candle Posted July 26, 2012 Author Share Posted July 26, 2012 true wonder if Lenore could be bothered to make an adapter for them Quote Link to comment Share on other sites More sharing options...
Marius Posted July 26, 2012 Share Posted July 26, 2012 you would need antic and gtia plus some parts you can pick up in any store the only thing left to get is crystal you need to change - you may pull that out from broken pal XL board, or buy from one of atari suppliers mine was ntsc, but now is 100% PAL This is INTERESTING ... Could you tell me more about those 'some parts'? And why is it so much harder to convert 1200xl from NTSC to pal? Quote Link to comment Share on other sites More sharing options...
candle Posted July 26, 2012 Author Share Posted July 26, 2012 1200xl? you get Lenore's adapter and you're done with NTSC/PAL conversion for 1200XL i'll make a photo of CPU board when i'll return from the copy party - possibly with labels on components that were added Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 26, 2012 Share Posted July 26, 2012 1200xl? you get Lenore's adapter and you're done with NTSC/PAL conversion for 1200XL Can't wait to get mine fitted! Quote Link to comment Share on other sites More sharing options...
Marius Posted July 26, 2012 Share Posted July 26, 2012 Where do I get that adapter?!! Quote Link to comment Share on other sites More sharing options...
+tf_hh Posted July 26, 2012 Share Posted July 26, 2012 Hi, And why is it so much harder to convert 1200xl from NTSC to pal? Hmm, this isn´t "hard". You´ve only to change the ANTIC & GTIA against PAL versions, replace the system crystal and add a little circuit to generate the PAL color clock @ 4,43 MHz. This was one of my first conversions to PAL. Regards, Juergen Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 26, 2012 Share Posted July 26, 2012 Hmm, this isn´t "hard". You´ve only to change the ANTIC & GTIA against PAL versions, replace the system crystal and add a little circuit to generate the PAL color clock @ 4,43 MHz. Ah... we could have used your help when Lenore was designing the adapter board. I tried to build one similar to the one in your picture, but it never worked for s**t. Anyway: Lenore's adapter (now working fine, I'm told) sits in the GTIA socket, and is almost a solderless upgrade (still need to change the master crystal, of course). Quote Link to comment Share on other sites More sharing options...
+wood_jl Posted July 26, 2012 Share Posted July 26, 2012 Is the crystal (on the old Beige 800) located on the CPU/ANTIC/GITA card, or on the motherboard? If it is on the CPU card, could you then change a machine back and forth by merely swapping the NTSC CPU card for a PAL one? Sloopy! Can you "make" PAL 800s one day? Quote Link to comment Share on other sites More sharing options...
+Stephen Posted July 26, 2012 Share Posted July 26, 2012 The crystal is unfortunately on the motherboard. The other thing too, the CPU card is installed under the nuclear bomb proof shielding. It takes forever to get at it. It's possible that a board which allows for selectable crystals could be made, but IIRC, there is a bit of additional circuitry besides just the crystal needed, to get the proper colourburst divisor. Quote Link to comment Share on other sites More sharing options...
Marius Posted July 26, 2012 Share Posted July 26, 2012 Is there already a pre order thread going? I certainly do not want to miss this for my 1200xl!!! Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 26, 2012 Share Posted July 26, 2012 Is there already a pre order thread going? I certainly do not want to miss this for my 1200xl!!! I think Lenore will start a pre-order when she's made some minor amendments to the board. You're not missing out, though! Quote Link to comment Share on other sites More sharing options...
+tf_hh Posted July 27, 2012 Share Posted July 27, 2012 Hi, Ah... we could have used your help when Lenore was designing the adapter board. I tried to build one similar to the one in your picture, but it never worked for s**t. Anyway: Lenore's adapter (now working fine, I'm told) sits in the GTIA socket, and is almost a solderless upgrade (still need to change the master crystal, of course). Of course I will help, when I can. But I do nothing special The little circuit for the PAL generator is 1:1 used from the 800 XL schematics, I use all the components like in a stock 800 XL. Jürgen Quote Link to comment Share on other sites More sharing options...
Frankie Posted August 2, 2012 Share Posted August 2, 2012 Is the pre-order filled for the 800 ? I wanted one but didn't get here soon enough! Quote Link to comment Share on other sites More sharing options...
Nikos Pachtas Posted August 4, 2012 Share Posted August 4, 2012 Sebastian, I just received an Atari 800 and although it had some unfortunate moments traveling from USA to Greece, I would realy like to have one incogito board for it, please. Quote Link to comment Share on other sites More sharing options...
candle Posted August 4, 2012 Author Share Posted August 4, 2012 i'll get back to everyone who send me PM about additional incognito boards in a day or two, currently i want to have first panel assembled by hand and design verified at this moment 3 chips from each board are missing, bottom side is fully populated, top is missing some parts hopefully i'll do it today (well, when i wake up) Quote Link to comment Share on other sites More sharing options...
candle Posted August 5, 2012 Author Share Posted August 5, 2012 (edited) ok laidies here is first panel and the only panel i've assembled manually to verify the design Edited August 5, 2012 by candle 3 Quote Link to comment Share on other sites More sharing options...
+wood_jl Posted August 5, 2012 Share Posted August 5, 2012 I sure like those pics, candle! Quote Link to comment Share on other sites More sharing options...
Stephen J. Carden Posted August 6, 2012 Share Posted August 6, 2012 I like what I see. Have one question for you. Does this upgrade have r/w ram at $d700--$d7ff? The reasion I ask is the Ultra-Speed OS that Bob Puff created uses sram mapped into $d700--$d7ff. Thanks Steve Quote Link to comment Share on other sites More sharing options...
candle Posted August 6, 2012 Author Share Posted August 6, 2012 it has R/W ram at d700-d7ff, but it's there for internal PBI device what is ultra-speed os? does it has any advantages over Hias modified stock os? having $d700-$d7ff mapped constantly as RAM will cause incompatibilities with extensions like VBXE or MIO, so i would rather walk away from this anyways, here is updated list, please check if everything is as it should be Quote Link to comment Share on other sites More sharing options...
BillC Posted August 6, 2012 Share Posted August 6, 2012 it has R/W ram at d700-d7ff, but it's there for internal PBI device what is ultra-speed os? does it has any advantages over Hias modified stock os? having $d700-$d7ff mapped constantly as RAM will cause incompatibilities with extensions like VBXE or MIO, so i would rather walk away from this anyways, here is updated list, please check if everything is as it should be The CSS US+ OS has some extra features, these include a configuration menu which allows remapping drives, a built-in RAMdisk handler which recognizes any size XE-type memory upgrade up to 2MB, and an enhanced memory test routine which has been rewritten and tests all of the available memory. Information about all the features can be found on Bob Puffs current website: http://www.nleaudio....ss/products.htm. The information provided doesn't mention anything about SRAM being part of the module but it is only describing the features, not the technical details. Quote Link to comment Share on other sites More sharing options...
FastRobPlus Posted August 6, 2012 Share Posted August 6, 2012 ok laidies here is first panel and the only panel i've assembled manually to verify the design This should fit my modded 800 perfectly!! 2 Quote Link to comment Share on other sites More sharing options...
Apatama Posted August 7, 2012 Share Posted August 7, 2012 anyways, here is updated list, please check if everything is as it should be Hey Candle, I just checked your updated pre-order list. You omitted my request for one board. Quote Link to comment Share on other sites More sharing options...
kenjennings Posted August 9, 2012 Share Posted August 9, 2012 ok laidies here is first panel and the only panel i've assembled manually to verify the design This should fit my modded 800 perfectly!! That has some really rough-looking plastic joints. (Your copy of photoshop needs the sandpaper plugin.) Quote Link to comment Share on other sites More sharing options...
1NG Posted August 9, 2012 Share Posted August 9, 2012 As far as I read here there are still a few boards available, so I want to get one. (I am lucky that I havn´t sold it 27 years ago, it is still MY computer. I would not sell it for 500€) Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted August 9, 2012 Share Posted August 9, 2012 This should fit my modded 800 perfectly!! "Alert Alert ! This is Battleship Galactica, attention to all our Star Raider pilots - our long range scanners have just detected new forms of Zylon base stars..." Original: New Form: ;-) Andreas Koch. Quote Link to comment Share on other sites More sharing options...
