19Echo #1 Posted February 27, 2012 is it possible to make? I thought it would easy enough to hack 2 cables. one half of a cable was used for my apelink. so i thought i could just slice another cable and solder the other half into it. Needless to say, it didnt work. I hooked one end up to the computer, the other end to a disk drive and the other end to an 850. The first drive worked, anything coming out the 850 didnt. Quote Share this post Link to post Share on other sites
sloopy #2 Posted February 27, 2012 Have to make sure your Data In and Data Out are connected correctly... and unless you are going to be using SIO powered devices, pins 3, 4, 5, 7 are all you need to connect... (Data In, GND, Data Out, /Command) and be CAREFUL with pin 10... It has power on it... sloopy. Quote Share this post Link to post Share on other sites
19Echo #3 Posted February 27, 2012 i may have criss crossed a wire or something. I took 2 cables that had the atari logo on them (i think) so i was under the assumption that the wires were the same. I basically soldered all wires together. Ill dig a little deeper on the end and take another look. thanks Quote Share this post Link to post Share on other sites
sloopy #4 Posted February 27, 2012 then swap the conns... take the SIO out of the A8 and the 1050, and swap them... and it should work... sloopy. Quote Share this post Link to post Share on other sites
Gunstar #5 Posted February 27, 2012 This may help you out, make sure you read the note at the top of the page. Quote Share this post Link to post Share on other sites
Creature XL #6 Posted February 27, 2012 Wich such a cable I could use Aspeqt and my new DRive together? How would the drive numbers be assigned? Is it enough to use drives 5-8 in Aspeqt? Quote Share this post Link to post Share on other sites
Rybags #7 Posted February 27, 2012 Device numbers have nothing to do with cabling, they're assigned at the device. Ape/Aspeqt lets you assign any of D1-D8 so it's up to you to decide what any real drive has, but most only do D1-D4. Quote Share this post Link to post Share on other sites
Fox-1 / mnx #8 Posted February 27, 2012 is it possible to make? As long as it's correctly wired (1:1) it works. Did the same years ago., The first drive worked, anything coming out the 850 didnt. My experience is that an 850 (at least the ones I have) is a big load on the SIO bus compared to a 1010/1050. With a single chain I can connect 7 or 8 disk drives without problems but when an 850 is part of the chain only up to 3 disk drives work reliable. However I'm in doubt this applies to your case, just keep it in mind :-) Quote Share this post Link to post Share on other sites
+wood_jl #9 Posted February 27, 2012 (edited) I think a 3-way SIO port adapter (like the Quintopus but 8 are not necessary anymore) would be a nice project. I wish Atarimax would make. He has his own source of white SIO ports and it would be great for all the users of dead-end SD card drives. Maybe no market. I put the Sdrive/SIO2SD after the 850 to use the printer. I use 1010 in-line for cassette. For SIO2PC, I use PC printer. Now he sells SIO2PC with daisy chain port, too. Edited February 27, 2012 by wood_jl Quote Share this post Link to post Share on other sites
Mathy #10 Posted February 28, 2012 (edited) Hello guys Check out the Automatic Two-Computer Interface, by the guys who made the SIO2USB (to USB devices, not SIO2PCviaUSB). It works with everything, but SIO2USB (the latter uses the clock signal, which the A2CI doesn't pass along). Mathy PS for some reason, I can't hide the link, so here it is: http://www.mathyvannisselroy.nl/special%20stuff.htm#nice_hardware Edited February 28, 2012 by Mathy Quote Share this post Link to post Share on other sites
+bf2k+ #11 Posted February 28, 2012 I think a 3-way SIO port adapter (like the Quintopus but 8 are not necessary anymore) would be a nice project. You can get a Eas I/O spider which has SIO ports for CPU and 3 peripherals from Rick at MorethanGames. Quote Share this post Link to post Share on other sites
Gunstar #12 Posted February 28, 2012 (edited) I think a 3-way SIO port adapter (like the Quintopus but 8 are not necessary anymore) would be a nice project. You can get a Eas I/O spider which has SIO ports for CPU and 3 peripherals from Rick at MorethanGames. Or the Apelink from Best Electronics, they are the same thing, except Apelink is a kit you have to put together. I think the spider you can buy complete or in kit form? 19Echo already has the Apelink, but during it's construction he ended up with half an SIO cord with the configuration he chose, so he's doing the 'Y' cable to make use of the other half and essentially regain the lost cable used in the Apelink construction. Edited February 28, 2012 by Gunstar Quote Share this post Link to post Share on other sites
+Guitarman #13 Posted February 28, 2012 The SIO Y cable is definitely doable. I have one that was a 3rd party cable from back in the day and it works great, especially when using 1 for your drive chain and one for a piece of hardware without a passthru. Quote Share this post Link to post Share on other sites
+Roydea6 #14 Posted February 28, 2012 I found this article from the newsgroups: <quote name='newsgroups'> Paul Alhart who published a neat and cheap alternative in AIM magazine way back when. You lay two SIO cables side by side and strip about a foot of cover off each one, starting about 8 inches from the paired ends, uncovering towards the center. You then bunch the foot of uncovered wire together so as to expose/create a large ball of wires on each cable. You then find and combine each color of wire with a few tight twists. Then at each twist, you apply a soldering iron to melt away the insulation, apply some flux and then solder the same colored wires together. Make these connections all along the way of the bared one foot of wire such that no connection can touch any other. Tape each connection with electrical tape, then tape the whole bundle leaving out the ground wires. I cut the ground wires in the middle and fold them back to then wrap the main portion with aluminum foil and integrate the ground wires into the foil on top and soldered back together followed up with a good wrapping of tape. You can't beat the price or availablity. The utility of such a four headed cable will amaze you once it's built. Use the two short ends (8 inches) for your disk drives with the long ones used for your computer and Atari printer. You now have three open ports to link everything else with. The only problem is when the color of the wires are not the same, I never ran into that situation though. Chances are good they will be matched which is something you should double check before soldering the first wire? I was in need of just such a critter when I got that AIM issue, thanks Paul, you saved the day. It's a bit more work than it sounds, but it's well worth doing. <end quote> Quote Share this post Link to post Share on other sites
Gunstar #15 Posted February 28, 2012 (edited) That AIM article was what I read and made a Y cable for back in the early 90's. I just couldn't rmember where I read the article. Though I thought I looked through all my AIM magazines for it without any luck, but maybe I'm missing the one with the article...I'll look again. Do you know which issue it was in? Oh, never mind, I see you were quoting someone else and those arn't your words... Edited February 28, 2012 by Gunstar Quote Share this post Link to post Share on other sites
