+Vorticon Posted March 17, 2015 Share Posted March 17, 2015 Actually, you could add UNITS to UCSD Pascal to cover most of the machine-dependent functionality. TI did that for their IV.0 (99/4A) and IV.11 (99/8) implementations. It also allowed use of Assembly modules and I'm pretty sure you could swap modules on the fly too--that was all part of the UCSD IV environment. Apple's implementations were based on the earlier I.x and II.x versions of UCSD (ISTR I.5, II.0, and II.1). There is even a TI module out there to allow Pascal code using Apple's TURTLEGRAPHICS extensions to be run on the TI. Yes indeed. Many graphical libraries and other supports were written for the UCSD Pascal on the TI. Not sure about the speed issue as compared to other high level languages, but I guess I'll find out Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 17, 2015 Share Posted March 17, 2015 You can change the ScrollLock key to any other key: http://www.ninerpedia.org/index.php/Change_MESS_menu_mode_key Check the file mess.ini for the entry "uimodekey". Maybe there is something similar in QMC2. Edit: In the configuration tab of QMC2 on the right side, find "Keyboard mapping", unfold it, and there is "uimodekey". Replace SCRLOCK by another name you can take from the above location on ninerpedia. Well, there is no mess.ini file anywhere in the MESS directory, the QMC2 version 0.49 configuration does not have a keyboard mapping option... This is really frustrating. Why the hell does the MESS team insist on using an obsolete key anyway??? In any case, I went ahead and connected an external keyboard with a scroll lock key and managed to set the dip switch on the p-code. Now the system boots appropriately into the p-code environment, but there is a new issue: The emulation crashes if I have any other disk than the Editor/Filer disk image in floppy drive 1. And even then, all the other floppy drives have to also be empty. This is of course through QMC2. Not sure if this is an issue with the frontend software or with the p-code emulation itself. I know for a fact that the other p-code disk images I have for the compiler and assembler are good because I am able to access them via the Classic99 p-code emulation. I need to have at least the compiler disk and a work disk in the other drives for efficient coding... Any ideas? Quote Link to comment Share on other sites More sharing options...
+mizapf Posted March 17, 2015 Share Posted March 17, 2015 No keyboard mapping? Have a look at my screenshot below - this is also 0.49 (with MESS 0.155). The mess.ini file should be in the mess folder, but only if you created it with the command line option "-createconfig". This file is pretty important when you want to set up a persistent configuration; otherwise, either the defaults are used, or you have to supply the settings when launching MESS (which is done by QMC2). I thought mess.ini would be created by QMC2 as well. The usage of this obsolete key by default is not bad as such. What key would you assign to switch between the two keyboard modes? You cannot use the F1-F10 keys because many of them are predefined in the partial mode (for making screenshots or chaning emulation parameters). Also, keyboards look different. On laptops you don't have a separate number pad, hence those keys are no choice either. The reason for ScrollLock is simply because no one has suggested a better key yet. But as I said, at least you can define another menu key if you need to. Concerning the disk issue, I have to admit I did not really try it. I just noticed that my new floppy support (hfdcnew) has a problem with the UCSD Pascal disks ; I'm getting an error and the emulation crashes. You must use the legacy implementation of the HFDC (slot option "hfdc"). With that I was able to launch the P-System with the compiler disk in drive 1. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 17, 2015 Share Posted March 17, 2015 I assure you there is no keyboard mapping tab: QMC2 apparently did not create a mess.ini file, so I created it from the command line using the -createconfig switch as you instructed, but it still did not have a keyboard mapping option either! I tried adding a uimodekey entry, and it had no effect... I am using the 64bit version of MESS 0.159, which is newer than the one you are using. I did switch the disk controller to the legacy one and that solved the disk issues. I finally have a functional p-code system running! I need a stiff drink... Quote Link to comment Share on other sites More sharing options...
+mizapf Posted March 17, 2015 Share Posted March 17, 2015 (edited) Ehm ... just noticing one thing: # # SDL KEYBOARD MAPPING # keymap 0 keymap_file keymap.dat uimodekey SCRLOCK in the mess.ini file ... "SDL" ... this only applies to Linux and OSX (at this time; it is planned to port that to Windows). I'll have to ask the others what to do for MESS in Windows. Edit: Try this: http://www.mess.org/faq#for_some_reason_esc_does_not_quit_mess_nor_does_tab_bring_up_the_menu Edited March 17, 2015 by mizapf Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 17, 2015 Share Posted March 17, 2015 Edit: Try this: http://www.mess.org/faq#for_some_reason_esc_does_not_quit_mess_nor_does_tab_bring_up_the_menu That did it! I'm using the tilde key instead of scroll lock. Thanks for help Quote Link to comment Share on other sites More sharing options...
+mizapf Posted March 17, 2015 Share Posted March 17, 2015 I found the problem with the new floppy system: I relied too much on the entries in sector 0 (VIB). The UCSD Pascal disks do have a VIB, but it is incomplete. The number of heads and sectors is 0, and well, you guess ... some division ... I just added a sanity check which treats the VIB as non-existent when it is incomplete. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 17, 2015 Share Posted March 17, 2015 Excellent! So how do I update my MESS installation? Quote Link to comment Share on other sites More sharing options...
+mizapf Posted March 17, 2015 Share Posted March 17, 2015 Only if you pull the source code from github and build yourself; otherwise you have to wait until 0.160. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 18, 2015 Share Posted March 18, 2015 Well, I may have celebrated too fast. I just noted as I was entering test code in the p-code editor (MESS p-code emulation) that the minus (-) key is not registering with either the laptop keyboard or an external keyboard. I can fix this by switching from emulated to natural keyboard, but then the ctrl functions of the p-code stop working. This is a pretty important key I should think... Michael, have you encountered this issue before? Quote Link to comment Share on other sites More sharing options...
+mizapf Posted March 18, 2015 Share Posted March 18, 2015 If you have trouble with keys, open the menu (in your case, ~, then TAB), check "Input (this system)" and look for the key that holds the minus character. Try to set it (Return, then press the key). If it does not work, the key may be dead (by definition from the OS, not by hardware); you can try to assign another key for it. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 18, 2015 Share Posted March 18, 2015 I see... It's not exactly an intuitive layout: - is shift -, / is - , alt Z is \, alt U is _ etc... Reminds me of the overloaded keys of the handheld computers of old... What I might do is wire up a real TI keyboard to an Arduino (Teensy ++2) and customize the key codes so they match what MESS expects. That way it will be seamless to me as if I was typing on a real TI. Fun little project Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 18, 2015 Share Posted March 18, 2015 I see... It's not exactly an intuitive layout: - is shift -, / is - , alt Z is \, alt U is _ etc... Reminds me of the overloaded keys of the handheld computers of old... What I might do is wire up a real TI keyboard to an Arduino (Teensy ++2) and customize the key codes so they match what MESS expects. That way it will be seamless to me as if I was typing on a real TI. Fun little project Those are the TI mappings, Walid, with the Alt key as FCTN. ...lee Quote Link to comment Share on other sites More sharing options...
+mizapf Posted March 18, 2015 Share Posted March 18, 2015 I know that the "natural keyboard" looks much easier to use, but it is also funny to see how fast you can get used to the emulated keyboard with the TI mapping. I have to take care not to type AltGr-P on the PC to get quotes. :-) The problem with the natural keyboard is not only that it is much slower (don't ask me - I did not write that part in the MAME kernel) but that it must somehow map a PC key to one or more TI keys; and it gets worse when you have a n:m mapping, e.g. when you want to use the "Del" key and F1 and AltGr-1 in the same way. But I agree, when I tried my TI keyboard to USB adapter, it is indeed fun to use it together with MESS; you soon forget that you have an emulation. 2 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 18, 2015 Share Posted March 18, 2015 Those are the TI mappings, Walid, with the Alt key as FCTN. ...lee Yes they are, but when using a PC keyboard they are totally unnatural Which is why I'm going to look at converting a TI keyboard to USB and use it with MESS. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 18, 2015 Share Posted March 18, 2015 Yes they are, but when using a PC keyboard they are totally unnatural Which is why I'm going to look at converting a TI keyboard to USB and use it with MESS. Can you not use the “Natural” keyboard mode? ...lee Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 18, 2015 Share Posted March 18, 2015 Can you not use the “Natural” keyboard mode? ...lee I tried, but then things like ctrl-C are not recognized by the p-code emulation. This command is vital to change editing modes in the editor... Quote Link to comment Share on other sites More sharing options...
+mizapf Posted March 18, 2015 Share Posted March 18, 2015 (edited) I tried, but then things like ctrl-C are not recognized by the p-code emulation. This command is vital to change editing modes in the editor... Yes, this is the big shortcoming of the natural keyboard. It is quite simple to define F4 (PC) as Fctn-4 (TI): When F4 is pressed, the natural keyboard pretents that both Fctn and 4 are pressed. When Del is pressed, we can make both Fctn and 1 be detected as pressed. You see that MESS's duty is to translate the natural keyboard presses to line states of the 9901 interface. This is a typical definition of an input line in MESS: PORT_START("COL4") // col 4 PORT_BIT(0x80, IP_ACTIVE_LOW, IPT_KEYBOARD) PORT_CODE(KEYCODE_B) PORT_CHAR('b') PORT_CHAR('B') PORT_BIT(0x40, IP_ACTIVE_LOW, IPT_KEYBOARD) PORT_CODE(KEYCODE_T) PORT_CHAR('t') PORT_CHAR('T') PORT_CHAR(']') ... If the core detects a KEYCODE_B in the emulated keyboard mode, the leftmost bit in column 4 is set. The keycode is actually the key on the PC keyboard (which can be accompanied by modifier keys). The next entries are used by the natural keyboard. The main idea of the natural keyboard is that a key on the PC keyboard should be appropriately mapped to the TI keys. If you press arrow left, you expect a reaction like Fctn-S. If I press AltGr-7, I expect a left brace. You certainly don't, because you might not have a German keyboard, so your brace is somewhere else. Accordingly, the natural keyboard uses characters and not raw keycodes, defined by PORT_CHAR in the shown lines. The input subsystem loops through all options of all lines. The first is without modifiers, the second is with Shift, the third (if available) is with Fctn. In the third line you see such a case. When it detects a right bracket, it signals bit line 0x40 and assumes that Fctn was also pressed; this is defined in another line. So you can now guess what is the problem. We just cannot map Ctrl-C because there is no character on the PC side that can be sent to the input core. Edited March 18, 2015 by mizapf Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 19, 2015 Share Posted March 19, 2015 Michael, is there an rpk repository somewhere available, at least for XB and EA? Quote Link to comment Share on other sites More sharing options...
RobertLM78 Posted March 19, 2015 Share Posted March 19, 2015 Michael, is there an rpk repository somewhere available, at least for XB and EA? You mean something like this? Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 19, 2015 Share Posted March 19, 2015 Damn! I really need to start looking at the Whtech site more carefully. Thanks for the tip. 1 Quote Link to comment Share on other sites More sharing options...
RobertLM78 Posted March 19, 2015 Share Posted March 19, 2015 No problem, bud - don't forget about the sitelist on there too Quote Link to comment Share on other sites More sharing options...
+mizapf Posted March 19, 2015 Share Posted March 19, 2015 Michael, is there an rpk repository somewhere available, at least for XB and EA? As already said above, all on WHTech. I think some time we need a guidance through that server, maybe by HTML pages with appropriate links. I already started with such a page on http://ftp.whtech.com/info/geneve.html (important: ftp server, but http schema!) I would suggest to also think about using the zip cartridges. Most of the RPKs are also available as ZIP files. The difference between both is that the ZIP versions can be selected via MESS using a built-in software list, you don't have to provide a file name, only the program name. And the ZIP support comes from the MAME core, while the RPK support is a prior concept which is quite lonely inside the MESS world, namely only available for the TI emulation. I insisted to retain it because in the meantime, when the others finally came up with the ZIP support, we got used to the RPKs, and they do their job pretty well. From the command line, instead of "-cart extended_basic.rpk" or "-cart editor_assembler.rpk" you would write "-cart exbasic" or "-cart editass". In QMC2 there is a software list selection. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 19, 2015 Share Posted March 19, 2015 Good to know. It looks like the whtech site has the zip versions as well. And yes, it would definitely be nice to have easier access to that site. EDIT: Actually it looks like QMC2 did not like the zip files... Rpk worked just fine. Quote Link to comment Share on other sites More sharing options...
apersson850 Posted March 19, 2015 Author Share Posted March 19, 2015 The ability to link to separatly compiled units in Turbo Pascal 4 is actually a copy of what's available in UCSD Pascal IV.0. UCSD was available before Turbo in this case. Quote Link to comment Share on other sites More sharing options...
