Willsy #1 Posted November 1, 2011 Anyone know what the current status is with this? Thanks Quote Share this post Link to post Share on other sites
lp060 #2 Posted November 2, 2011 Its not an OS, its just a Desktop. Like Thing, Jinee, TeraDesk, etc. Far as I know dead in the water as the author gave up on it. Quote Share this post Link to post Share on other sites
Christos #3 Posted November 2, 2011 I think the source is available though, for anyone interested in giving it a go. Quote Share this post Link to post Share on other sites
AtariSociety #4 Posted November 2, 2011 IMHO, this desktop is the slickest, most modern looking, coolest "possible" desktop I have seen in the Atari platform and is a shame it has stopped. I wish I was a programmer to help finish it but alas I am not even close. I hope some Atari fanatics that know programming pick this back up and finish it. Would be real nice to use on Firebee for example. I think there are a few things missing to help an older Atari more useful in this day and age. I will mention 2. #1 Need of a modern web browser that can handle most web sites of today. The new Firebee or faster clones should be able to handle them so would be nice to have a new browser. #2 More mature and useful desktop like this new zView I think they call it. Keeps fairly basic on appearance so it is not too much eye candy but I feel a step above what is already available, looks more modern, and has some nice windowing and tabbing features that look useful. I really like the looks of this new desktop and sorry to see the original programmer stop. 8-( tj Quote Share this post Link to post Share on other sites
Christos #5 Posted November 2, 2011 Netsurf should be able to view most of the websites. Quote Share this post Link to post Share on other sites
OldAtarian #6 Posted November 18, 2011 Netsurf should be able to view most of the websites. Where do you get it from? I went to the Netsurf website but can't find it in the download section. In the history it says an Atari port was made in Jan. 2011 so they should still have it in the download section if it's that recent, no? Quote Share this post Link to post Share on other sites
Christos #7 Posted November 18, 2011 (edited) http://nic-nac-proje...ari/netsurf.php It needs mint and rpm and ext2 partitions to work. An easymint setup should be ok. I think it needs lots of RAM too. Edited November 18, 2011 by Christos Quote Share this post Link to post Share on other sites
OldAtarian #8 Posted November 18, 2011 http://nic-nac-proje...ari/netsurf.php It needs mint and rpm and ext2 partitions to work. An easymint setup should be ok. I think it needs lots of RAM too. Is 2mb enough? A Mega ST 2 is the machine I have with the most RAM atm. I have a 1040STE I can upgrade with more if I have to. Quote Share this post Link to post Share on other sites
+DarkLord #9 Posted November 18, 2011 Not really. 4 megs will let you run MINT on a standard ST, but only a cut down/slimmed down version. Not sure it even has a normal desktop at that point. Will be a little bit slow without some kind of accelerator as well. Needs a higher end Atari... Falcon, TT, Falcon 060, Firebee, etc... Quote Share this post Link to post Share on other sites
Christos #10 Posted November 18, 2011 Not even enough to execute the binary I think. You could take a look at highwire. If you turn off images it would run. Quote Share this post Link to post Share on other sites
jens #11 Posted November 18, 2011 (edited) Afaik Highwire needs TOS 4.04, or MiNT, or Magic, and NVDI (3 or above), or SpeedoGDOS. I think with these specs we can talk about a four meg machine as minimum hardware. *edit* You might use Cab instead. *edit* Edited November 18, 2011 by jens Quote Share this post Link to post Share on other sites
OldAtarian #12 Posted November 19, 2011 Afaik Highwire needs TOS 4.04, or MiNT, or Magic, and NVDI (3 or above), or SpeedoGDOS. I think with these specs we can talk about a four meg machine as minimum hardware. *edit* You might use Cab instead. *edit* I have a copy of CAB, but still have no way to get online with an Atari. My internet connection is cable modem and I have no way to interface it to the ST. Quote Share this post Link to post Share on other sites
jens #13 Posted November 19, 2011 You can use STing with Slip to connect to a Linux box which will route you into the net. Here is a guide on how to configure both machines. Quote Share this post Link to post Share on other sites
+DarkLord #14 Posted November 19, 2011 I have a copy of CAB, but still have no way to get online with an Atari. My internet connection is cable modem and I have no way to interface it to the ST. Have you considered EtherNEC, NetUSB or Hydra? Or even setting up a connection through a modern PC? Quote Share this post Link to post Share on other sites
OldAtarian #15 Posted November 19, 2011 (edited) You can use STing with Slip to connect to a Linux box which will route you into the net. Here is a guide on how to configure both machines. Which might work if I had a machine running Linux. I have a copy of CAB, but still have no way to get online with an Atari. My internet connection is cable modem and I have no way to interface it to the ST. Have you considered EtherNEC, NetUSB or Hydra? Or even setting up a connection through a modern PC? I can't find anyone still making any of those devices and how do I route my internet connection through my PC? I don't have any port on my PC that coincides with any port on my ST to make the connection. Edited November 19, 2011 by OldAtarian Quote Share this post Link to post Share on other sites
Christos #16 Posted November 19, 2011 You can also do it with windows xp Quote Share this post Link to post Share on other sites
OldAtarian #17 Posted November 19, 2011 You can also do it with windows xp Does me no good if I have no way to make the physical connection between the machines. Quote Share this post Link to post Share on other sites
Christos #18 Posted November 19, 2011 (edited) No serial port? Then why are we discussing it? Anyway, I got an ethernec and I go online that way. The designs are free (as in free speech so no laws will be broken) and some people are selling such devices if you want to either build it or buy it. Edited November 19, 2011 by Christos Quote Share this post Link to post Share on other sites
OldAtarian #19 Posted November 19, 2011 (edited) No serial port? Then why are we discussing it? Anyway, I got an ethernec and I go online that way. The designs are free (as in free speech so no laws will be broken) and some people are selling such devices if you want to either build it or buy it. We're discussing it because the possibility of connecting through a PC was mentioned by another user above. When was the last time you saw a serial port on a modern PC? Also, I don't do electronics and as I said previously I haven't seen one for sale for a long time and then they are only available sporadically whenever someone feels like turning out a small batch and then they go fast. I can't find any Atari ethernet adapter of any kind for sale anywhere at the moment. Edited November 19, 2011 by OldAtarian Quote Share this post Link to post Share on other sites
Christos #20 Posted November 19, 2011 There are usb to serial adapters too... And anyway, you initially said your problem was not having linux, then not having serial ports and then that you are basically unwilling. So again, why are we discussing this? Quote Share this post Link to post Share on other sites
OldAtarian #21 Posted November 19, 2011 There are usb to serial adapters too... And anyway, you initially said your problem was not having linux, then not having serial ports and then that you are basically unwilling. So again, why are we discussing this? When did I ever say I was unwilling to do anything? I can't build an ethernet adapter for the ST because I don't know how, and I can't buy one because none are available to buy. In the same post where I said I didn't have a machine running Linux, I also mentioned that I didn't have, couldn't make, and can't find an adapter for the ST to connect to my ethernet. What part of that post didn't you understand? Quote Share this post Link to post Share on other sites
Christos #22 Posted November 19, 2011 http://www.freemint.org/ethernec/ethernec.html Quote Share this post Link to post Share on other sites
desiv #23 Posted November 19, 2011 I can't build an ethernet adapter for the ST because I don't know how Understand you there.. I wish I was a hardware person.. ;-( That said, the PC USB-to-serial adapters frequently sell for under $10 with shipping on e-bait... It's always nice to have one of those.. And you can make the connection on Windows as mentioned, but you can also just set up a VM on your PC to run Linux in. VirtualBox is free. Now, for totally USELESS internet connectivity :-), they sell serial-ethernet adapters. They were/are basically for managing remote devices where ethernet was available. I have one and have used it on my Amigas. The "neat" feature there is that the devices generally support DNS and "modem emulation." Also, there are still a number of BBSes out there, but available via telnet. So I fire up my Amiga 1000, launch JRComm, and type something like: atdt coolbbs.dyndns.org and it connects and I'm BBSing over the internet.. True, not what you asked for at all, but it's kind of fun.. Theoretically, if in Linux or Windows, you could set up a listener (getty or mgetty in Linux) to listen on a TCP port rather than a serial device, you could use it to SLIP "dial" into your Linux box via ethernet, but I haven't worked on that... My Amiga 1000 at the time didn't have the horsepower for even a SLIP TCPIP stack... (It does now, so I could look at that again maybe... I need more time...) Good Luck desiv Quote Share this post Link to post Share on other sites
OldAtarian #24 Posted November 19, 2011 WIll all this work with MultiTOS? I have a copy of that, too. Quote Share this post Link to post Share on other sites
+DarkLord #25 Posted November 19, 2011 MultiTOS is very uh...slow and buggy. I wouldn't fool with it, other than as a novelty. Quote Share this post Link to post Share on other sites
