VicViper #1 Posted December 2, 2011 I'm having trouble with the sega master system phazer. I've bought two at this point, and both didn't work right- they would only register in the center of the screen, but not to the left or right. the only game I have is Rescue mission, could it be the game? or just bad luck? and before any one asks, no, I'm not using an LCD tv :/ Quote Share this post Link to post Share on other sites
DemonoidTentacle #2 Posted December 3, 2011 The problem is that these things are so darn simple. It's odd that it will only work in the middle of the screen. When you fire, does it at least register that you're firing? Quote Share this post Link to post Share on other sites
VicViper #3 Posted December 3, 2011 The problem is that these things are so darn simple. It's odd that it will only work in the middle of the screen. When you fire, does it at least register that you're firing? yes, the trigger works, and I can sort of hit stuff in the middle of the screen. I feel like maybe the eye inside is loose/out of position and that could be affecting the accuracy. I tried to take it apart but broke my screwdriver bit . Quote Share this post Link to post Share on other sites
zylon #4 Posted December 3, 2011 Try the other controller port. Quote Share this post Link to post Share on other sites
