the ST....forget the obscure name of it.
sloopy.
Yeah - note the evil smiley after the statement. Couldn't resist. Had a Jag since early 95, and been through far too many of the wars associated with it.
sloopy.
Heh, even with smileys, it's hard to tell if someone's being serious sometimes.
I can't keep my mouth shut when it comes to the Jag, though, regardless, haha.
OH SH*T MAN!! You've opened a portal to the Jaguar forum!!!!! RUN!!!!!
