Marius Posted February 6, 2012 Share Posted February 6, 2012 In my Atari I replaced the Basic chip with the Synassembler Rom. Sometimes I need basic, and I don't want to boot Turbo Basic. Is there a working binary of disk version of Basic Rev. C? That would be awesome. Thanks Marius Quote Link to comment Share on other sites More sharing options...
Rybags Posted February 6, 2012 Share Posted February 6, 2012 (edited) Unsure - from what I've heard there's a patcher out that copies Rev B to ROM and applies the C fixes but that's not useful to you. To run an 8K language image you need a CASINI routine that switches the ROM out when the user hits Reset. By leaving the ROM switched in, that prevents the screen from overwriting the top 1K of the RAM copy of Basic. I did something for the AsmEd image that leaves Basic in and allows switching between the 2. Mine had the Casini routine sitting around $9B00 though which is not real safe since any screen open for a graphics mode > 1K would wipe it. Best idea would probably to have the Casini routine near the bottom of the stack. It should only take about 30-60 bytes of programming but needs to be kept safe because if wiped the machine will lockup on Reset. Here's the code I use to allow swapping between the Basic ROM and AsmEd based in RAM: 9B81 LDA $D20F ;SKSTAT 9B84 AND #$08 9B86 STA $04 ;RAMLO 9B88 BNE $9B92 9B8A LDA $9B80 9B8D EOR #$02 9B8F STA $9B80 9B92 LDA $9B80 9B95 AND #$02 9B97 STA $9B80 9B9A LDA $D301 ;PORTB 9B9D AND #$FD 9B9F ORA $9B80 9BA2 STA $D301 ;PORTB 9BA5 LDA #$12 9BA7 STA $02D9 ;KRPDER 9BAA LDA #$03 9BAC STA $02DA ;KEYREP 9BAF JSR $9BBD 9BB2 LDA #$03 9BB4 STA $09 ;BOOT 9BB6 LDA $04 ;RAMLO 9BB8 STA $08 ;WARMST 9BBA JMP ($BFFA) 9BBD JMP ($000C) ;DOSINI 9BC0 LDA #$9B 9BC2 STA $0345 ;B0-ICBAH 9BC5 LDA #$0C 9BC7 STA $034A ;B0-ICAX1 9BCA STA $034B ;B0-ICAX2 9BCD JSR $E456 ;CIOV 9BD0 RTS Here's the executable - asm.xex Edited February 6, 2012 by Rybags Quote Link to comment Share on other sites More sharing options...
+Larry Posted February 6, 2012 Share Posted February 6, 2012 Yes, there are bload versions of Basic-C floating around. If you have a PILL or such that is a really good alternative, since then the "cart" will survive a reset. Alternatively, you could put in a 27256 (or more) with multiple progs using a switch. Lots of alternatives. -Larry Quote Link to comment Share on other sites More sharing options...
sloopy Posted February 6, 2012 Share Posted February 6, 2012 Maybe better idea to make your internal 'BASIC' ROM swappable from synassembler and BASIC, or use a cart... cart would take the slot, but a switched ROM, would be best... and easy to do. if you used something like http://store.go4retro.com/2364-adapter/ this from Jim Brain, you could switch 8 different ROMs... sloopy. Quote Link to comment Share on other sites More sharing options...
Marius Posted February 6, 2012 Author Share Posted February 6, 2012 @sloopy Usually I would agree with that, but I did not mention it... but my Basic Rom is 'replaced' by the Ultimate 1MB. I flashed Synassembler in the Basic slot. Unfortunately the Ultimate 1MB does not let me switch between Missile Command and "Basic" slot. (Why In the world did candle not built that feature in?!?!). I use Synassembler 99% ... but sometimes I need basic. I don't want to boot Turbo Basic for that. Too much. So a binary of basic is a good alternative. Yes a Cart would do too... but I know myself: when I need such a cart, I can't find it... and a file is always there where I need it: on my harddisk. Thanks for all your help folks! I'm on my work now, so I can not reply to anything (no time) but when I'm at home tonight... I will reply on more things! Quote Link to comment Share on other sites More sharing options...
+rdemming Posted February 6, 2012 Share Posted February 6, 2012 but my Basic Rom is 'replaced' by the Ultimate 1MB. I flashed Synassembler in the Basic slot. Unfortunately the Ultimate 1MB does not let me switch between Missile Command and "Basic" slot. (Why In the world did candle not built that feature in?!?!). I'm just thinking, when having an XL/XE and the Ultimate 1MB: If you flash the XEGS OS rom (rev 4) and set the P3 (XEGS) jumper, can you hold <SELECT> while turning on to boot Missile Command just as a regular XEGS? Then you could replace Missile Command with SynAssembler. Robert Quote Link to comment Share on other sites More sharing options...
Rybags Posted February 6, 2012 Share Posted February 6, 2012 In theory, the Diag OS might be able to be replaced with 2 8K ROM images. Then a program could temporarily switch that OS in and copy one to RAM then switch the normal OS back in. http://www.spiflash.org/block/20.html Quote Link to comment Share on other sites More sharing options...
sloopy Posted February 6, 2012 Share Posted February 6, 2012 The benefits of owning an XEGS :') sloopy. Quote Link to comment Share on other sites More sharing options...
Rybags Posted February 6, 2012 Share Posted February 6, 2012 I suspect the Missile Command ROM can be gotten at on other machines. Might have to have a play around. Quote Link to comment Share on other sites More sharing options...
russg Posted February 6, 2012 Share Posted February 6, 2012 (edited) BASIC C, binary load.BASICC.zip You can enter DOS, then RUN A000 to get back to BASIC. You have to have internal A000 off, hold OPTION at boot. Edited February 6, 2012 by russg Quote Link to comment Share on other sites More sharing options...
trub Posted February 6, 2012 Share Posted February 6, 2012 (edited) You will find file based Atari Basic (ABASIC) on my site (load with X from SDX) Edited February 6, 2012 by trub Quote Link to comment Share on other sites More sharing options...
