sailorcull
Atari ST won't show files on disk in drive
I just purchased a 1040 STFM on ebay and low and behold, it turns on, the disk drive light comes on for a second and the monitor screen shows the usual top menu, but shows no files on the disk. I have tried many disks and have tried the disks on my other ST and the disks are fine. What would cause the system to not read the disk? The drive also does not make a sound.
Thank you in advance..
LSC
If you're a bit adventurous, you can swap the known working drives from the other ST
to the non-working one and see if that is what it is...
If you do that, and it still doesn't work, then while you have it apart, carefully check
and reseat all the socketed chips. They suffer from "creep" sometimes.
HTHs.
I am adventurous but I kind of don't want to mess up the working one doing this! I am going to see about returning it. Wish me luck!
Thank you for your reply..
Well, honestly...its not that hard to take them apart. Just go slow, be careful, take pictures
of things as you go, you would do okay.
But if not, I hope you can get your money back at least! :)
