mega-hz
SIO2SD3 PCB released
hmmm... time to send FJC one of my 800XLs :D
I'm not normally a fan of mods which require radical changes to the case, but I'm rather taken with this one.
Edited by flashjazzcat
This is so awesome. I hereby award the inofficial price for best looking Atari hardware 2011! If I get get to create some hardware for my XL, I'll be on my knees for you to create the case.
FJC,
very nicely done. How did you cut the opening for the screen? How do you get the inside corners square? I assume that your buttons are shaped like tophats to capture them inside the case. Do you use springs to keep them fully up against the case or do they rely on the switches themselves for spring pressure? I'm assuming that you'd use springs from ballpoint pens or something that slips over the extended buttons on the tac switches.
cheers,
c
FJC,
very nicely done.
Thanks - the owner's certainly happy. :)
The usual procedure: marked out in pen and dremelled, then flat-filed and hand-sanded. This one was a little more difficult, however, since the exact position of the screen in relation to the case lid was hard to calculate. Therefore, I started with a rectangular hole a bit "short" on all sides, then carefully widened it out, constantly refitting the lid to see how things lined up.
I scrape the "thick" out with a craft knife, then carefully finish them with a box-shaped file.
Since the shafts on the momentary switches were so tall (although not quite tall enough), all I needed to do was extend them some (using the nylon 5mm M3 spacers which are usefully an exact push-fit on the button shafts), and then superglue the button tops in place (these particular button tops don't have a cavity in the bottom - just a recessed channel around the perimeter). I just pressed the spacers down until the clearance was just right, and the increased surface area they provided gave a good contact area for the glue. Fitting the 800XL's lid, then, is simply a case of ensuring the buttons are lined up with the holes before pushing it home.
One thing I could certainly use is a drilling jig. Owing to the natural "drift" of the power drill when widening the holes for the shift and reset switches, they ended up off course by a couple of millimetres. I managed to fix them with some minor adjustments, but I'll certainly be saving up for a jig at some stage.
For the activity lights, I designed a 3-pin header directly attached to the LEDs (push-fitted into the brown plastic layer), into which is plugged a harness connected to three wires going to the relevant pads on the PCB. The objective here was to ensure that nothing that shouldn't get wet in a cleaning or Retr0Briting situation was permanently attached to the case.
Lettering complete. Done using a laser printer, parchment paper and a toaster-oven. I've also attached the original concept sketch I did a few months ago (for the rev 2 board). Pretty close.
cheers,
c
Edited by Vandal968
Nice - lettering's come out really well. Seems you used the same technique I did:
I wish I had known, it would have saved me some time! There's a guy in my local machining club that spent a few weeks researching how to do this and came up with this procedure:
http://rick.sparber.org/ttm.pdf
I did the final transfer part a little differently, I held the strip onto the metal with binder clips and heated in the toaster at 250F. When hot, I reached in with a stick and rubbed the lettering to do the xfer. Worked pretty well, but I think that your font is better than mine.
Do you seal it with anything, or just leave the bare toner? How does it hold up against scratches?
cheers,
c
I'd had some practice with this, so what you see is somewhat refined through repitition.
The font is "SF Atarian System" (although I recall using Arial for the numerals). I adjusted the kerning very carefully to get the XL "look", and printed numerous copies on A4 photo paper. I then cut these into strips and taped them face-down onto the aluminium offcuts on a piece of chipboard. I then ironed them for about five minutes on the hottest setting, before carefully washing away the paper under the cold tap. I'd do a couple and pick the best one.
I tried sealing it with spray-on sealants, etc, but it seems to look better with nothing on. The print isn't as black as I'd like (more a dark grey), but at least it's sharp and required no retouching. As for scratches - I don't know. I don't scratch it. :)
On the subject of aluminium strips: I find they bend better if gently scored underneath.
I received my SIO2SD3 just this morning but I've been unable to test it as the connector is different from my original SIO2SD.
Does anyone make or sell cables for use with the SIO2SD3 yet or would anyone be kind enough to provide pin-outs so I can solder a SIO cable directly to it?
You can use your version 2 cable, that's what I'm doing. I originally soldered a male header to a female header to make an adapter so that the pins would be offset enough for the bulky v2 cable connector to clear the v3 board. Once my enclosure was done, it would no longer fit with my crude adapter, so I just soldered the wires to a female header and plugged it in. The cable still works on either board, but it's no longer "keyed". I plugged it in backwards once and it didn't hurt anything.
cheers,
c
I'm wondering if an off-cut from a turned-pin DIL socket would fit. The connectors look to be of the turned-pin type...
Need to look into this more thoroughly.
Thanks for your suggestion. Where did you buy the male and female headers?
The female connectors are turned, but (on mine) they have extra-wide diameter holes which will take square header pins.
Interesting, thanks for the link. For the moment, I'm satisfied with how the toner looks. If I do another one, I'm definitely going to try a different process, but unless this one gets damaged, I'm going to leave it alone for now.
Too many projects, too little time....
cheers,
c
Got mine today. I was going to order the case but it looks like the display for mine is longer than the ones in the posted pictures. So I doubt the case would fit.
Longer?
I've got three displays here, orange, b&w, blue, they vary a lot. The metal bezel is the part that varies the most, the orange one is narrow but tall, the blue one is wide but low, and the B&W one kind of splits the difference. I found that I could use any one of the three if I adjust the header pins a little. Remove the plastic strip from the base of the male pins, I used an exacto knife to gently pry it up. Then you can clip the male header pins a little at a time to shorten them until you get the fit that you want between bezel and enclosure.
cheers,
c
cheers,
c
amazing work! ...any chance you will make for sale?
Longer?
cheers,
c
Here is a picture of my SIO2SD3 with the supplied display. The display doesn't look like it would fit in the enclosure. It's much longer than the others I've seen posted here that fit nicely over the board.
LOL. Yeah, that display definitely will NOT fit inside the enclosure. The good news is that the displays are standard and you can get the correct size/type for about $6 delivered from eBay.
cheers,
c
Thank you :)
The design is up on Shapeways, you can buy a set by following this link.
http://www.shapeways.com/shops/ohmbu
There is a small amount of fitting required. On mine, the posts that locate the pc board printed a little off from where they should have been, the easy solution was to just snip off two of them. It took me about 10 minutes of careful adjusting with an Exacto to get it all to fit just-right.
cheers,
c
