russg #1 Posted October 29, 2011 (edited) When I run MEMTEST.EXE on my 256K Newell 800XL I get 304 KB, 48K too much. Is there an updated MEMTEST someplace? Or maybe I'm not understanding correctly. Edited October 29, 2011 by russg Quote Share this post Link to post Share on other sites
+Roydea6 #2 Posted October 29, 2011 When I run MEMTEST.EXE on my 256K Newell 800XL I get 304 KB, 48K too much. Is there an updated MEMTEST someplace? Or maybe I'm not understanding correctly. http://www.atariage.com/forums/topic/162718-comprehensive-ram-test-programs/page__view__findpost__p__2009277 look at this link for ramtesting programs. I don't think that I have a memtest program except for xram21.com. Quote Share this post Link to post Share on other sites
Rybags #3 Posted October 29, 2011 Some RAM expansions mirror parts of the base 64K to the 16K area @ $4000 with certain PortB settings. If the testing program doesn't take this into account, it can return the wrong amount. Quote Share this post Link to post Share on other sites
russg #4 Posted October 29, 2011 (edited) Some RAM expansions mirror parts of the base 64K to the 16K area @ $4000 with certain PortB settings. If the testing program doesn't take this into account, it can return the wrong amount. Yes, I believe that is what is happening. The Newell allows banking all four 16K standard memory into $4000, so MEMTEST.EXE is probably banking everything but the OS ($C000-$FFFF). Newell docs say don't bank main memory, unless you know what you're doing. The Newell banks 12 16K extended RAM into $4000, giving 192K extra. There's a memory test program on the Newell disk. It also has VTOCFIX.EXE for MyDOS/2.5/2.0 fixer and a RAMdisk at D8: and a COPY256.EXE to use all 192K for a diskcopy. Here's the Newell disk. It has a XLXETEST.BAS file that tests the Newell. I haven't found many programs that use the extra memory. Probably mostly demos use it. NEWELL.zip Mem-Test v1.0 (1996)(Jaku-B)(Pl).zip Edited October 29, 2011 by russg Quote Share this post Link to post Share on other sites
russg #5 Posted October 29, 2011 That Mem-Test is a .ATR. I can't get it to list a directory or show the MEMTEST file, so here's MEMTEST.COM file. MEMTEST.ZIP Quote Share this post Link to post Share on other sites
russg #6 Posted October 29, 2011 (edited) (Off topic) I just learned what russ means in Deutch. I took German in college, but didn't run across this word. German uses a funny capital 'S' for a double ss. I'm now ready to become a chimney sweep. "SOOT". Edited October 29, 2011 by russg Quote Share this post Link to post Share on other sites
russg #7 Posted October 30, 2011 (edited) OK. I got it now. MEMTEST.COM is correct. Bits 5,6,3 and 2 when set bank extended memory into $4000-$7FFF. If bit 7 is set then main RAM is banked to $4000. So, $8F banks OS ($C000-$FFFF) to $4000, $8B banks $8000-$BFFF, MEMTEST doesn't bank $4000-$7FFF, I guess because it is already there (?), so that bank isn't included in the total, and finally $83 banks $0000-$3FFF to $4000, whatever you'd want to do that. I had to look at my old Newell documentation. REFERENCE VALUEs in $D301 (PORTB): $FF standard RAM, BASIC disabled. $EF,$EB,$E7,$E3, four banks $CF,$CB,$C7,$C3, four more banks $AF,$AB,$A7,$A3, four more banks then bit 7 set, along with bits 0 to 3 bank main memory., Uh, bit 7 is set for all of them, anything above $80 bit 7 is set. Edited October 30, 2011 by russg Quote Share this post Link to post Share on other sites
russg #8 Posted October 30, 2011 (edited) The ABBUC contest is over, so I can release an improved CRC32 program. I call it CRC32N.COM. version 'N'. It gets the directory problem fixed, is 27% faster and has error trapping. Here's a little history of how I programmed CRC32N.COM: 'This came from: http://www.6502.org/...ntegers/crc.htm This URL came from a post '32 bit numbers' to AtariAge.com asking for info how to deal with 32 bit numbers on 8-bit Atari and RevEng responded with this URL. on August 20, 2011. My code comes without much modification directly from this code.' That is about the assembler code embedded in ACTION! code that gets the filename, directory, parse, etc. I wrote the code in Mac65, compiled it, and extracted the machine code into a series of hex numbers for ACTION! code blocks. Much thanks to RevEng (reverse engineer) and, of course, this wonderful resource, ATARIAGE.COM. CRC32N.zip Edited October 30, 2011 by russg Quote Share this post Link to post Share on other sites
+Roydea6 #9 Posted October 30, 2011 Hi Russg, Could the results be captured to a text file, besides just screen results. PS I voted seven points. Quote Share this post Link to post Share on other sites
russg #10 Posted October 30, 2011 (edited) Hi, @rdea. I don't think I can get a text file of MEMTEST output. My previous post of reference values is what MEMTEST shows, except I don't believe I included the $8x main memory banking. It shows $8F, $8B, no $87 (banking $4000-$7FFF to $4000-$7FFF), and $83. So, MEMTEST shows 12 banks, four each, at $Ex, $Cx, $Ax, making 3x64K banking and three $8x main memory banking for 48K more, totalling 240K banked memory and 64K main memory for a total of 304K. If I understand what you're asking. Here's a screen of MEMTEST for Rambo 320K in A8WP4, which is same as my screen except mine doesn't have $87. I forgot to thank ABBUC members, such as you, for the terrific support of Atari 8-bit. russg Oh, I think you're asking results of CRC32 captured to text file. I could do that. Edited October 30, 2011 by russg Quote Share this post Link to post Share on other sites
+CharlieChaplin #11 Posted October 30, 2011 (edited) (Off topic) I just learned what russ means in Deutch. I took German in college, but didn't run across this word. German uses a funny capital 'S' for a double ss. I'm now ready to become a chimney sweep. "SOOT". Hmm, in german dialect we also use "Russ" (yes, with double-s) as an abbreviation for "a russian" (someone from russia)... and err, the german special character "ß" (sharp s) does not exist in upper case; furthermore it looks more like an upper case "B" than an upper case "S" -Andreas Koch Edited October 30, 2011 by CharlieChaplin Quote Share this post Link to post Share on other sites
russg #12 Posted October 30, 2011 (Off topic) I just learned what russ means in Deutch. I took German in college, but didn't run across this word. German uses a funny capital 'S' for a double ss. I'm now ready to become a chimney sweep. "SOOT". Hmm, in german dialect we also use "Russ" (yes, with double-s) as an abbreviation for "a russian" (someone from russia)... and err, the german special character "ß" (sharp s) does not exist in upper case; furthermore it looks more like an upper case "B" than an upper case "S" -Andreas Koch That makes sense. Quote Share this post Link to post Share on other sites
russg #13 Posted October 31, 2011 ß it is an ASCII character, sharp s. ASCII 225 ß, so my name is Ruß. Quote Share this post Link to post Share on other sites
russg #14 Posted October 31, 2011 I should probably start a new thread, and I usually should wait at least 3 days before releasing a new or modified program. But I'll consider it a BETA and post it here for @rdea6 and anyone else wants to test it. This is CRC32N2.COM, it incorporates a feature to write the CRC32 to a .DAT file. It will only make a CRC32.DAT file. If you want to save it to make another one change the filename before you make a new .DAT file, ie. it overwrites any CRC32.DAT file already whereever you want to put it (which drive #). CRC32N2.zip Quote Share this post Link to post Share on other sites
+Roydea6 #15 Posted October 31, 2011 I should probably start a new thread, and I usually should wait at least 3 days before releasing a new or modified program. But I'll consider it a BETA and post it here for @rdea6 and anyone else wants to test it. This is CRC32N2.COM, it incorporates a feature to write the CRC32 to a .DAT file. It will only make a CRC32.DAT file. If you want to save it to make another one change the filename before you make a new .DAT file, ie. it overwrites any CRC32.DAT file already whereever you want to put it (which drive #). Thanks Russg This is good just what the program needs IMO. And I agree this deserves a new thread since it is an ABBUC contest entry. Thanks again. Quote Share this post Link to post Share on other sites
russg #16 Posted November 1, 2011 I should probably start a new thread, and I usually should wait at least 3 days before releasing a new or modified program. But I'll consider it a BETA and post it here for @rdea6 and anyone else wants to test it. This is CRC32N2.COM, it incorporates a feature to write the CRC32 to a .DAT file. It will only make a CRC32.DAT file. If you want to save it to make another one change the filename before you make a new .DAT file, ie. it overwrites any CRC32.DAT file already whereever you want to put it (which drive #). Thanks Russg This is good just what the program needs IMO. And I agree this deserves a new thread since it is an ABBUC contest entry. Thanks again. Welcome. It was your idea. Let me know if it works for you. Quote Share this post Link to post Share on other sites
+Roydea6 #17 Posted November 1, 2011 SNIP Welcome. It was your idea. Let me know if it works for you. Yes I like it.. It reminds me of a crc16 progam to check and list the crc's of files that I have. It is easier to use now with the saved results on the same disk. With file names needing to be truncated to 8.3 format so often I have a lot of dupilicates just named differently, and this CRC listing lets me get rid of duplicates. Quote Share this post Link to post Share on other sites
+Roydea6 #18 Posted November 2, 2011 (edited) That Mem-Test is a .ATR. I can't get it to list a directory or show the MEMTEST file, so here's MEMTEST.COM file. I have dug through a bunch of .ATRs and extracted the memtest programs and made up an ATR with all the best. The file called PAGEMAP.COM is only a bload data program for one of the Atari basic programs. MEMRAMCHECKTEST.ATR Edited November 2, 2011 by rdea6 5 Quote Share this post Link to post Share on other sites
russg #19 Posted November 2, 2011 I'll have fun with those, thanks. Quote Share this post Link to post Share on other sites
w1k #20 Posted November 2, 2011 very good utils, thank you! Quote Share this post Link to post Share on other sites
Mathy #21 Posted November 2, 2011 Hello rdea6 The file called PAGEMAP.COM is only a bload data program for one of the Atari basic programs. PAGEMAP.COM is intended to be loaded by PAGEFIND.BAS, a VERY good test utility for extended memory. Mathy Quote Share this post Link to post Share on other sites
Osgeld #22 Posted July 27, 2017 (edited) I have dug through a bunch of .ATRs and extracted the memtest programs and made up an ATR with all the best. The file called PAGEMAP.COM is only a bload data program for one of the Atari basic programs. exttest.pnglamemem.pngMEMDRV.pngMEMTEST.pngRAMTEST.pngSHORT.pngSI2.EXE.pngXLTEST.pngXRAM.pngMEMRAMCHECKTEST.ATRmemcheck.png Necro bump, I just upgraded my 400 to "48" k and wanted to check the ram, and before I posted a new topic asking for some ram tests I did a little foo on google and bam here it is with a pile of programs I like more than one checker as a sanity test Thank you! PS: that quoted post would be a good link to have marked as a reference in one of the n00b stickies Edited July 27, 2017 by Osgeld 1 Quote Share this post Link to post Share on other sites
+toddtmw #23 Posted July 27, 2017 I have dug through a bunch of .ATRs and extracted the memtest programs and made up an ATR with all the best. The file called PAGEMAP.COM is only a bload data program for one of the Atari basic programs. This is an awesome compilation! Just what I was looking for! Thanks! 1 Quote Share this post Link to post Share on other sites
1050 #24 Posted July 27, 2017 Extest, my contribution above, has been upgraded in talents to properly detect rambo type banking scheme where 4 banks of system ram are in the extended memory reducing the overall size of usable ramdisk usage by those same 4 banks. The prior version above did not do this and gave an incorrect accounting of available banks on those machines. With source code here - http://atariage.com/forums/topic/256959-calling-on-1200xl-extended-memory-experts-for-help/page-2?do=findComment&comment=3600549 1 Quote Share this post Link to post Share on other sites
+Roydea6 #25 Posted July 28, 2017 (edited) Extest, my contribution above, has been upgraded in talents to properly detect rambo type banking scheme where 4 banks of system ram are in the extended memory reducing the overall size of usable ramdisk usage by those same 4 banks. The prior version above did not do this and gave an incorrect accounting of available banks on those machines. UPDATED:MEMRAMCHECKTEST.ATR with 1050's latest EXTEST.COM Edited July 28, 2017 by rdea6 5 Quote Share this post Link to post Share on other sites
