Satoshi Matrix
Original Xbox Modchips - Need advice
Not exactly a classic console but not modern either, I want to add in a modchip into my Xbox version 1.1 so I can install and use a 750 GB IDE seagate barracuda harddrive with it. I don't really require multiple dashboards or anything fancy, just as long as I have the large harddrive support across E and F partitions.
As of now in 2012, what is the best Xbox modchip to go with? I'm leaning towards the DuoX-2 GS more than the Aladdin XenoFX, but I want to hear from those who know about this stuff. Thanks.
I can't imagine what could make one chip better than the other aside from ease of installation. Live hasn't been an issue for years since (I presume) Microsoft shut it down for old Xbox. These days it'd be better to not have a stealth mode chip.
Just as long as you have a BIOS with the LBA patch for large drives, that's all you should really need.
Softmodding doesn't allow me to exchange the harddrive without severe difficulties, and even then I could only access the first 137 GB out of a 750 GB drive. Modchips allow up to 2 TB drives to be easily installed.
While I can't recommend much between each type of chip, a chip mod is so much easier to do if you have some basic soldering skills. And if the Xbox dies, it's not too hard to install a pin header in a replacement and just move the chip over.
But a softmod can't install an LBA patch for large HDs. Unless you know how to make a softmod work with large HDs, that is. Please do tell us how.
The only option that I can think of is to bridge the Write Enable points on the motherboard so you can rewrite the internal BIOS chip. But if you're going to do that, you might as well do a chip mod so you don't have to go through all that live swap nonsense to change the HD.
Booting copy discs is stupid when you can install games to a HD, and the optical drives themselves are aging, so you don't want to use them more than you have to. Even the much maligned PS2 drives are (IMHO) easier to keep running than the crap drives MS used.
I wouldn't call it severe difficulties (it's actually relatively easy), but point taken. You can't just drop in a hard drive on a hat like you could with a chip so that is an advantage.
Ah, I see. I wasn't aware of that limitation. :)
I had bad luck with Aladdin chips in the past, steer clear of that wreck. When I was still installing these things for people around 2004 or so, it was all Xecuter chips. Those are great. Then the Duo chips started coming out... I never used one, but I know they're closer to an Xecuter than Aladdin.
Actually that's not true at all. You can put in most any hard drive as far as I know. If there WAS a limit, it's definitely not 137 GB.Heck I've put 500gig drives in there with zero problems on a Ndure softmod and that was years ago. Been a long time now and I'm sure it has only improved.
Sure, you can put in a huge drive, but the stock BIOS won't be able to access beyond 137GB or so.
The reason is that the IDE command set only went that high until ATA100 came out and they added a new command set for bigger disks. The stock Xbox BIOS was made before those commands existed. Most hacked BIOSes will have the necessary patch.
There are only two ways to use a hacked BIOS:
1) solder a bridge over the points that disable write-protect on the main BIOS chip, then use some kind of a flasher utility
2) install a chipmod, which overrides the main BIOS chip
I'd feel a lot safer leaving the main BIOS chip unchanged as an anti-bricking fail-safe.
Edited by Bruce Tomlin
I think you're a little behind the times man and are thinking of old softmod methods. :P Current softmods with LBA48 support patch the MS-BIOS and that is no longer an issue and they EASILY support larger hard drives, and give you a whole bunch of useful standard features like virtual EEPROM, Shadow-C etc..
As I said before I've put 500 gig hard drives and filled them chock full of junk. Heck, just quickly looking, the set of PCE CD's alone is 132 gigs alone.. not to mention everything else. They access just fine. Put in a 750 gig hard drive if you want.
Just make sure you are doing a recent softmod. :)
Edited by NE146
Yeah, there's no point in using a mod chip at this point.
All my Xbox1 systems are softmodded. One has a 320GB drive. Another has a 160. Another has an 80. Another has a 40. I used the CASH CD (cereal's automated softmod helper, I think, it's been so long). Very very hard to find at this point. But I just downloaded it, burned it to disc, inserted it into the Xbox, followed the menu prompts, and voila, a fully modded system. No need for games. No need for cables. No need for memory cards. No need for anything else.
And the best thing about this mod was that everything was done in a virtual partition (not sure if I'm using the terminology correctly). So I still have full access to the original BIOS and full compatibility for everything. And if I wipe out the virtual partition, my Xbox1 goes back to its original state.
Edited by onlysublime
Cool, but the OP was wanting a 2TB drive. Can this be done on a softmod?
he didn't ask for a 2TB drive. but why would you use a 2 TB drive on the Xbox1? I don't even think all the Xbox1 games would take up 2 TB. And it can't really do HD movies so you're not using a lot of space on movies. And music is not big and the Xbox1 isn't fast enough for FLAC (actually, I don't know about FLAC, never tried it on Xbox1).
As for someone that did want to use a 2TB drive, I don't remember that limitation in the docs. The only limitation is finding a hard drive that is lockable. That is the rate limiting step with using softmods. With mod chips (AFAIK), you can use any drive. for softmods, I think you need a lockable drive (but don't hold me to this).
you can go to http://xboxdrives.x-pec.com/?p=list to see a list. Now, this list is completely volunteer. And most people have moved on to bigger and better things than the Xbox1 so the list isn't being updated as much as it should. So a lot of the newer drives are just trial and error on your part. For the softmods I have tried, they all needed the drive to be lockable which meant some hard drives I tried worked and some didn't. I myself added a few drives to the list that worked and some drives that didn't work.
Duo X is a nice chip and so is the Alladin. I always preferred the SmartX but I don't even know if they are made anymore. I never bothered with softmods. Had to open the case no matter what if adding a bigger HD, soldering may have taken 5 minutes at the most, multiple boot modes, safe modes and drive swaps were worth way more to me than a softmod.
I'm with starscream, I have duo x2 chips in 2 of my xbox's .
They are cheap, easy to install, available and reliable (4 years of almost daily use in my main xbox)
I did do a softmod once, years ago, but the hassle to try and install a large HDD put me off.
Ive got an Xbox 1 also. Do you have an ISO for Cash v1.1 ? The Torrents seems to have no seeders
I am interested in this as well.
Huh, I had a question about this as well. I was just wondering about which one to get , a Duo X would be fine? There is software out there that will auto-install the new dashboard of your choosing when you burn it, I was planning on installing EvolutionX or something similar.
It's on Usenet...
EvolutionX is supposedly old and outdated. It's what I use (modded my system a few years back), but apparently there are better ones available now. Where's Hyper_Eye when we need him? He knows a lot about XBOX modding.
I always used Evox as the dash, but XBMC now would be fine. Evox always had the FTP server built in which was valuable for modding multiple system or sharing. The Duox and other chips can be set to boot to different dashes from the chip itself depending on how you flash the chip. If you really want to get into all of that, the SmartX is the best chip for that, you can set up multiple bios' on the chip and when you power on the system, select which bios to boot. If you aren't going to tinker around, use any chip and XBMC.
Anyone looking do install a chip that hasn't done it before, you need to find which version of the system you have and flash the appropriate bios. In reality, a 1.6 system is the only one that won't boot off an older bios. And 1.6 systems are a pain in the ass for other reasons too.
Evox is one of the bioses that come with the Duox mod chip but it's a crap BIOS, especially the built-in ftp server. I highly recommend using XBMC as your dashboard.
