_ThEcRoW #1 Posted June 17, 2012 Hello guys, i'm trying to find this game, i found on a site a disk image, but it is a .stx and i don't know how to write back to disk. I tried one automation disk that has the game, but when select it from the menu, it justs get back to tos desktop. I assume that it was a bad crack and the game won't start. Anyone? Thanks in advance!!! Quote Share this post Link to post Share on other sites
Charlie_ #2 Posted June 17, 2012 (edited) Try here: http://www.thegamear...0_4_25_0_23_1_0 Edit: Nevermind that is the STX also... I'll keep looking.... Edited June 17, 2012 by Official Ninja Quote Share this post Link to post Share on other sites
Charlie_ #3 Posted June 17, 2012 Hello guys, i'm trying to find this game, i found on a site a disk image, but it is a .stx and i don't know how to write back to disk. I tried one automation disk that has the game, but when select it from the menu, it justs get back to tos desktop. I assume that it was a bad crack and the game won't start. Anyone? Thanks in advance!!! Ok the automation disk 19 works but you have to select 50Hz before starting the game. I tested it to start on my 1040STFM Tos1.0 and STE Tos1.62. Enjoy. If you can't get your working I'll attach the version I have here. Quote Share this post Link to post Share on other sites
_ThEcRoW #4 Posted June 17, 2012 Cool, will try the automation disk with 50 hz option. Will post the results. Quote Share this post Link to post Share on other sites
_ThEcRoW #5 Posted December 27, 2012 Tried the automation disk, and used 50hz mode, but still it didn't work. I tried to google a .st version, but seems that is nearly impossible. Has anyone a .st image of this game? Quote Share this post Link to post Share on other sites
ParanoidLittleMan #6 Posted December 28, 2012 Strange. Only 1 crack available ? I would not say that it is bad crack, just that works not on some configurations. Anyway, I will do ST/MSA + hard disk installable 'cracks' in days. Hopefully, STX is error-free. Quote Share this post Link to post Share on other sites
_ThEcRoW #7 Posted December 29, 2012 Thanks for the help ParanoidLittleMan. I'll wait anxiously for your .st cracks. It's interesting that no .st image is on the net, at least i didn't find it. Quote Share this post Link to post Share on other sites
ParanoidLittleMan #8 Posted December 31, 2012 I have in my collection some 4 different cracks of this. But made own, + harddisk runnable (protection is joke). http://atari.8bitchip.info/ASTGA/W/wheretss.php http://atari.8bitchip.info/SCRSH/wheretss.html New things in above hard disk adapt.: overscan intro pic for ST(E), Falcon, TT intro pic show from regular BMP file. Quote Share this post Link to post Share on other sites
_ThEcRoW #9 Posted December 31, 2012 Thanks for the image!. I put it in a floppy and tried to boot it, but it appeared to run, then, bring back to the gem desktop. I have noted that the image is a 400kb one, and the format used in floimg was of 720, because the others were too short to use. How is the optimum way to write back the image to floppy?. Is there any trick in floimg for disks that size?. Thanks in advance!!! Quote Share this post Link to post Share on other sites
ParanoidLittleMan #10 Posted January 2, 2013 There is no special format 720 in FloImg. It works geometry based. CHS parameters - in case of 400KB floppy it is 1 side, 10 sectors/track and 80 tracks. Very common format. You should see those parameters after opening image file. If writing was OK, it may be that reading with Atari is unreliable. Or you have some failure im machine. Btw. what TOS version ? You may try following to increase readibility on Atari: format floppy on Atari, but not with Desktop formatter - there is a lot of SW capable to fromat 10 s/track. Just set above parameters or 400K format. Then insert in PC, and check off format in FloImg, and click write ... If getting error messages like RNF then there is very likely head misalign between floppy drives case. Quote Share this post Link to post Share on other sites
_ThEcRoW #11 Posted January 2, 2013 The disk was formatted previously on the atari, and on another disks or images it doesn't fail. Will try the suggestion on formatting with another tool. On the other hand, floimg didn't report anything wrong, just that the writing was ok, but the image was smaller that the disk format(400kb vs 720kb of the disk). Other than that, it went ok. Will try your suggestions and report here the results. Thanks and happy new year to all! Quote Share this post Link to post Share on other sites
ParanoidLittleMan #12 Posted January 2, 2013 Happy New Year Fact that on floppy writes something like 720K means nothing. It will have format/capacity according to what SW for formatting creates. Many of original games were distributed on SS floppies, formatted to 400K - and it stays for this game too. And all it was on 720K floppies. So, I'm not who invented 400K format To be sure that you write it correctly, do following: after writing image onto floppy, make test image by clicking Floppy to Image - give some other name. Then compare it with source file. Simplest is with Total Commander. If images are not same, you set something wrong. If are same, then something from what said in previous post. Quote Share this post Link to post Share on other sites
tjlazer #13 Posted June 15, 2014 Hmmm been having trouble getting this to work, in STeem or on real hardware. Found the problem! It NEEDS a UK TOS to run! Weird, the first game I found like this... Any patched version out there that will work with other TOS's? Quote Share this post Link to post Share on other sites
ParanoidLittleMan #14 Posted June 15, 2014 Hmmm been having trouble getting this to work, in STeem or on real hardware. Found the problem! It NEEDS a UK TOS to run! Weird, the first game I found like this... Any patched version out there that will work with other TOS's? Not just UK TOS is OK, but any TOS working at 50Hz . I updated floppy version, so it works now at 60 Hz too, so with US TOS versions. http://atari.8bitchip.info/ASTGA/W/wheretss.php Quote Share this post Link to post Share on other sites
