ColecoFan1981 #1 Posted April 2, 2012 http://www.digitpress.com/eastereggs/cvdonkeykong.htm Has anyone here ever been able to execute any of the following bugs successfully? If so, I'd like to see a video of these efforts. I've tried doing all of these without any success. 1. Start at Level 5: press # and 9 simultaneously. 2. Start at Level 6: press # and 0 simultaneously. 3. Start at Level 7: press #, 9 and 0 simultaneously. 4. Fall through the floor (elevators): Bring Mario to the top right of the elevator screen, where the Purse is. Below it is a short ladder. Climb it up and down quickly and Mario will fall right through the floor. What should I be doing? Thank you, Ben Edge Quote Share this post Link to post Share on other sites
RelliK111 #2 Posted April 3, 2012 http://www.digitpres...vdonkeykong.htm Has anyone here ever been able to execute any of the following bugs successfully? If so, I'd like to see a video of these efforts. I've tried doing all of these without any success. 1. Start at Level 5: press # and 9 simultaneously. 2. Start at Level 6: press # and 0 simultaneously. 3. Start at Level 7: press #, 9 and 0 simultaneously. 4. Fall through the floor (elevators): Bring Mario to the top right of the elevator screen, where the Purse is. Below it is a short ladder. Climb it up and down quickly and Mario will fall right through the floor. What should I be doing? Thank you, Ben Edge I have done the fall through the floor trick on the first stage but not on any of the others. These bugs are new to me. Is there any videos on you tube showing how to do it? Quote Share this post Link to post Share on other sites
phattyboombatty #3 Posted April 3, 2012 This is all new to me. Where did you hear about these key sequence-initiated bugs? Quote Share this post Link to post Share on other sites
ColecoFan1981 #4 Posted April 3, 2012 http://www.digitpres...vdonkeykong.htm Has anyone here ever been able to execute any of the following bugs successfully? If so, I'd like to see a video of these efforts. I've tried doing all of these without any success. 1. Start at Level 5: press # and 9 simultaneously. 2. Start at Level 6: press # and 0 simultaneously. 3. Start at Level 7: press #, 9 and 0 simultaneously. 4. Fall through the floor (elevators): Bring Mario to the top right of the elevator screen, where the Purse is. Below it is a short ladder. Climb it up and down quickly and Mario will fall right through the floor. What should I be doing? Thank you, Ben Edge I have done the fall through the floor trick on the first stage but not on any of the others. These bugs are new to me. Is there any videos on you tube showing how to do it? You and I both would like to see a video of Mario falling through the metal floor... Quote Share this post Link to post Share on other sites
