+RangerG #101 Posted July 27, 2012 I think one of the problems is that people got the stick without a cable. They were hyped up to play and then they just stare at the stick and start to notice imperfections. It's like buying a new Corvette, but you have no access to gasoline for a week :-). Once you use the controller, it is smooth. It makes you want to fire up the machine. The suction cups work great. I like the pass-through on the back. I have a Champ keypad (the less valuable one button kind). You can plug it into the back and then actually insert the overlays. I hope someone releases a game to use the buttons on the side or modifies some roms to use them. They are great. Quote Share this post Link to post Share on other sites
ColecoDan #102 Posted July 27, 2012 I think one of the problems is that people got the stick without a cable. They were hyped up to play and then they just stare at the stick and start to notice imperfections. It's like buying a new Corvette, but you have no access to gasoline for a week :-). Once you use the controller, it is smooth. It makes you want to fire up the machine. The suction cups work great. I like the pass-through on the back. I have a Champ keypad (the less valuable one button kind). You can plug it into the back and then actually insert the overlays. I hope someone releases a game to use the buttons on the side or modifies some roms to use them. They are great. pinball which is coming out later when the SGM is available is supposed to use those side buttons. Quote Share this post Link to post Share on other sites
Pixelboy #103 Posted July 27, 2012 I think one of the problems is that people got the stick without a cable. They were hyped up to play and then they just stare at the stick and start to notice imperfections. It's like buying a new Corvette, but you have no access to gasoline for a week :-). Once you use the controller, it is smooth. It makes you want to fire up the machine. The suction cups work great. I like the pass-through on the back. I have a Champ keypad (the less valuable one button kind). You can plug it into the back and then actually insert the overlays. I hope someone releases a game to use the buttons on the side or modifies some roms to use them. They are great. pinball which is coming out later when the SGM is available is supposed to use those side buttons. Rollerball, to be precise. Quote Share this post Link to post Share on other sites
harlock76 #104 Posted July 27, 2012 guys get a male female db 9 cable take out the screws on the female side so you can connect the extension on it and it work just fine Quote Share this post Link to post Share on other sites
purenergy #105 Posted July 28, 2012 Colecovision Arcade Joystick #14 has arrived safely, and works great! The Joystick control is wonderful, as I tested several games, they all worked great. All 4 buttons work fine. And, the cable connection is fine, no problems at all. (Wish I could test the side buttons.) Everyone (retroillucid, coleco_master and 5-11under) did a great job bringing the arcade experience home to enjoy on the ColecoVision! Thanks! 1 Quote Share this post Link to post Share on other sites
NIAD #106 Posted July 28, 2012 Wish I could test the side buttons You can, but not for the method that they were designed/intended for as they will function as if you are pressing left or right on the Controller/Joystick. For instance, if you press the left side button in Donkey Kong, Mario will move left. If you press the right side button, Mario will move right. At least this way you can test them out to make sure they are working properly and when Rollerball is released by CollectorVision you will be able to put them to work as they were intended. 1 Quote Share this post Link to post Share on other sites
ColecoDan #107 Posted July 28, 2012 Wish I could test the side buttons You can, but not for the method that they were designed/intended for as they will function as if you are pressing left or right on the Controller/Joystick. For instance, if you press the left side button in Donkey Kong, Mario will move left. If you press the right side button, Mario will move right. At least this way you can test them out to make sure they are working properly and when Rollerball is released by CollectorVision you will be able to put them to work as they were intended. If you want to make the games more difficult you could use the buttons instead of the joystick for left and right then. I will have to wait for my correct cable. A few weeks is not long to wait when we had to wait many months for them to finish making them 1 Quote Share this post Link to post Share on other sites
retroillucid #108 Posted July 28, 2012 Here's Rollerball (MSX Version) http://www.youtube.com/watch?v=2z2RmIQQjP4&feature=youtube_gdata_player Quote Share this post Link to post Share on other sites
Cebus Capucinis #109 Posted July 28, 2012 ....I am going to timidly ask: Are any more of these available? Quote Share this post Link to post Share on other sites
retroillucid #110 Posted July 28, 2012 ....I am going to timidly ask: Are any more of these available? No, all sold out although...... Toby gave me my Official #29 Letter with the label to put on my controller, because I have the prototype unit but if Toby want to make the number 29 to you, then It's yours! I will keep my unit labeled Prorotype I know he have a PCB left Quote Share this post Link to post Share on other sites
Cebus Capucinis #111 Posted July 28, 2012 I worked a lot of overtime this week, so my paycheck should be bigger on Friday......hmmm! Quote Share this post Link to post Share on other sites
retroillucid #112 Posted July 28, 2012 I worked a lot of overtime this week, so my paycheck should be bigger on Friday......hmmm! Contact coleco_master If he agree to make the #29 , then it's yours I prefer to keep mine as the proto as the unit is slightly different by having the Coleco logo at the bottom center of the unit And some other minor issues... Quote Share this post Link to post Share on other sites
Cebus Capucinis #113 Posted July 28, 2012 Sending a PM to him now! Quote Share this post Link to post Share on other sites
+RangerG #114 Posted July 28, 2012 If you want to take your controller apart, use a Robertson screwdriver. The front screws use a #1 and the back #2. You won't slip and scratch up your controller this way. These are evidently common in Canada. Quote Share this post Link to post Share on other sites
HARMIK #115 Posted July 31, 2012 Cant wait to get mine Quote Share this post Link to post Share on other sites
+grips03 #116 Posted July 31, 2012 (edited) Any plans to do a re-release? I missed out on this. Edited July 31, 2012 by grips03 Quote Share this post Link to post Share on other sites
retroillucid #117 Posted July 31, 2012 Any plans to do a re-release? I missed out on this. No, but we plan to sell KIT to make your own Quote Share this post Link to post Share on other sites
+grips03 #118 Posted July 31, 2012 will kit contain internal componets only (pcb, wiring)? or keypad, joystick, controller, case, cable, stickers, etc as well? Quote Share this post Link to post Share on other sites
retroillucid #119 Posted July 31, 2012 will kit contain internal componets only (pcb, wiring)? or keypad, joystick, controller, case, cable, stickers, etc as well? The Kit will contains, The PCB, already wired with clamps , mean no soldering necessary Will contains the Keypad too The only things you will need, is make your own case and buy some arcade buttons and a joystick Quote Share this post Link to post Share on other sites
+grips03 #120 Posted July 31, 2012 when will the kit ship and how much ? Quote Share this post Link to post Share on other sites
retroillucid #121 Posted July 31, 2012 when will the kit ship and how much ? too much early to say Too much projects already in the pipe , it won't happen until next year Quote Share this post Link to post Share on other sites
+grips03 #122 Posted July 31, 2012 ok, np by the way $180 for the aracde quality controller (complete pre-built ones) is a great deal. The amount of effort that must have went into it is incredible. 1 Quote Share this post Link to post Share on other sites
retroillucid #123 Posted July 31, 2012 ok, np by the way $180 for the aracde quality controller (complete pre-built ones) is a great deal. The amount of effort that must have went into it is incredible. Thanks Quote Share this post Link to post Share on other sites
cOLeCoHiTMan #124 Posted July 31, 2012 The acrylic has some spots where the black layer underneath is not flush. It looks like an oil slick (hard to describe...maybe it's adhesive residue???). I noticed these as well.. they were around the screws. I was able to get rid of them for the most part by loosening and tightening the screws.. If I go really tight the oil slick would appear again.. not sure how to make it disappear altogether. 1 Quote Share this post Link to post Share on other sites
+RangerG #125 Posted August 1, 2012 Yes, just loosen up the screws if you have that oily stuff. You may need to open the back and loosen the screws from the back. That's what I did and it is gone now. Quote Share this post Link to post Share on other sites
