Pengwin #1 Posted March 9, 2012 I have this piece of code: ; Routine to load the next level level_vec .word $0000 scrn_vec .word GameScreen + $28 outchar .byte $00 loadlevel inc level ;Increment the level lda #$05 ;If the level is now 5, then set it back to 1 cmp level beq levelok lda #$01 sta level levelok ldx level ;Load the level and reduce it by 1 dex level txa ;Multiply the level by 2 for the offset asl tax lda lvlvectors,x ;Get the address of the level data sta level_vec lda lvlvectors+1,x sta level_vec+1 ldy #$00 getscrnchr lda (level_vec),y ; <---- THIS LINE HERE GENERATES THE ERROR cmp #$FF beq leveldone tax and #$0f clc adc #$40 sta outchar txa lsr lsr lsr lsr tax lda outchar rptscrnchr cpx #$00 beq getscrnchr sta (level_vec),y iny dex jmp rptscrnchr ; ++++++ HERE ++++++ leveldone lda #$00 ;Temporary instruction rts I know it's probablu quite messy, but this is my first real assembly project. However, when I try to run the assembler, it tells me that I have an illegal addressing mode on the indicated line. I though that indirect-indexed was allowed for LDA. Any help please Quote Share this post Link to post Share on other sites
Pengwin #2 Posted March 9, 2012 Never mind, just found out that it is for zero-page addresses only. That will explain my error Quote Share this post Link to post Share on other sites
