Synthpopalooza #251 Posted September 7, 2012 The Violator one is a fairly easy one to do, as that one only uses about 4 or 5 colors. Nice to see a fellow modehead, tho personally I am more of an Erasure/Vince Clarke fan. Quote Share this post Link to post Share on other sites
miker #252 Posted September 7, 2012 "Hobo with a shotgun" Created this way: /i=hobo.jpg /filter=box /dither=chess /pal=laoo.act /s=10000 /h=213 Original: My convert (after 485 million of iterations): And the xex file: miker_hobo_with_a_shotgun.xex Enjoy! 4 Quote Share this post Link to post Share on other sites
Synthpopalooza #253 Posted September 16, 2012 This one's for Philsan: synthpopalooza - dmode90.xex 2 Quote Share this post Link to post Share on other sites
+Philsan #254 Posted September 16, 2012 Thank you Synthpopalooza. Posts without images are not allowed so I reply with this car: Philsan_MercedesCLK230Kompressor.xex 1 Quote Share this post Link to post Share on other sites
pps #255 Posted September 16, 2012 This one's for Philsan: synthpopalooza - dmode90.xex ... not only for him Quote Share this post Link to post Share on other sites
ilmenit #256 Posted October 10, 2012 (edited) I'm still out of time to merge the latest changes with the main branch, but here are some new pics (PAL + Laoo palette). ilmenit_demon.xex ilmenit_ESET_41M.xex ilmenit_eset2.xex ilmenit_kretik.xex ilmenit_lionking.xex ilmenit_lobo.xex ilmenit_mary.xex ilmenit_reksio.xex ilmenit_warcraft.xex Edited October 10, 2012 by ilmenit 10 Quote Share this post Link to post Share on other sites
ilmenit #257 Posted October 11, 2012 Some art ilmenit_japanbird.xex ilmenit_kanagawa.xex ilmenit_manet.xex 6 Quote Share this post Link to post Share on other sites
+Philsan #258 Posted October 12, 2012 Philsan_AtariVideoMusicAd.xex 1 Quote Share this post Link to post Share on other sites
mrnukem #259 Posted November 16, 2012 Here is a set of 10 Christmas images I made using the Rasta Converter software. Enjoy! christmas 2012.zip 2 Quote Share this post Link to post Share on other sites
+Philsan #260 Posted December 1, 2012 Another "animated" image (click to enlarge). Philsan_Illusion_2.xex 1 Quote Share this post Link to post Share on other sites
mrnukem #261 Posted April 28, 2013 How does details mask work and how would I generate a details mask from a picture to use in the Rasta Converter. I poked around the Rasta FAQ and Forum Posts but still did not find the answer to this question so decided it was best to ask. BTW all the pictures are really great. I love this tool and have been playing with it for a long time now and still enjoying it. Quote Share this post Link to post Share on other sites
mrnukem #262 Posted April 29, 2013 How does details mask work and how would I generate a details mask from a picture to use in the Rasta Converter. I poked around the Rasta FAQ and Forum Posts but still did not find the answer to this question so decided it was best to ask. BTW all the pictures are really great. I love this tool and have been playing with it for a long time now and still enjoying it. I forgot to ask if there is a utility that will let me extract the raw picture file from the.xex files? Would they extract to a known atari picture format so that i could use one of the many picture viewers with slide show function? thank you Quote Share this post Link to post Share on other sites
+Roydea6 #263 Posted April 29, 2013 With SpartaDOS you can batch file the Raster View images to view continuously just needs a key press for each new view. Quote Share this post Link to post Share on other sites
ilmenit #264 Posted April 29, 2013 I forgot to ask if there is a utility that will let me extract the raw picture file from the.xex files? Would they extract to a known atari picture format so that i could use one of the many picture viewers with slide show function? RastaConverter executables are not only raw data but the main part is the raster program that shows the data. The program is generated for each picture separately. Quote Share this post Link to post Share on other sites
mrnukem #265 Posted April 29, 2013 RastaConverter executables are not only raw data but the main part is the raster program that shows the data. The program is generated for each picture separately. Thank you and thanks for all your great work and pictures you have shared here. Do you happen to have a link to a document explaining how the details mask function works? Quote Share this post Link to post Share on other sites
ilmenit #266 Posted April 29, 2013 Thank you and thanks for all your great work and pictures you have shared here. Do you happen to have a link to a document explaining how the details mask function works? The details mask is briefly described here: http://atariage.com/forums/topic/200118-images-generated-by-rastaconverter/page__st__175#entry2581819 Let me know if you need some more info. Quote Share this post Link to post Share on other sites
mrnukem #267 Posted April 29, 2013 The details mask is briefly described here: http://atariage.com/...75#entry2581819 Let me know if you need some more info. So if I take the original picture then cover with a black layer and use an erase function to re-expose important areas of the photo would that work as a mask picture? Quote Share this post Link to post Share on other sites
ilmenit #268 Posted April 29, 2013 So if I take the original picture then cover with a black layer and use an erase function to re-expose important areas of the photo would that work as a mask picture? It will work. I usually add a new layer, select a shape that I want to make more detailed, fill it with white, invert selection, fill the rest with black. Quote Share this post Link to post Share on other sites
mrnukem #269 Posted April 29, 2013 It will work. I usually add a new layer, select a shape that I want to make more detailed, fill it with white, invert selection, fill the rest with black. Thank you very much for taking time to answer my question. I will give it a try. Quote Share this post Link to post Share on other sites
mrnukem #270 Posted April 29, 2013 Some Pictures I converted. Trying more complex ones now, will post those worth sharing mrnukem-dpanic.xex mrnukem-pitfall.xex 1 Quote Share this post Link to post Share on other sites
+Stephen #271 Posted April 30, 2013 Wow - the Pitfall one is really nice. I remember seeing that ad when it was new Quote Share this post Link to post Share on other sites
mrnukem #272 Posted May 1, 2013 Here are some of my new rasta Conversions. mr_nukem_burger.xex mr_nukem_gandalf.xex mr_nukem_wfall.xex mr_nukem_djin.xex 2 Quote Share this post Link to post Share on other sites
mrnukem #273 Posted May 5, 2013 Newest creations. I have to say I am happy how well the King Tut image turned out. I let the conversion software run for 24 hours on it. mrnukem_tut.xex mrnukem_coke1.xex mrnukem_tolkien runes.xex Quote Share this post Link to post Share on other sites
+Philsan #274 Posted May 6, 2013 Philsan_Pencils.xex 4 Quote Share this post Link to post Share on other sites
ilmenit #275 Posted May 6, 2013 Wow, this is colorful - 103 unique colors :-) Quote Share this post Link to post Share on other sites
