linville Posted January 26, 2012 Share Posted January 26, 2012 Boisy, I'm eager to see the schematic for that CPU adapter, especially that clock circuit. Can you post a copy somewhere? Quote Link to comment Share on other sites More sharing options...
boisy Posted January 26, 2012 Author Share Posted January 26, 2012 John, I've uploaded a copy of the schematic to the gallery. This was designed by Gary Becker, and we discussed it last night via Skype. The circuit generates PHI1 and PHI2 from PHI0, and E and Q from a combination of /PHI_0 and RDY. The RDY line is gated to basically halt the processor by stopping the clocks. Comments would be appreciated. Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 26, 2012 Share Posted January 26, 2012 /RDY is available "on demand" by storing to the Wsync register on Antic. Will this cause any problems? Quote Link to comment Share on other sites More sharing options...
boisy Posted January 26, 2012 Author Share Posted January 26, 2012 /RDY is available "on demand" by storing to the Wsync register on Antic. Will this cause any problems? Interesting. So the 6502 can write to a register on the Antic and effectively halt itself? If that's the case, how does it get unhalted? Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 26, 2012 Share Posted January 26, 2012 It's temporary, released towards the end of a scanline. Nothing else generates it, so if it was a problem you could omit the connection from your design. But it is very useful for synchronising video changes to a known position. Quote Link to comment Share on other sites More sharing options...
boisy Posted January 26, 2012 Author Share Posted January 26, 2012 Rybags, got it. I think I'll keep it for now since it seems useful. Quote Link to comment Share on other sites More sharing options...
Shawn Jefferson Posted January 27, 2012 Share Posted January 27, 2012 Wsync is fundamental to the character of antic-i think you will want to keep it indeed. 1 Quote Link to comment Share on other sites More sharing options...
JamesD Posted January 27, 2012 Share Posted January 27, 2012 (edited) @boisy, and anyone else wanting to try this (boisy probably already remembers this) supposedly, the standard 6809s can only be safely halted around 13 clock cycles in a row or they can loose their register contents. I don't know how many clock cycles the Antic may steal so I'd stick with the 6309 since it doesn't have that problem. Frankly, I don't think I've ever read where someone verified the loss of register contents to be true but the 6309 is more powerful anyway. Interesting project. It would be nice to have both CPUs in the machine and to be able to select which one you want. There were some articles in MICRO about a 6809 board for the Apple II. The author of the article(s) found it was faster to send some math to the 6809 and recover the results than to do the math on the 6502. I don't remember what kind of math the author was dealing with. Edited January 27, 2012 by JamesD Quote Link to comment Share on other sites More sharing options...
netdude77479 Posted January 27, 2012 Share Posted January 27, 2012 Let me introduce myself. My name is Gary Becker. I am helping Boisy in his XEGS project. I have a lot of experience with the 6502, but it has been a few years ago. I do not have any experience with Atari's Sally version. I also have experience with the 6809E. I generated the schematic Boisy posted. I am now working on adapting other signals. I understand Sally has a Halt input. The Halt signal on the 6809E will tristate the address and data bus during the last cycle of the current instruction. I found some information on the Antic chip that gave me some information about the Halt signal and how DMA is accomplished. It appears to me the Antic will expect to be able to grab the bus on the next CPU cycle after asserting the Halt signal. Is this correct? That is not the way the 6809E will do it. It could be easily be 5 or more cycles before the 6809E goes into halt mode. Another question is with the clocks. The PHI 1 and PHI 2 clocks are output from the Sally chip, but the Q and E clocks are inputs to the 6809. During halt mode, does the Sally chip tristate these clocks? Sorry for having to ask so many questions on my very first post. I look forward to getting to know the Atari systems better. Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted January 27, 2012 Share Posted January 27, 2012 The 6502 starts each cycle with the 02 clock going low. The addresses set up and 02 goes high for the data transfer portion of the instruction. Then, it repeats. ANTIC asserts HALT somewhere around the rise of 02. The 6502 tri-states at the next fall of 02. ANTIC releases HALT somewhere around the rise of 02. The 6502 enables at the next fall of 02. Basically, you disable the CPU with a latch - data on HALT, clock on 02. Bob Quote Link to comment Share on other sites More sharing options...
UNIXcoffee928 Posted January 27, 2012 Share Posted January 27, 2012 ... I chose the XEGS because it was a system recommended to me by someone. I liked the cool look of the case and thought it would be a great system to start with. The 130XE was another one I considered, but the XEGS came up on eBay first for me. Hi, and welcome to the forum! Keep the XEGS for later. What you need for the initial stages of this project is an original Atari 800, not an XL, but the 800 with the slots. It will greatly simplify your testing, since the original 800 uses a plug-in CPU card. Quote Link to comment Share on other sites More sharing options...
boisy Posted January 27, 2012 Author Share Posted January 27, 2012 ... I chose the XEGS because it was a system recommended to me by someone. I liked the cool look of the case and thought it would be a great system to start with. The 130XE was another one I considered, but the XEGS came up on eBay first for me. Hi, and welcome to the forum! Keep the XEGS for later. What you need for the initial stages of this project is an original Atari 800, not an XL, but the 800 with the slots. It will greatly simplify your testing, since the original 800 uses a plug-in CPU card. You're the second person to indicate the XEGS probably wasn't the best first choice. Other than the 800 having a plug-in CPU card, are there other reasons? Differences in the processor? I've invested time and $$$ into the XEGS and really don't mind taking on the harder aspects of this project. Quote Link to comment Share on other sites More sharing options...
sloopy Posted January 27, 2012 Share Posted January 27, 2012 ... I chose the XEGS because it was a system recommended to me by someone. I liked the cool look of the case and thought it would be a great system to start with. The 130XE was another one I considered, but the XEGS came up on eBay first for me. Hi, and welcome to the forum! Keep the XEGS for later. What you need for the initial stages of this project is an original Atari 800, not an XL, but the 800 with the slots. It will greatly simplify your testing, since the original 800 uses a plug-in CPU card. You're the second person to indicate the XEGS probably wasn't the best first choice. Other than the 800 having a plug-in CPU card, are there other reasons? Differences in the processor? I've invested time and $$$ into the XEGS and really don't mind taking on the harder aspects of this project. Most 800's use a plain NMOS 6502, not the Atari Modified 6502C... so it would make a nice setup where you would be able to make a single replacement card that would plug right in, as the ANTIC/GTIA are on this card also... The XEGS probably isnt the best, but it doesnt really have any major disadvantage over a 130XE besides the ECI port... for the most part the basic system is the same between the 800XL/130XE/XEGS with the 800XL being the LCD, and the 130XE and XEGS expanding on it in two different ways... sloopy. Quote Link to comment Share on other sites More sharing options...
sloopy Posted January 27, 2012 Share Posted January 27, 2012 Also in this thread: http://www.atariage.com/forums/topic/96927-xlxe-compatible-atari-800/page__view__findpost__p__2453510 Mimo has made pics of the 800 CPU card, and the 'Personality' card (which is where the OS is...) to give you an idea of what they look like... sloopy. Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 27, 2012 Share Posted January 27, 2012 You can potentially have 97, possibly more, consecutive /Halt cycles. As stated before, they take effect mid-instruction. Re choice of machine, I don't think it matters that much. If you use a ribbon cable to the CPU socket then swapping the board is just as easy. The XEGS takes seconds to pull apart, and you can do away with the metal shielding to make access easier. Additionally, if he goes and buys an 800, there's no guarantee it's going to be a plain 6502 variant. Quote Link to comment Share on other sites More sharing options...
netdude77479 Posted January 28, 2012 Share Posted January 28, 2012 The 6502 starts each cycle with the 02 clock going low. The addresses set up and 02 goes high for the data transfer portion of the instruction. Then, it repeats. ANTIC asserts HALT somewhere around the rise of 02. The 6502 tri-states at the next fall of 02. ANTIC releases HALT somewhere around the rise of 02. The 6502 enables at the next fall of 02. Basically, you disable the CPU with a latch - data on HALT, clock on 02. Bob Thanks for the info Bob. I believe I understand the timing. The Halt signal on the 6809E will not work for this, but there is a tristate pin I can use. When you mentioned the rise and fall of 02, does that mean Sally continues to drive the clocks? Or do you mean 00. the input clock to Sally which is nearly identical to 02? Gary Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted January 28, 2012 Share Posted January 28, 2012 Sally drives 02 all the time - it is the system clock, actually. 00 is skewed from 02 by about 50ns and is not used anywhere that I can see. 01 is only used for a voltage doubler circuit that feeds 10v to the GTIA color phasing pot. You can use any of the 1.79MHZ signals for that. 02 does all the heavy lifting. Bob The 6502 starts each cycle with the 02 clock going low. The addresses set up and 02 goes high for the data transfer portion of the instruction. Then, it repeats. ANTIC asserts HALT somewhere around the rise of 02. The 6502 tri-states at the next fall of 02. ANTIC releases HALT somewhere around the rise of 02. The 6502 enables at the next fall of 02. Basically, you disable the CPU with a latch - data on HALT, clock on 02. Bob Thanks for the info Bob. I believe I understand the timing. The Halt signal on the 6809E will not work for this, but there is a tristate pin I can use. When you mentioned the rise and fall of 02, does that mean Sally continues to drive the clocks? Or do you mean 00. the input clock to Sally which is nearly identical to 02? Gary Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted January 28, 2012 Share Posted January 28, 2012 I replaced the 65C02 with a 65C816 and just latched HALT on the fall of 02, killed the 02 clock only to the CPU and de-gated the bus. Worked fine. Can you hold 02 down for long periods on the 6809E? Bob The 6502 starts each cycle with the 02 clock going low. The addresses set up and 02 goes high for the data transfer portion of the instruction. Then, it repeats. ANTIC asserts HALT somewhere around the rise of 02. The 6502 tri-states at the next fall of 02. ANTIC releases HALT somewhere around the rise of 02. The 6502 enables at the next fall of 02. Basically, you disable the CPU with a latch - data on HALT, clock on 02. Bob Thanks for the info Bob. I believe I understand the timing. The Halt signal on the 6809E will not work for this, but there is a tristate pin I can use. When you mentioned the rise and fall of 02, does that mean Sally continues to drive the clocks? Or do you mean 00. the input clock to Sally which is nearly identical to 02? Gary Quote Link to comment Share on other sites More sharing options...
netdude77479 Posted January 28, 2012 Share Posted January 28, 2012 Thanks again Bob. 01 and 02 driven from the circuit to the main board is not stopped. The Q and E clocks driven to the 6809E are stopped for the RDY signal. I believe the RDY is not needed. It might cause issues with the 6809E if RDY is asserted for long enought time. It looks like the Halt can be directly connected to the 6809E TSC (tristate) pin. This will tristate the address and data buses for a cycle or longer. Gary Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 28, 2012 Share Posted January 28, 2012 If you can tristate it, then shouldn't that mean it's effectively suspended in similar manner to /RDY anyway? Although with the 6502, /RDY isn't effective immediately, but if you were to implement it in some fashion the timing difference vs 6502 shouldn't matter since there's not really a codebase to support yet. Quote Link to comment Share on other sites More sharing options...
netdude77479 Posted January 28, 2012 Share Posted January 28, 2012 One use for the /RDY pin is to streach accesses to slow devices. During the time /RDY is asserted, the 6502 address, R/W, and data bus on writes is kept enabled. The 6809E does not have a /RDY pin, so my method of adding this feature was to stop the clock going to the 6809E. If I used the 6809E TSC, the buses would go away. The 6809E /HALT pin was not usable either. It only stops execution during the last cycle of the instruction. Gary Quote Link to comment Share on other sites More sharing options...
boisy Posted January 29, 2012 Author Share Posted January 29, 2012 An update... I'm about three wires away from having the prototype completely wired up. After that I will do a complete design review and continuity check before actually trying it out. I've also converted the OSTest3 that Rybags posted to 6809 assembly. I think I've made the translation right and am posting the output of the mamou assembler here as an attachment. If anyone knows both the 6502 and 6809, please review. Quote Link to comment Share on other sites More sharing options...
boisy Posted January 29, 2012 Author Share Posted January 29, 2012 Ok, I am at a loss on how to upload an assembly language source file on this forum. I've spent the last 10 minutes monkeying around the website trying to figure it out. I'm just going to post it here. The Mamou Assembler Version 01.00 01/29/2012 11:23:46 Page 001 00001 F000 org $F000 00002 00003 reset 00004 F000 1CAF andcc #~$50 mask inter 00005 F002 10CE00FF lds #$00FF set stack 00006 00007 F006 5F clrb 00008 cleario 00009 F007 8ED000 ldx #$D000 00010 F00A 6F85 clr b,x 00011 F00C 8ED200 ldx #$D200 00012 F00F 6F85 clr b,x 00013 F011 8ED300 ldx #$D300 00014 F014 6F85 clr b,x 00015 F016 8ED400 ldx #$D400 00016 F019 6F85 clr b,x 00017 F01B 5C incb 00018 F01C 26E9 bne cleario 00019 F01E 8603 lda #3 00020 F020 B7D20F sta $D20F set POKEY 00021 00022 * delay POKEY (possibly not needed) 00023 delay 00024 F023 1F01 tfr d,x 00025 subloop 00026 F025 830001 subd #$0001 00027 F028 26FB bne subloop 00028 00029 * setup DLIST ptr 00030 F02A BEF062 ldx >dlist 00031 F02D EC84 ldd ,x 00032 F02F F7D402 stb $D402 00033 F032 B7D403 sta $D403 00034 F035 8622 lda #$22 00035 F037 B7D400 sta $D400 DMA mode n 00036 F03A 86F0 lda #$F0 00037 F03C B7D409 sta $D409 CHBase at 00038 F03F 86A0 lda #$A0 00039 F041 B7D200 sta $D200 00040 F044 86A1 lda #$A1 00041 F046 B7D202 sta $D202 set audf1 00042 F049 4F clra 00043 F04A B7D01A sta $D01A color bord 00044 F04D 8682 lda #$82 00045 F04F B7D018 sta $D018 color back 00046 F052 86CA lda #$CA 00047 F054 B7D017 sta $D017 PF1 color 00048 00049 F057 86A8 lda #$A8 00050 F059 B7D201 sta $D201 00051 F05C B7D203 sta $D203 set audc1 00052 00053 F05F 7EF05F wait jmp wait loop forev 00054 00055 dlist 00056 F062 70707070 fcb $70,$70,$70,$70 00057 F066 42 fcb $42 00058 F067 F06F fdb screen1 00059 F069 42 fcb $42 00060 F06A F06F fdb screen1 The Mamou Assembler Version 01.00 01/29/2012 11:23:46 Page 002 00061 F06C 41 fcb $41 00062 F06D F062 fdb dlist 00063 screen1 00064 F06F 00010203 fcb 0,1,2,3,4,5,6,7,8,9 00065 F079 0A0B0C0D fcb 10,11,12,13,14,15,16,17,18,19 00066 F083 00010203 fcb 0,1,2,3,4,5,6,7,8,9 00067 F08D 0A0B0C0D fcb 10,11,12,13,14,15,16,17,18,19 00068 00069 00070 FFDE org $FFDE 00071 FFDE F000 fdb reset 00072 Assembler Summary: - 0 errors, 0 warnings - 72 lines (60 source, 10 blank, 2 comment) - $0099 (153) bytes generated - No output file Quote Link to comment Share on other sites More sharing options...
boisy Posted January 29, 2012 Author Share Posted January 29, 2012 An update: I found a few errors in the assembly language above and have corrected them. I've also verified that the code is in the correct offset in the $8000 sized ROM file that I'm uploading to the ROM emulator. I've wired up the board, did final design checks and missed a few things, so fixed those up and gave it the big test... loaded up the translated 6809 code into the ROM emulator, plugged in the satellite board with the 6809E socketed, and... Nothing. Well, not quite. I get a funky green screen but no sound or video like I do with the 6502C and the test ROM… Remove the satellite board, put the 6502C back in, load the ROM emulator with the OSTest3 code and it comes up with the graphic and sound. So everything is still working. At least nothing is blown up or burnt. At this point I'm not sure if the '09 is coming to life or not. I don't have a scope, so I'm pretty much dead without one. It's time I get one though. This may be the impetus. Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 29, 2012 Share Posted January 29, 2012 Black screen should be the first sign of life since we write zeros to the I/O area. But that's often the default (background usually starts black or brown) - you could change that e.g. with lda #$c6 / sta $d01a after the cleario loop ( $c6 = medium green) Quote Link to comment Share on other sites More sharing options...
