Sign in to follow this
Larry
Turbo Basic XL and the 65816?
Does anyone have any experience running TBXL with the 65816 instead of the normal 6502?
With the 6502, TBXL works fine under Dos 2, Dos 2.5, and all versions of MyDos that I have tested (certainly 3.x and 4.5x).
With the 65816, TBXL continues to work under Dos 2.0/2.5, but fails to one degree or another under all versions of MyDos.
I realize that 65816's in our A8's are pretty scarce, but thought I'd ask (nothing ventured...).
-Larry
TBXL worked fine on my 65C816 Atari, when I had it. I of course only used it under SpartaDOS X, but that should not influence its general operation. Only BLOAD/BRUN instructions may fail under anything else than DOS 2.5, but this should always happen regardless of the CPU used.
TBXL is only sensitive to the math pack - if you replace the original math pack (in ROM) with the Fastchip, TBXL will fail.
Hi Drac030-
Thanks! The math pack might be a good clue. I'll check into that. The mode of failure is that it appears to load normally, setting up it's "splash screen" and continuing to load. But after loading, it returns to the Dup.Sys menu. But I'll also try SDX -- I haven't done that yet.
-Larry
Hi Gary-
I'm not quite sure what you mean. It fails while loading TBXL -- returns to MyDos Dup.Sys. I probably did not make that clear.
-Larry
OK... my theory was that MyDos might preserve PORTB state when doing Init/Run but probably not because it'd break a lot of stuff.
I thought it loaded totally, a partial load might mean that TBasic is unhappy about something and terminating the load process.
Are you doing this under emulation? If so, then you could upload an ATR and someone could take a look. Possibly TBasic requires certain memory requirements that MyDos isn't providing.
Yes, I've run TBXL with several different versions of MyDos and they all were just fine with 6502's.
There may be other issues.
@David_P -- I've since found that a "Sweet 16" board runs TBXL just fine, but this (different) board doesn't. So it's evidently not just the 65816. Today I'm going to trace the loads with Dos 2.0 (works) and MyDos (not).
@Drac030 -- this board uses the stock math pack.
-Larry
TBXL works with MyDOS just fine, in my experience. Would a 65816 "silently" mess with PORTB in any way?
Some progress -- MyDos 3.07 will load TBXL just fine. The 3.x versions could handle "large drives" but cannot navigate subdirectories.
Version 4.20 gives a clue. Midway through the load, it chokes and shows error 181 -- "Invalid address range for loading a binary file, end<beginning." After the error, it returns to Dup.Sys.
That address range certainly does not seem to be the case, since all of the load vectors are "legal."
-Larry
Is this the system with 16MB of memory?
Bob
-Larry
Hi Bob-
No, it's not that one...
Bob
More success!
I remembered that I had an old (1980's) 6-sector ".EXE game loader" that works with most any Dos.Sys, and presents the typical 0-9 selection menu for selection. Works very well with MyDos 4.0 and 4.5 (so far). It does not put up the "splash screen" while loading, but appears to load everything correctly and goes straight to the blue screen "TURBO" or "READY". In testing several BASIC progs, TBXL works just fine, and will exit properly to Dos.
This is probably as close as I'm going to get to a "fix."
-Larry
Larry,
I realize you have a valid work around, but did you try the obvious next step of creating a disk with just Dos.sys and naming TBXL as AUTORUN.SYS? I don't think it will save you anything. Just an additional step for completeness sake. Of course, you would lose the ability to exit to DOS.
No need to try, if you are not so inlcined.
Hi Kyley-
Thanks, I do appreciate the suggestion! I guess I hadn't mentioned it, but I had previously tried using TBXL as the Autorun.Sys for every version of MyDos that I had tested. It did work with version 3.x of MyDos, but not version 4.x, and I was really hoping for 4.x so that I could access subdirectories on my hard drive. You are quite right -- that is frequently a very good way to get around a program that can't be loaded from Dup.Sys.
As it stands now, I swap the hard drive to be D2: and boot from a floppy image with TBXL. MyDos 3.x probably works because it is much smaller than 4.x. IIRC, it is even smaller than Dos 2.0.
-Larry
Larry,
Yes, it's too bad that there haven't been more "Sweet-16" or "Turbo 816" type boards produced. I don't think that FTE ever produced/sold very many of them. I remember hearing that there were "issues" (?) with some of those boards, but I don't know what those issues were. OTOH, there isn't much "bang for the buck" by using a 65816 at the same clock speed except to find out how many things "break" when the 6502 is swapped out.
-Larry
I see. Sorry I can't be of more help then.
Obviously, the solution is to get more 65816 systems out in the wild...
Thanks, I hadn't tried that, but it fails, too -- goes back to Dup.Sys.
-Larry
you can try to rename the autorun.sys to AUTORUN.AR0 for mydos...
The 65816 does not generate PH02 timings for you, where the 6502 does. So, the interaction between the other chips and the 65816 are just enough different to cause problems with some ANTICS on the Sweet16. I think Larry's problem is similar, only with POKEY timings.
Bob
-Larry
