+Stephen #1926 Posted January 26, 2019 Question for all - is there a program that can let me say get a preview of an image with boosted saturation / contrast / levels, such that I can really pixel perfect erase all of a background to black, but not actually change the levels, then do the erase, then try to revert the levels? Hope this makes sense. Quote Share this post Link to post Share on other sites
Gunstar #1927 Posted January 26, 2019 (edited) Well, you can load the finished .xex or actually I think you make a MCH file in Rasta and load that up into G2F and make it all as perfect as possible down to the pixel. But of course it is then a G2F .xex image you've made in the end and not an imperfect direct Rastaconverter .xex image anymore. For me the fun of Rastaconverter is seeing how close to perfect can be reached with any given image without further pre or post editing than is necessary for proper scale and ration, etc. But yes, you can also use G2F to touch things up pre-rasta conversion too, I think, I don't use it so I'm not sure what's involved, but lot of the guys here do know. Maybe it's just swapping MCH files between G2F and Rastaconverter or similar. I think using masking is the same basic principal too. Again, I never have actually made a mask and I used one made for me once. Edited January 26, 2019 by Gunstar 1 Quote Share this post Link to post Share on other sites
dmsc #1928 Posted January 27, 2019 Hi! Question for all - is there a program that can let me say get a preview of an image with boosted saturation / contrast / levels, such that I can really pixel perfect erase all of a background to black, but not actually change the levels, then do the erase, then try to revert the levels? Hope this makes sense. Using GIMP image editor, in the menu "View", "Display filters...", you can add a gamma or contrast filter and set to a high value, so you view a filtered version of the image without modifying it. 1 Quote Share this post Link to post Share on other sites
+Stephen #1929 Posted January 27, 2019 Hi! Using GIMP image editor, in the menu "View", "Display filters...", you can add a gamma or contrast filter and set to a high value, so you view a filtered version of the image without modifying it. Thank you - that is exactly what I need. Quote Share this post Link to post Share on other sites
+Stephen #1930 Posted January 27, 2019 In honour of today's 32nd Royal Rumble. I should have mentioned before - almost all of my pictures are PAL. I have no idea how Vince's lawyers lost to the damn World Wildlife Federation. Would anyone confuse the two company abbreviations? This is a cheat. I know that hand pixelling this in G2F would look super crisp, but I was experimenting with the gamma and brightness settings. This should need no explanation. Five years before his iconic defeat of the Iron Shiek, the Hulkster was absolutely massive. No doubt juiced to the gills. Say what you will, but forty years later, the Hulkster is out to prove that Hulkamania really is immortal! Finally, we have the beautiful Irish lass-kicker Becky Lynch wearing her war paint. All screenshots were taken using untouched Altirra PAL settings. Above images were a combination of laoo and Altirra palette. Stephen_WWF.xex Stephen_Wrestlemania.xex Stephen_HulkHogan1979.xex Stephen_HulkHogan2019.xex Stephen_BeckyLynchBustedFace.xex 6 Quote Share this post Link to post Share on other sites
a8isa1 #1931 Posted February 4, 2019 (edited) I can't remember if I ever posted this conversion. I've tried many times to improve upon it but with no success. looks better on my new (to me, circa 2000) CRT TV than it does on my laptop's LCD. It looks reasonably good on my phone. I mean the screenshot does. NTSC only a8isa1_54vette.xex Edited February 4, 2019 by a8isa1 11 Quote Share this post Link to post Share on other sites
a8isa1 #1932 Posted February 4, 2019 Monet's Woodbearers in Fontainebleu Forest 37 colors NTSC a8isa1_monet0484.xex 9 Quote Share this post Link to post Share on other sites
miker #1933 Posted February 5, 2019 Ok, found this: https://demozoo.org/graphics/199009/ Should look cool albeit it's a bit higher resolution. Please give it a try. Quote Share this post Link to post Share on other sites
+Stephen #1934 Posted February 5, 2019 Ok, found this: https://demozoo.org/graphics/199009/ Should look cool albeit it's a bit higher resolution. Please give it a try. Well, I had it done, looked awesome in the preview. I just learned an important lesson - do not use the "Grey" palette. It turned into a psychadelic skull Should only take another 15 minutes to re-convert and I'll post. This one was very easy, because the unaltered source image was only 7 colours. Quote Share this post Link to post Share on other sites
_The Doctor__ #1935 Posted February 5, 2019 post both Quote Share this post Link to post Share on other sites
miker #1936 Posted February 5, 2019 Well, I had it done, looked awesome in the preview. I just learned an important lesson - do not use the "Grey" palette. It turned into a psychadelic skull Should only take another 15 minutes to re-convert and I'll post. This one was very easy, because the unaltered source image was only 7 colours. Superb! Quote Share this post Link to post Share on other sites
+Stephen #1937 Posted February 5, 2019 post both Here is the correct conversion using Altirra palette: Stephen_AmigaSkull.xex Here is the invalid conversion using Grey palette: Stephen_AmigaSkull_Green.xex 5 Quote Share this post Link to post Share on other sites
_The Doctor__ #1938 Posted February 5, 2019 (edited) you could try again, just downloaded ami skull, that's one angry creature! ssome pointy teeth and wide brow edit grabbed the second skull you added that looks like it came archeological dig. Edited February 5, 2019 by _The Doctor__ Quote Share this post Link to post Share on other sites
+Stephen #1939 Posted February 5, 2019 you could try again, just downloaded ami skull, that's one angry creature! ssome pointy teeth and wide brow Edited the original post - look above 1 Quote Share this post Link to post Share on other sites
+Stephen #1940 Posted February 10, 2019 Well, not very happy with this one at all. Too many colours per line. I am posting this crappy version along with my source as a learning experience. What I did: Took a direct screen capture from MAME. Careful cropping got me an image of 331*242. Close enough I said, and resized to an exact 320*240 Using FastStone, I reduced from the original 20,000 colour image down to 7-bit (128 colour). Note - this did not let me choose the palette, it only reduced overall colours. Rasts settings were quite basic. YUV, Altirra palette, 10,000 solutions, no dither. Source: Screenshot: Executable: Stephen_Escape.xex 8 Quote Share this post Link to post Share on other sites
Rybags #1941 Posted February 11, 2019 Some extra help maybe - "Add coins to start" could be removed though allowing more colour on those lines would leave a conspicuous blank area. Atari logo - change to same colour as the background of "Robot Monsters". 2 Quote Share this post Link to post Share on other sites
ggn #1942 Posted February 12, 2019 Another idea would be to start with a touched up image with less colours. For, example the Atari ST version: 1 Quote Share this post Link to post Share on other sites
tebe #1943 Posted February 13, 2019 (edited) mayby it's time to create slideshow ? but ... we have only XEX-s, how, how it's possible p.s. http://g2f.atari8.info/rc2mch.7z Edited February 13, 2019 by tebe 4 Quote Share this post Link to post Share on other sites
Rybags #1944 Posted February 13, 2019 Some nice pics there but almost all look like C64 conversions. Slideshow - some sort of Ram save/restore might be needed. Or possibly XBios could just do it by default? Quote Share this post Link to post Share on other sites
Bob The Bug #1945 Posted February 13, 2019 C64 conversions or not - that is probably the most stunning collection of Atari 8-bit images i have ever seen... I'm stunned...! WOW ! Quote Share this post Link to post Share on other sites
+Roydea6 #1946 Posted February 13, 2019 tebe, Would you mind sharing the xex files used to make this video. Quote Share this post Link to post Share on other sites
MaPa #1947 Posted February 13, 2019 Maybe I don't get it, but isn't this demo from some ZX Enhanced machine and surely not Atari? Quote Share this post Link to post Share on other sites
Rybags #1948 Posted February 13, 2019 Yep, it's some sort of modern day enhanced ZX Spectrum but there seems to be not much info around about it. The demo looks like it's using the Atari font. Cue to around 3:20 for info on the program and hardware. Quote Share this post Link to post Share on other sites
Bob The Bug #1949 Posted February 13, 2019 Ha! I was too busy admiring the pictures to read the scroller the first time. I thought they were G2F images, rather than Rastaconverter... but not actually Atari images at all. Awesome 8-bit art though! Quote Share this post Link to post Share on other sites
tebe #1950 Posted February 13, 2019 Maybe I don't get it, but isn't this demo from some ZX Enhanced machine and surely not Atari? smart guy http://www.pouet.net/prod.php?which=80171 Quote Share this post Link to post Share on other sites
