Sign in to follow this
Ed Siegler
Case Cleaner
I have a Sears Video Arcade II that the shell is in good shape, but it's got some pretty funky dirt on it that simple soap and water doesn't get off. Anyone have any idea what kind of cleaner/mild degreaser I can use to clean this thing up?
Squeaky Clean?
I just read thru that thread and other than De-Solv-It, Fantastic, and Simple Green, I did not see any mention of "Squeaky Clean". Is that some kind of cleaner?
No it means when you are done with all these suggestions...yer Atari will be so clean... It squeaks!!
Heh, I clicked on the link expecting to see information about a "Squeaky Clean" product also. :) I generally use Goo Gone to clean carts and remove sticker residue. I have also used lighter fluid, but that stuff is nasty and you don't want to get it on your hands!
..Al
Lighter fluid is bad, mmmkay. :D
Take the thing apart and wash the plastic parts like you would dishes, then dry them and give them a nice brand new shine with ArmorAll and you're done.
Well, I tried the Windex, and then the Palmolive wash, but this stuff was pretty strict. I just bought a cheapy toothbrush and used some De-Solv-It, and it took about 95% of the stuff off. I want to try this Goo-Gone/Goo-Be-Gone. Can I get this at WalMart or Home Depot?
yeah, I usually pick it up at Home Depot. Works good for me too.
Thanks, I appreciate it. I'm no nightshift, so I'll pick it up on the way in. You gotta have something to occupy your time at work, right? Can't have those pesky work responsibilities keeping you busy, right?
Is it called Goo Gone" or Goo Be Gone"? Just so I know what to look for.
I think there are several Goo X products, Goo Gone is good because it's water based and won't eat away your plastics or labels too much. Goo be Gone and other ones are oil/solvent based and will eat your plastic cart casings and maybe your skin :)
So, "Goo Gone" is what I should get and "should" get this creepy crud off of the case (and is also the water based, correct?)?
I work in a Boiler Room. Unfortunately, I have many scars from chemical burns over the years. You think one would get smart and use protective gear. I'll shield my face, but I shoud be better with covering my arms.
