Tjoppen
I've lost my ZIP file with all TIA sounds - does anyone have it?
A while back I found a ZIP file on some blog where a fellow had recorded all sounds the TIA can produce as WAV files. I seem to have misplaced it. Does anyone else have it, or a link to said site? I spent a couple of minutes searching but came up empty.
I posted a batari Basic program that cycles through all of the AUDC0 and AUDF0 settings (simple to do), but it takes about an hour because it plays each sound for about 7 seconds. You could easily change the loop so each sound plays for a second or less. I can do that, record the output to DVD, and rip the sound to a WAV file if you need it. Is there any preference to order? My program played one AUDF0 setting and cycled through all AUDC0 settings before switching to the next AUDF0 setting, but it would be easy to do it the other way around.
As far as "all sounds," that would be kind of impossible, since you can create your own waveforms by setting AUDC0 to 0 and varying the AUDV0 setting.
I don't know if this would help, but I recorded all of the sounds from a real Atari 2600 for a page I had on my web site:
http://www.randomterrain.com/files_sounds/
After jwierer used the sounds in the Music and Sound Editor, the page was no longer needed, but I never got around to deleting that folder.
Quick question here:
Are there any soundfonts out there of the TIA at all? If there are, then it'd be fun to hear TIA renditions of Doom II music.
http://www.randomter...m/files_sounds/
Sweet, thanks. I grabbed them all and put them in a zip here: http://www.acc.umu.se/~tjoppen/files/vcs/tia_sounds.zip
